hey guys need some advive im having a problem after snorkeling my 08 rzr im getting my best speed at 3/4 throttle andf actually slow down if i have it floored i restricted the 2 1/2 pvc with a black sock before i put tne k/n on it and it got better any suggestions ???
I think the problem is too much intake pipe length. Your not getting a venturi effect in the throttle body because of your mods. While the need for a snorkel is obvious if running in water or mud it is a poor design as far as performance goes. Is it possible to have a snorkel system that allows the upper intake tube be removed when not needed?
This problem is solved by cutting a 2.5 inch hole in the bed and cutting the stock snorkel from the airbox and adding a 2 inch abs hose,a 45 degree 2 inch elbow and about 5 inches of abs pipe topped with a 90 degree 2 inch elbow.i added a k&n breather (1.5 inch diam) for extra filtration.works great and no loss of top speed.if anything feels like more power,maybe because the extra cool air going to the airbox.
NOTICE THE HOLES IN THE BED ARE BARELY NOTICEABLE,BECAUSE OF THE POSITION ON THE EDGE.LOOKS CLEAN.I ADDED 2 MORE,ONE FOR THE CVT INTAKE AND ANOTHER ONE FOR THE CVT EXHAUST.
