800rzr hydraulic roller lifter conversion?? - Polaris RZR Forum - RZR Forums.net
post #1 of 21 Old May 5th, 2012, 08:55 PM Thread Starter
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
thought I sen one shop offered hyd-roller lifters/cam for 800 rzr engines. or did I dream that?
has anyone tried or given thought, or use solid flat tappet set-up?
also does anyone know the diameter of the hyd lifters in the 800 engine?
RacerSam is offline
post #2 of 21 Old May 6th, 2012, 06:54 AM
dr.vacation's Avatar
First Name: elias
Member #2092
Feedback Score: 5 reviews
View dr.vacation's Photo Gallery(0)
Re: 800rzr hydraulic roller lifter conversion??
s&s has roller lifter cams for it,and richochet racing has converted them to solid's for more rpm's
dr.vacation is offline
post #3 of 21 Old May 6th, 2012, 06:56 AM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
S&S has roller lifters... I have a set myself...
swingarm1 is offline
post #4 of 21 Old May 6th, 2012, 07:25 AM Thread Starter
RacerSam's Avatar
Member #7858
is it a drop in deal? or must you have lifter bores in block machined larger?
SBC are .842" dia. Fords are .875" dia. would the stock popo be one of those two dia.? thanks
RacerSam is offline
post #5 of 21 Old May 6th, 2012, 07:41 AM
Sparky's Avatar
First Name: Dave
My RZR: Aerocharged 1110
Member #1007
View Sparky's Photo Gallery(0)
Sam --
The S&S Roller Cam Kit is a complete kit.
It is a drop-in kit ........... Although a slight bit of clearancing needs to be done on both the cylinder and base gasket. A dremmel is a good tool for this. The instructions explain this well.
The kit is guaranteed to run all day at 8500 RPM.
The kit is not designed to work with a stroker crank. Although with a bit of work it does work. I have 2 Turbo'd motors fitted this way.
You must run their roller lifters as they are machined for their lifter stablizing blocks. Also the correct length pushrods are included in their kit.
Have FUN .. ..
Sparky is offline
post #6 of 21 Old May 6th, 2012, 07:58 AM
First Name: elias
Member #2092
actually s&s guarantees it to 7400 rpm,but you can trust sparky's numbers
post #7 of 21 Old May 6th, 2012, 08:07 AM Thread Starter
RacerSam's Avatar
Member #7858
Originally Posted by Sparky View Post
Sam --
Have FUN .. ..
did you happen to measure the lifter dia? look a lot like SBC hyd lifters. anyways, why can you not run them with stroker cranks? does rods hit the camshaft??
RacerSam is offline
post #8 of 21 Old May 6th, 2012, 09:06 AM
Sparky's Avatar
First Name: Dave
Member #1007
The S&S Cam Kits were developed long before the stroker crank became reality.
S&S used the '08 engine as their platform and this engine is governed to 6385 RPM. They developed their kits to rev extend 1000 RPM beyond.
Enter the stroker crank and the different engine manangement systems. When I worked with one of their Product Engineers on the development of a Turbo grind for a bored/stroked engine -- They have now re-certified their existing kits to run up to 8500 RPM. I have this in writing - Hence my posting on this.
I suggest you don't try an re-invent the wheel and substitute a different roller lifter. You gain nothing. And - No ...... I don't know the measurements.
The S&S Roller Cam Kit as I mentioned is not designed to work with the stroker crank.
With a longer stroke -- Without a base shim under the twin cylinder raising the head ............... The pistons would hit the head.
To use their kit with a stroker crank -- One has some machining to perform on the balance shaft -- Base shim and new pushrods are needed.
All very easy corrections to make work.
Good Luck -- I'm back on the road for a couple of weeks.
Sparky is offline
post #9 of 21 Old May 6th, 2012, 09:16 AM Thread Starter
RacerSam's Avatar
Member #7858
no big deal to measure for pushrod length to get correct ones needed, I understand guess you clearance shim plate liek you would bottom stock cylinder for the lifter guides. but why would you have to machine on balance shaft with /S&S roller set-up and not with flat tappet? thanks
RacerSam is offline
post #10 of 21 Old May 6th, 2012, 10:28 AM
First Name: elias
Member #2092
you have to clearance for strocker crank ,not s&s cam
post #11 of 21 Old May 6th, 2012, 10:30 AM
First Name: elias
Member #2092
sparky did you get them to grind you a turbo cam? I tried and first they said yes, than no
post #12 of 21 Old May 6th, 2012, 07:49 PM
Sparky's Avatar
First Name: Dave
Member #1007
Hey Eli --
At the time - I had the rights to the Turbo cam ........... I agreed to the product development fee -- Ultimately they could not meet my schedule as they had quite a delay period until they could get a blank into production.
The Turbo grind never went into production as they had some internal issues.
Sparky is offline
post #13 of 21 Old May 6th, 2012, 07:52 PM
nathen53's Avatar
First Name: Nathen
My RZR: 800 Sunset orange with a SATV 6'' lift
Member #37507
View nathen53's Photo Gallery(0)
[/QUOTE]
SBC are .842" dia. Fords are .875" dia. would the stock popo be one of those two dia.? thanks[/QUOTE]
They look identical to a 350 chevy lifter
nathen53 is offline
post #14 of 21 Old May 7th, 2012, 08:47 AM Thread Starter
RacerSam's Avatar
Member #7858
They look identical to a 350 chevy lifter[/QUOTE]
what I was thinking too
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #15 of 21 Old May 7th, 2012, 10:06 AM
First Name: elias
Member #2092
sparky, had virtually same conversation with s&s,and web cams also,they wanted me to pay for blank,but got hung up when I wanted property rights to turbo grind
Hydraulic Bump Stops??? mulleyman RZR-S Specific Discussion 28 August 26th, 2014 04:15 PM
hydraulic lift GIFF-TURBO Projects and How-To 27 December 10th, 2012 11:47 AM
UTV hydraulic lift 66cummins Misc For Sale 17 April 6th, 2012 07:45 AM
Power Difference Between Old 800RZR Engiine and the H.O.800 billrzr General RZR Discussion 25 October 3rd, 2011 09:13 PM
2010 800rzr no power ? STOUTE Engine and Drivetrain 1 April 10th, 2011 08:12 PM
