2012 RZR another problem - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old April 3rd, 2012, 04:04 PM Thread Starter
Murphytom24's Avatar
Member #33834
View Murphytom24's Photo Gallery(0)
so every once in awhile my rzr will be hard to start, once it starts it sounds like its only running on one cylinder but its not, i hit the gas and it stalls, then when i try to start it again it whirls over like it has no compression eventually it will start again, after a long period of starting and stalling it will eventually start like nothing is wrong and runs like a champ, i bought it in dec 2012, 17 hours in the cam lobes wore off and polaris rebuilt the motor for no charge, it has about 180 miles on it now havent had any other problems, yes i took the junk champion plugs out and put NGK irdium plugs in it, yes the air filter is clean, no i havent had it in any water or mud, i just trail ride it, any ideas? thanks for your time
Murphytom24 is offline
post #2 of 9 Old April 3rd, 2012, 04:09 PM
King of crash!
Member #787
Re: 2012 RZR another problem
the oil pressure regulator pin likes to stick on the 800 get a new one or try to clean it up with some crockus cloth. not sure how to spell it.
johnnycat8 is offline
post #3 of 9 Old April 3rd, 2012, 04:44 PM Thread Starter
Member #33834
ok, where is that located, im not familiar with it.
post #4 of 9 Old April 3rd, 2012, 04:50 PM
redrzrrider's Avatar
First Name: Butch
My RZR: 2012 LE
Member #17841
There is a thread on this about 10 pages deep with the same problem, most on 2012 and 2011 models, when they changed the fuel pump. I think we have it narrowed down to a heat issue with the injectors or a possible ECU programing issue. I'm personally waiting for it to warm up so I can test it again. Also, many think it's ethenol fuel. Try premium and see if that helps.
I will locate the thread and bring it back to the top so watch for it in the active topics.
UPDATE....the thread is 18 pages deep. The topic is "hard to start when warm".
redrzrrider is offline
post #5 of 9 Old April 9th, 2012, 01:30 PM Thread Starter
Member #33834
So I located this valve where the dowl pin is located, took the cap off took the spring out but can't get the pin out, is it magnetic? Is it brass? Should I crank the motor over and hope the oil pressure just blows the dowl out? and once I get it out is there a "fix" or am I gonna have to do this every 150 miles, this blows, I bought a new one for a reason, thank you all for your input it's very helpful
post #6 of 9 Old April 9th, 2012, 01:47 PM
slider_buck's Avatar
My RZR: 2012 60" SATV Kit LE
Member #36277
View slider_buck's Photo Gallery(0)
read this topic. sounds exactly what you have going on.
http://www.rzrforums.net/general-rzr...when-warm.html
slider_buck is offline
post #7 of 9 Old April 9th, 2012, 03:58 PM Thread Starter
Member #33834
Mine only does it after it sits over night, I never have a problem when it's hot, once I get it started its fine all day, but every morning it seems to take about 20 mins to get it going
post #8 of 9 Old April 16th, 2012, 01:21 PM Thread Starter
Member #33834
Ok as a close for this thread, I located the oil pressure relief valve, pulled the dowl pin out and shined it like glass and put it back together, and now my RZR runs like a champ ALL the time. I can't believe something so small can cause such BIG problems and I still can't wrap my head around how it made it do what it did but it's fixed so I hope this thread will help others, and now I'm gonna make a new thread about another problem ha ha thanks everyone
post #9 of 9 Old April 18th, 2012, 08:31 PM
wes31123's Avatar
First Name: wes
Member #31293
View wes31123's Photo Gallery(0)
how did u get the dowl pin out
wes31123 is offline
DIRTFEST 2012 at Speedworld January 21, 2012 racespeedworld Local Rides and Events 3 January 20th, 2012 08:13 PM
clutch problem on 2012 razr le eps goat2789 Engine and Drivetrain 21 January 11th, 2012 02:09 PM
Major problem with our 2012 RZR XP 900 TigeDuner RZR XP 900 19 January 10th, 2012 05:32 PM
2012 intake problem adamr General RZR Discussion 5 January 6th, 2012 08:17 PM
2012 rzr randomly died - problem found!!!!! Orangemadness12 Engine and Drivetrain 4 October 30th, 2011 09:46 AM
