fastest way to get rear diff out of 09 rzrs - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old May 13th, 2012, 07:04 PM Thread Starter
Ohsoslow's Avatar
First Name: bruce
My RZR: 09 rzr 800
Member #39593
View Ohsoslow's Photo Gallery(0)
rear diff is locking up and going to change it tomorrow. any tips on the quickest ways to get it out? first time ever doing this. thanks
08 rzr 800
mcx turbo
long travel
hid's, pci radios
more to come
Ohsoslow is offline
post #2 of 12 Old May 13th, 2012, 07:16 PM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: fastest way to get rear diff out of 09 rzrs
follow the service manual.
Tuf-Skin is offline
post #3 of 12 Old May 13th, 2012, 07:23 PM
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
1 Drain fluid
2 Pull the axles
3 Remove mid exhaust pipe and silencer
4 Remove the engine mount bracket from the frame and diff by removing 3 bolt two on frame one through the rubber mount.
5 Pull the bolts that secure the diff to the transmission and the bolts in the bracket that secure the rear of the gear case to the transmission. Remove the bracket
6 Pull the 4 bolts out of the rubber mount and remove it.
7 Pull the gear case to the rear and disengage it from the transmission
8 Remove the vent line and lift the gear case up and on its side to remove it from the rzr
There are 8 easy steps
crazywatson is offline
post #4 of 12 Old May 13th, 2012, 07:27 PM Thread Starter
Ohsoslow's Avatar
First Name: bruce
My RZR: 09 rzr 800
Member #39593
Steve, again your the greatest! Dont sound as bad as it looks.
08 rzr 800
mcx turbo
long travel
hid's, pci radios
more to come
Ohsoslow is offline
post #5 of 12 Old May 13th, 2012, 07:37 PM
King of crash!
Member #787
its tight but steve has it down.
johnnycat8 is offline
post #6 of 12 Old May 22nd, 2016, 03:04 PM
Dahole's Avatar
Member #132257
View Dahole's Photo Gallery(0)
I have never understood why some folks feel the need to post such a useless comments other than to make themselves feel important. Steve your post was just what I was looking for. This one, well it was just noise and a wast of space. If I had it, don't you think I would already RTFM!
Dahole is offline
post #7 of 12 Old May 22nd, 2016, 03:08 PM
psheadl's Avatar
First Name: Paul
My RZR: 2014 XP1K (sold), 2016 XPT4
Member #31171
View psheadl's Photo Gallery(0)
Arizona Flag Re: fastest way to get rear diff out of 09 rzrs
Originally Posted by crazywatson View Post
1 Drain fluid
2 Pull the axles
Make sure you label each bolt because there is one each of every length and thread known to man!
psheadl is online now
post #8 of 12 Old May 22nd, 2016, 03:49 PM
Dahole's Avatar
Member #132257
Giving back.
Here is a pick of the bracket bolts color pattern
Dahole is offline
post #9 of 12 Old May 22nd, 2016, 03:59 PM
Dahole's Avatar
Member #132257
Top bracket. Note the green is common between both brackets.
A rartching 13mm box end is a big help as is a stubby ratchet.
Dahole is offline
post #10 of 12 Old May 23rd, 2016, 08:17 AM
ShakyDog's Avatar
My RZR: 2013 Jagged X & 2009 RZR S
Member #41826
View ShakyDog's Photo Gallery(0)
Here is the video on just this procedure:
http://www.rzrforums.net/rzr-800-spe...pullerguy.html
Steve
ShakyDog is offline
post #11 of 12 Old June 18th, 2016, 09:58 PM
Dahole's Avatar
Member #132257
Thanks for posting the link to the video! It helped me a great deal.
Dahole is offline
post #12 of 12 Old June 21st, 2016, 12:31 AM
Pirate's Avatar
First Name: Stuart
Member #3677
Just one note.
Before you take the axle nuts loose...just remove the upper and lower rear A-arm bolts that go through the bearing carrier...and then pull the whole thing as one piece. Axle, bearing carrier, brake rotor.
So much easier and less time consuming than taking the axle nut off and then taking each component out.
Pirate
Pirate is offline
RZR trans/rear diff/front diff for sale dpcustomfab Polaris RZR Parts For Sale 30 September 9th, 2014 01:14 PM
what is needed for 2010 rzrs rear Cage to fit 2011 rzrs wandemo1 RZR-S Specific Discussion 2 December 17th, 2011 05:27 AM
Who has the fastest RZR 4? bioaction2 RZR 4 Specific Discussion 7 June 10th, 2010 03:11 PM
Who has the fastest RZR in the U.S.? DanNorCal General RZR Discussion 82 April 23rd, 2010 05:50 PM
RZRS Rear bumper to protect the rear tail lights. Daryle Skaugstd Bumpers, Skid Plates and RZR Protection 0 October 16th, 2008 01:15 PM
