Coolant Loss - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old March 15th, 2012, 04:41 PM Thread Starter
Nunzio's Avatar
Coolant Loss
Just wondering if anyone else has this issue: I'm loosing a small amount of coolant about every tankful of fuel, and wondering if it's "normal" or anyone else has this issue? The RZR is an '09 Limited 50-inch, no engine mods. We're the second owner and it's done it since we got it. Here's the scenario: radiator is full so fill the plastic overflow bottle to between the "min" and "max" lines. Take a ride, about 15-20 minutes out running around 35-40 mph on decent gravel roads, there's an odor of coolant. The fan kicks on occcasionally and runs briefly, there's no indication it's overheated. Check all the lines, radiator, etc, etc and unable to locate a leak, no coolant in the oil either. After about 200 miles the overflow bottle is empty, and she doesn't loose any more coolant or produce the odor. So what's up??
Nunzio is offline
post #2 of 11 Old March 15th, 2012, 05:15 PM
I am still 16 in my head!
Feedback Score: 29 reviews
Kandgo's Avatar
Re: Coolant Loss
I would say you have leak. If you cannot hunt it down your self, you may have to go the Fluorescent Dye Leak way of finding it. Find a local Radiator Shop and they should be able to find it, put in some Dye and you go run it, take it back, they Blacklight it and find the leak, or you can buy a good Blacklight Bulb and do it yourself.
And it sounds like you have leak from inbetween the Overflow Tank and the Motor, probablly down along the bottom.
Kandgo is offline
post #3 of 11 Old March 16th, 2012, 05:23 AM
mudxxed's Avatar
Re: Coolant Loss
Mine does the same thing, and I know of a few more rzrs do the same thing. I just leave my overflow bottle empty and Ive never had a problem. Im thinking that the coolant smell and loss of coolant is its coming out of the overflow tube off your radiator. Never had an overheating problem with the coolant only in the radiator.
2008 RZR 800
6in SATV LIFT, HL Springs
31 Laws
HIDS
LTE DUALS
Bazooka TUBBIES Speakers
mudxxed is offline
post #4 of 11 Old March 16th, 2012, 07:51 AM Thread Starter
Nunzio's Avatar
Re: Coolant Loss
Same here, never had an issue, just kind of bugs me. I've wondered if it's escaping from that tiny little vent hole in the bottle cap, but I can never find a trace of coolant anywhere. Oh well, at least it not's leaking from my Jaeger flask.
Nunzio is offline
post #5 of 11 Old March 16th, 2012, 08:16 AM
dajo's Avatar
Re: Coolant Loss
My 2010 RZR4 can smell antifreeze most of the time. No overheating.
dajo is offline
post #6 of 11 Old March 16th, 2012, 09:05 AM
wolfwgn's Avatar
Re: Coolant Loss
Mine was doing the same thing pulled skid plates and the rubber hose connections from the steel tubes underneath were not tight also had some antifreeze on the connections never saw a drip under the rzr but there was some on the top side of the skids
jeff
wolfwgn is offline
post #7 of 11 Old March 16th, 2012, 09:11 AM
BarRZR's Avatar
Re: Coolant Loss
jeff
This sounds like the most probable cause; if it's slowly leaking onto the skid-plate/s, it would be awfully hard to spot from the outside, IMO.........
Cheers
BarRZR is offline
post #8 of 11 Old March 16th, 2012, 09:50 AM
jerrzr's Avatar
Re: Coolant Loss
Check the weep hole on the water pump..just a few drops to stream down out of it and you can smell it pretty good...and when engine is warmed up it evaporates fast..A "ghost" leak.
jerrzr is offline
post #9 of 11 Old March 16th, 2012, 10:28 AM
mudxxed's Avatar
Re: Coolant Loss
My weep hole is sealed up, yes do check the clamps underneath the rzr where it goes from hardline to hose. Mine were good to go. The pinhole on my overflow bottle has a cotton ball in the cap to prevent gritty water from getting in when Im dash deep in water
2008 RZR 800
31 Laws
HIDS
LTE DUALS
mudxxed is offline
post #10 of 11 Old March 16th, 2012, 12:38 PM Thread Starter
Nunzio's Avatar
Re: Coolant Loss
Hmmm, weep hole. I truly hadn't thought of that. Where is it located?
Nunzio is offline
post #11 of 11 Old March 16th, 2012, 02:23 PM
Kandgo's Avatar
Re: Coolant Loss
None of our Rzrs lose Antifreeze. You have a leak somewhere. Pull the skids, weephole. Find the leak.
Kandgo is offline
loss of HP with mods ? gus700 RZR-S Specific Discussion 1 July 23rd, 2011 11:16 AM
Bog - loss of power woodguy General RZR Discussion 1 August 25th, 2010 04:46 AM
power loss Lardogg RZR-S Specific Discussion 10 March 30th, 2010 08:03 AM
loss of top end? Vince General RZR Discussion 9 October 24th, 2008 07:36 AM
Help Loss RPM's giddyupgo Engine and Drivetrain 1 May 21st, 2008 07:31 PM
