slp super quiet muffler...... - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old October 30th, 2012, 01:25 AM Thread Starter
unclecrazy1's Avatar
has anyone realy tried this thing yet??? looking for some info....does it realy work??is it worth the money???
unclecrazy1 is offline
post #2 of 7 Old November 1st, 2012, 03:22 PM
yoshman762's Avatar
Re: slp super quiet muffler......
Ive been running this muffler since May, I like it. I dont have a fuel controler or air box. I run a stock air filter. I know the stock exhaust is raspy sounding on the S model. The Super quiet is consideribly better sounding, at idle all you can here is the motor run, lower speeds up to about 30 35 mph, its quieter than stock, you can have a conversation and not be yelling. Once you get to 40 it sounds stock but, a little more throaty, without the rasp but, still quiet. The fit and finish seems good, the welds are clean, and its shiny, whatelse could you want from an exhaust? It comes with a spark arrestor, bushings and brackets, fairly easy to install. As I mentioned I run everything else stock motor wise but tire set up, 9x12 baja cross all around. The power seems the same maybe a little more responsive than stock. Im running a little more weight from my first S. Over all, if you want a quiet exhaust that doesnt rob power, its worth the price tag in my book. I have about 1840 miles on this muffler, still doing its job. Id buy the SLP Super Quiet again without a flinch.
Yosh
yoshman762 is offline
post #3 of 7 Old November 1st, 2012, 03:23 PM
yoshman762's Avatar
I forgot to mention, its all stainless.
post #4 of 7 Old November 1st, 2012, 04:17 PM
Doolin2's Avatar
Check this out as an alternative.
I thought about getting one.
You will see one mounted to a RZR
Also look at the Decibel graph.
$145.99 on clearance.
Kolpin Stealth Exhaust 2.0
Doug
Doolin2 is offline
post #5 of 7 Old November 1st, 2012, 04:40 PM
Waistdeep's Avatar
I own the SLP as well, good fit, quiet and no noticeable loss of power. Would not like the additional inches hanging off the back that the Kolpin would take. Can just see that tree I back into tight in the woods bending that add on can.
Waistdeep is offline
post #6 of 7 Old November 2nd, 2012, 01:34 AM Thread Starter
so far,i realy like what i hear i dont like the kolpin one because it looks like an add on pc.....
post #7 of 7 Old November 2nd, 2012, 04:23 AM
Feedback Score: 5 reviews
whaffner's Avatar
i did this, less than 100$, and I like it. Not super quiet, but a big improvement.
http://www.rzrforums.net/projects-ho...r-install.html
whaffner is offline
QUIET muffler for the XP 900... Hopalong RZR XP 900 62 June 13th, 2015 08:17 PM
Need a QUIET muffler for my turbo!! Tejas58 Forced Induction 11 October 23rd, 2012 11:55 AM
Has anyone installed a quiet muffler on 570? KCrane RZR 570 Specific Discussion 2 July 10th, 2012 05:53 PM
Quiet muffler and metalic noise update... gjem1 General RZR Discussion 0 April 30th, 2011 05:17 PM
Quiet muffler? road742 General RZR Discussion 10 October 12th, 2009 08:21 AM
