Water pump weep hole leaking oil - Polaris RZR Forum - RZR Forums.net
This is a discussion on Water pump weep hole leaking oil within the Engine and Drivetrain forums, part of the Technical category; Im rebuilding the topend on my sons rzr 800 and noticed oil and water leaking from water pump weep hole. I know I have to ...
Old April 27th, 2012, 10:24 AM   #1
dsau's Avatar
First Name: donnie
My RZR: 2014 Rzr 1000
Member #10971
View dsau's Photo Gallery(0)
Im rebuilding the topend on my sons rzr 800 and noticed oil and water leaking from water pump weep hole. I know I have to change seals but do I need to pull the motor to do this,are can it be done with the motor in place.
dsau is offline   Reply With Quote
Old April 27th, 2012, 06:38 PM   #2
rusty richard's Avatar
My RZR: 09 RZR
Member #13596
View rusty richard's Photo Gallery(0)
Re: Water pump weep hole leaking oil
if it is just coolant leaking you do not need to pull the engine to replace the water pump seal but if oil is leaking there is an oil seal 5412455 on the inside of the magneto/engine cover' i thought i read on hear replacement requires engine removal. good luck
rusty richard is offline   Reply With Quote
Old April 27th, 2012, 06:57 PM   #3
dsau's Avatar
First Name: donnie
Member #10971
Thanks for the info, I was afraid of that.
Old April 27th, 2012, 07:04 PM   #4
My RZR: 09 RZR
Member #13596
You might verify with someone else on here but I tried taking off the stator outer cover and it would not come off while it was in the machine, also the part number was from an 09.
Old April 27th, 2012, 07:14 PM   #5
rzr s 38's Avatar
Member #14995
View rzr s 38's Photo Gallery(25)
Usa Re: Water pump weep hole leaking oil
I had the exact same thing happen to my 09 RZR S I had before I went xp. I took it to dealer since it was still under warranty and they fixed the problem and the engine did not have to come out.
rzr s 38 is offline   Reply With Quote
Old April 27th, 2012, 07:15 PM   #6
dsau's Avatar
First Name: donnie
Member #10971
It's an 09 also,so I guess I'll just have to pull the motor out.
Just a little more work but it's worth it.
Old April 27th, 2012, 07:18 PM   #7
dsau's Avatar
First Name: donnie
Member #10971
I guess I'll try to change it on the machine if I can't I'll just pull it out.
Old April 27th, 2012, 07:33 PM   #8
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
If it's oil for sure... You do have to pull the motor...
Old May 6th, 2012, 07:42 PM   #9
gdaddy's Avatar
First Name: GEORGE
My RZR: 2011 W,E,800
Member #37351
View gdaddy's Photo Gallery(0)
Wrench Re: Water pump weep hole leaking oil
The same thing happen to my 2011 800,I did not pull the engine,just take your time make sure the bore & shaft are free of any knicks, put a small amount of blue rtv on oil seal & press in flush with bore, it is always better to press in rather than beat in especially the waterpump seal, the seal should be centerd around the shaft when completed,if its not centerd it will leak,I also used a pressed in grease fitting to vent the weep hole with clear hose to keep from doing this again
gdaddy is offline   Reply With Quote
2011 rzr 800 rebuild water pump
2011 rzr 800 water pump leaks for weep hole
2014 rzr 800s weep hole leaking
oil coming out of weep hole on rzr
oil in water pump weep hole
ranger 800 water pump leaking
rzr 800 oil dripping out of weeping hole
rzr 800 oil in water
rzr 800 s leaking oil from water pump weep hole
rzr 800 water pump leaking
rzr 800 water pump weep hole
rzr water pump oil leak
rzr water pump weep hole leaking
weep hole continues to leak on my rzr 800
weep hole on water pump rzr 800
2012 rzr4 145 miles and oil is leaking from weep hole ? Barbarino Engine and Drivetrain 4 February 6th, 2012 05:02 PM
Weep Hole Leaking ALREADY? At 350 miles? cmcdaniel RZR 4 Specific Discussion 10 October 28th, 2010 01:05 PM
Water pump weep hole?? spinerep622 Engine and Drivetrain 4 August 16th, 2010 03:08 PM
Water Pump Leaking HivoltageRZR General RZR Discussion 27 May 29th, 2009 03:29 PM
Water Pump Weep Hole BEWARE HivoltageRZR General RZR Discussion 2 April 14th, 2009 10:22 PM
