2008 rzr torque specs - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old February 29th, 2012, 05:34 PM Thread Starter
racincowboy's Avatar
Member #36481
View racincowboy's Photo Gallery(0)
can someone give me the torque specs on a 2008 rzr head bolts. And does the rocker arms need torqued also or do i just run them down tight?
also what kind of oil are people using? thanks
racincowboy is offline
post #2 of 7 Old March 3rd, 2012, 07:35 PM Thread Starter
Member #36481
Re: 2008 rzr torque specs
well im guessing nobody on here knows how much to torque a head down!!
post #3 of 7 Old March 3rd, 2012, 08:01 PM
Love Thy Mudder!
Fishie's Avatar
First Name: Scotty
My RZR: 800
Member #9395
View Fishie's Photo Gallery(42)
35 ft/lb on cylinder head cover
torque sequence is as follows
3 1 5
6 2 4
rocker cover is 84 in/lb
7 5
3 2
1 4 6
rocker arm is 22 ft/lbs
Fishie is offline
post #4 of 7 Old March 3rd, 2012, 08:02 PM
Love Thy Mudder!
Fishie's Avatar
First Name: Scotty
My RZR: 800
Member #9395
torque head to specs, let gasket set for 1/2 hour and give another 1/4 turn in same sequence
Fishie is offline
post #5 of 7 Old March 3rd, 2012, 08:56 PM
King of crash!
Member #787
make sure their is no coolant in headbolt holes, lightly oil threads and both sides of headbolt washers
johnnycat8 is offline
post #6 of 7 Old March 5th, 2012, 05:49 PM Thread Starter
Member #36481
thank you for the info guys. do yall know if the head bolts are a "stretch" style bolt and should i replace them.
Fishie are you calling the valve cover a "rocker cover"?
post #7 of 7 Old March 5th, 2012, 06:40 PM
Love Thy Mudder!
Fishie's Avatar
First Name: Scotty
My RZR: 800
Member #9395
yes I am
hope the illustation for the sequence makes sense to you too.....one side has two bolts (7+5) and the other side has three bolts (1,4,+6)
3+2 are the end bolts.
Fishie is offline
Help torque specs FDrzrGuy General RZR Discussion 1 January 31st, 2012 05:59 PM
front a-arm torque specs? domestictuner RZR XP 900 1 June 24th, 2011 05:45 AM
Lug nut torque specs? safehaven Wheels and Tires 2 February 16th, 2011 06:00 PM
rear arm torque specs evilking General RZR Discussion 3 July 15th, 2010 02:17 PM
torque specs upinsmoke General RZR Discussion 6 August 9th, 2008 04:19 AM
