Primary clutch removal help - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old September 5th, 2012, 08:31 PM Thread Starter
COSP-RZR's Avatar
First Name: Todd
My RZR: 2008 RZR 800
Member #35162
View COSP-RZR's Photo Gallery(0)
So using the clutch removal bolt i just got in the mail, I was able to pull off the main clutch portion however the flat plate on the engine side still remained. Maybe thats normal but i was expecting it to slide off with the main clutch portion.
Not sure how to get that plate off now. Do i need to unscrew the removal bolt....actually its proving difficult as it went on so hard in the first place.
Never really heard the pop sound i was expecting either if that matters.
Sent from my DROID BIONIC using Tapatalk 2
COSP-RZR is offline
post #2 of 6 Old September 6th, 2012, 06:03 AM
Banned
Wren's Avatar
My RZR: 2009 800
Member #42017
Feedback Score: 5 reviews
View Wren's Photo Gallery(1)
Re: Primary clutch removal help
Mine came off in one piece. Also, my clutch tool was not long enough so we had to stick an additional piece of metal in there to get it off. Maybe thats the issue?
Wren is offline
post #3 of 6 Old September 6th, 2012, 07:20 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Feedback Score: 26 reviews
That doesn't even seem possible. What all did you remove from the primary before screwing in the removal tool? All you are supposed to do is remove the bolt from the crank and screw in the tool until the clutch pops off of the taper. I have done this countless times and have never seen this happen.
MotoXXX is offline
post #4 of 6 Old September 6th, 2012, 07:35 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
The removal tool should not screw in hard. It sounds like you may have it cross threaded. I hope this is not the case!
MotoXXX is offline
post #5 of 6 Old September 6th, 2012, 08:21 AM Thread Starter
COSP-RZR's Avatar
First Name: Todd
Member #35162
I hand threaded the removal tool bolt in for the majority of the tread depth until it bottomed out. Then put a wrench on it to turn it 1/4 or 1/2 turn while waiting to hear the "pop" sound I'd read about.
Didn't hear that and fearing to crank it any tighter, I reached for the clutch to see if it was loose or ready to slide off and it just did. I think it may have rotated coming off too if that means anything.
Perhaps I unscrewed it from the shaft instead of letting it pull straight off?
Now just the bearing and the inside plate are on the shaft still.
COSP-RZR is offline
post #6 of 6 Old September 7th, 2012, 08:12 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
It appears that you unscrewed the spider. That has 200 lbs. of torque on it so it had to have been loose already. Put it back on and try it again. the whole clutch assembly should pop off of the taper on the crankshaft.
MotoXXX is offline
primary clutch colebrian69 Polaris RZR Parts For Sale 9 March 23rd, 2014 06:51 PM
primary clutch removal tool RzrGood Engine and Drivetrain 0 August 11th, 2012 05:53 PM
Primary clutch Ronzo Want to Buy 8 October 17th, 2011 09:11 PM
Primary clutch chill720 RZR-S Specific Discussion 11 July 11th, 2011 07:52 AM
I need a primary clutch or aftermarket clutch stickman89 Want to Buy 1 April 8th, 2011 10:47 AM
