Front wheel bearing replacement - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old June 26th, 2012, 07:38 PM Thread Starter
derekk's Avatar
Hey guys Im new here! Had a question about the 2009 RZR 800 le I just purchased. I noticed some play in the front left wheel bearing so decided to instal a new one. Everything went well I thought until I put it all back together and the wheel rubs on the tie rod end slightly for 4-5 inches every revolution??
I thought if the bearing was pressed in all the way and the axle tightened back up the hub would be centred?? The axle is not centred in the bearing after its all retorqued?? Does anyone have any ideas for me? pls help!!
thanks
Derek
derekk is offline
post #2 of 5 Old June 26th, 2012, 08:02 PM Thread Starter
derekk's Avatar
Re: Front wheel bearing replacement
I used the part #3514699 bearing.. Im reading there is a hub kit available also so mabey they gave me the wrong bearing, I think they gave me the bearing for the new hub....GRRRR
derekk is offline
post #3 of 5 Old June 28th, 2012, 07:19 PM
rusty richard's Avatar
If I recall there was a split in early 09 where they went to a thicker hub which used a larger sized ID bearing. If this is the case you have to buy the hub as a kit and it will come with the bearing. The hub should fit snug as it slide into the bearing if there is slop its wrong...good luck
rusty richard is offline
post #4 of 5 Old June 28th, 2012, 07:51 PM
BIGGJIM's Avatar
Sounds like you have the new style bearing with the old style hub. Pull it back apart and measure the Id of the bearing and the OD of the Hub.
BIGGJIM is offline
post #5 of 5 Old July 8th, 2012, 03:34 PM
Pirate's Avatar
I'm surprised the dealer had a bearing for you. You can't get the original bearing, you have to buy the new carrier and bearing. Its an upgrade.
There were problems with the axle slines being too long and the axle nut wouldn't pull the axle, carrier, and hub together tightly. Thus the wheel will rock top to bottom even with the axle nut properly torqued.
Check the Polaris Parts | Polaris Accessories | ATV Parts | Ranger Parts | RZR Parts | PolarisPartsDealer.com PolarisPartsDealer.com Athens, OH 888-284-8219 website and make sure the bearing you have is the correct one, if its the new one...which I'll bet it is, then you need a new style carrier. Buying it will make for less problems in the future.
Pirate
Pirate is offline
Front wheel bearing JohnTheTileGuy Forum Help, Questions and Info 4 September 2nd, 2014 11:24 AM
Front wheel bearing specs flyrccg General RZR Discussion 43 April 25th, 2013 07:19 PM
Front wheel bearing replacement? Orangemadness12 Engine and Drivetrain 1 March 13th, 2012 07:54 PM
Front Wheel Bearing jodyt Engine and Drivetrain 5 June 27th, 2010 07:51 AM
Anyone have A new front wheel bearing instock? crazywatson Want to Buy 3 August 31st, 2009 06:18 PM
