Tell tale signs you need a new belt? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Tell tale signs you need a new belt? within the Engine and Drivetrain forums, part of the Technical category; I just opened up my clutch and everything look clean and the belt to me a novice looks brand new. I purchased the the rzr ...
Old October 10th, 2012, 08:03 PM   #1
KA_RaZzR_S's Avatar
First Name: Roy
My RZR: 2011 RZR S
Member #40923
View KA_RaZzR_S's Photo Gallery(0)
I just opened up my clutch and everything look clean and the belt to me a novice looks brand new. I purchased the the rzr with 1800 miles, 111 hours. It now has 3000 miles and 177 hours.
How do I tell if I need to replace the belt. I still runs fine, no issues just wanted to stay on top on maintenance. Thanks for your replies
Roy
KA_RaZzR_S is offline   Reply With Quote
Old October 10th, 2012, 08:12 PM   #2
Teamnipplesdeep's Avatar
First Name: Blake
Member #37593
View Teamnipplesdeep's Photo Gallery(0)
I noticed mine having a sluggish take off, its like it took more pedal to get going. Other than that I don't know, the sportsmans I had gave no signs they just shredded. I was in the same boat you're in about 2 months ago, just so happened to find a member wanting to get rid of a belt cheap so I threw it on and now use my original for a spare.
Teamnipplesdeep is offline   Reply With Quote
Old October 11th, 2012, 07:45 AM   #3
KA_RaZzR_S's Avatar
First Name: Roy
My RZR: 2011 RZR S
Member #40923
Re: Tell tale signs you need a new belt?
I'm sluggish on take off as well. I think it may be a throttle cable adjustment. I completed forgot to pull the gasket when I started it without the cover. shredded the gasket instantly.
Anyone know the best place and price in a replacement?
Also any tricks on getting the bottom two bolts back in?
Old October 11th, 2012, 07:59 AM   #4
darkstar_420's Avatar
My RZR: 2011 Screamin Yellow "S"
Member #29684
View darkstar_420's Photo Gallery(0)
lots of extensions LOL
darkstar_420 is offline   Reply With Quote
Old October 11th, 2012, 09:09 AM   #5
First Name: Blake
Member #37593
Yea that should bring her back to life. I know it did mine, I adjusted the throttle cable an put on the new belt at the same time too. The bottom bolts didn't give me much trouble, I guess I got lucky!
Old October 11th, 2012, 10:11 AM   #6
dmax61's Avatar
First Name: Tom
My RZR: 2010 RZR-S White
Member #10609
View dmax61's Photo Gallery(0)
I put a magnet in the socket that I use to put the bolts back in the cover.
This link might help.
http://www.rzrforums.net/general-rzr...elt-rzr-s.html
I keep the kit with the belt in the LnR cargo box.
dmax61 is offline   Reply With Quote
Old October 11th, 2012, 10:21 AM   #7
Jamminsatvs's Avatar
My RZR: 2013 900XP RZR
Member #28192
View Jamminsatvs's Photo Gallery(0)
Look at the sides of the belt. If you see hourglassing, glazing, cracks, seperations, then replace it. Since your in there already, I would install a new belt and use the old belt for a spare. Thx.
Jamminsatvs is offline   Reply With Quote
Old October 12th, 2012, 03:26 PM   #8
KA_RaZzR_S's Avatar
First Name: Roy
My RZR: 2011 RZR S
Member #40923
Thanks for the great replies. I've been reading BlackBarts treads on clutching. Great stuff. I probable should of started there.
Any way my belt that I may replace is number 3211118 which is for an 2009 700 xp. I may of been running the wrong belt. seems to of worked fine though.
Last edited by KA_RaZzR_S; October 12th, 2012 at 04:00 PM. Reason: corrected information
Old October 18th, 2012, 01:44 PM   #9
KA_RaZzR_S's Avatar
First Name: Roy
My RZR: 2011 RZR S
Member #40923
I just took the belt off its not the 311118 after all. Its the 311113 which is much tinner then the epi I am replacing it with the we265017
Old October 18th, 2012, 10:05 PM   #10
KA_RaZzR_S's Avatar
First Name: Roy
My RZR: 2011 RZR S
Member #40923
I just got back from breaking in the new EPI belt all went well and the rzr is running strong. I had zero issues with transmission grind as others have reported going to this belt. On another note I found this site for Dayco belts if anyone is interested.
Dayco Drive Belts for Polaris ATVs | ATV Parts | MFG Supply
Polaris Dayco XPX (Xtreme Torque) Belt. Fits 07 & newer models, replaces 3211113. For models with EBS.
Part #: XTX2239
OEM Replacement : Polaris 3211113, Polaris 3211116, Dayco XTX2239
Our Price: $89.99
Old October 19th, 2012, 07:43 AM   #11
Derek1's Avatar
First Name: Derek
My RZR: 2010 RG 4-Seater
Member #20650
View Derek1's Photo Gallery(0)
Part #: XTX2239
Our Price: $89.99
Thanks for sharing!
Sent from my Samsung Galaxy using TapaTalk
:rzrs: D-Man :rzrs:
Derek1 is offline   Reply With Quote
2012 polaris rzr 800 belt worn out?
how can you tell if a drive belt is going bad on a polaris ranger
how do i know if my rzr is an s
how to tell belt needs replacing polaris
how to tell if a belt is worn out on a utv
how to tell if a yamaha rhino belt is going bad?
how to tell if rzr belt is worn
how to tell if the belt is bad on utv
how to tell if you need a new belt on scooter
how to tell if your polaris rzr clutches are bad
sign of a bad scooter belt
signs of belt going bad on a 2000 sportsman 500
signs of worn belt on polaris ranger
what happens when the drive belt is to big on a polaris
will atv die if the belt is too stratched
My XP's tale of change K-fab RZR XP 900 231 September 21st, 2016 11:16 AM
Rugged Radios Signs Shannon Campbell! RuggedRadios Rugged Race Products 0 March 20th, 2012 05:10 PM
President Signs Law Creating Largest Wilderness Legacy in 15 Years The Lyin King Public Lands Advocacy 5 April 1st, 2009 09:14 AM
