Old January 6th, 2008, 06:46 PM
Code 41 & running like sh%$#t
My RZR has 20 hours on it and it started running like it is on 1 cylinder. It is giving me code 41 air intake temp sensor error. Is this common could it be dirt or moisture?..
Remove advertisements
Sponsored links
Old January 6th, 2008, 06:57 PM
JSC JSC is offline
First Name: Jeff
My RZR: Red One
Re: Code 41 & running like sh%$#t
I have read a few cases of cleaning the sensor cures the problem. Use some of that Mass Airflow Sensor cleaner in the spray can.
WWW.IDAHOATV.NET
2008 RED RZR, build date 10/04/07
Old January 6th, 2008, 07:03 PM
Thanks, I'll give it a try, My dealer is about 40 miles away..and I don't like going there unless necessary!
Old January 6th, 2008, 07:12 PM
RGERBER's Avatar
First Name: RUSTY GERBER
My RZR: 2008 GENERATION 1
there are 2 for code 41
code 41 is
intake air sensor : short circuit to ground.
intake air sensor : open or short circuit to + SENSOR VOLTAGE ( ecu )
THATS WHAT THE BOOK SAY'S
Old January 6th, 2008, 07:53 PM
i read that also...not sure exactly what the cause could be though. bad sensor? dirty connection?..
Old January 6th, 2008, 08:02 PM
Have you opened up the the airbox to see if there is any dirt?
Jim
Old January 6th, 2008, 08:41 PM
Code Blue's Avatar
My RZR: two red ones
Jim
Boy oh boy, my thoughts exactly.. Pull the filter and use a flash light to check your throttle body..
Old January 7th, 2008, 09:56 AM
guy48065's Avatar
I think you get a code 41 anytime the temp sensor in the T-bap sensor goes out of range. That could be caused by a short, an open or just oil or dirt contamination. Early SP800's had a problem with the connector loosening--I hope we're not revisiting that old problem. Clean the T-bap and the connection & apply dielectric grease to the inside of the connector.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
Old January 7th, 2008, 12:16 PM
I tried everything!!! I guess it's back to the dealer... The sensor was clean. I checked the wiring and nothing is broken...I did find out the plastic skid plate is useless. Mine was broken in a few places. Thanks for all your input guys.
  #10 (permalink)
Old January 7th, 2008, 12:25 PM
mtnmike's Avatar
hey MIKE if you speed up you can beat fate
  #11 (permalink)
Old January 7th, 2008, 08:10 PM
my 05 sportsman has the same sensor..I'll plug it in tomorrow and see it the sensor is bad.
  #12 (permalink)
Old January 7th, 2008, 08:20 PM
RGERBER's Avatar
I would like to know how that turns out.
  #13 (permalink)
Old January 7th, 2008, 09:33 PM
mtnmike's Avatar
I bet you would sounds kinda like yours good luck to you both.and please let all of us know how it works out.
  #14 (permalink)
Old January 8th, 2008, 08:14 PM
Well...I took it to the dealer...it turns out that 3 wires were broken in the loom that goes from front to back. They were pinched between the plastic body and frame. I did check them before I took it but they were not visually broken. Lesson here...get a Good aluminum skid plate BEFORE rock crawling!
  #15 (permalink)
Old January 8th, 2008, 08:17 PM
Well...I took it to the dealer...it turns out that 3 wires were broken in the loom that goes from front to back. They were pinched between the plastic body and frame. ( the frame cross member was bent up a bit)I did check them before I took it but they were not visually broken. Lesson here...get a Good aluminum skid plate BEFORE rock crawling!
Sponsored links
