rzr-s ecu
This is a discussion on rzr-s ecu within the Engine and Drivetrain forums, part of the Technical category; I can't find anything on search. Has anyone tried an ecu box for the rzr-s on a standard rzr? Figured if you add the s ...
Old December 13th, 2008, 06:16 PM
jasmoore3's Avatar
Member #4004
View jasmoore3's Photo Gallery(0)
rzr-s ecu
I can't find anything on search. Has anyone tried an ecu box for the rzr-s on a standard rzr? Figured if you add the s cam/hc pistons and exhaust then maybe you could also benefit from using the same ecu unit?
Old December 16th, 2008, 03:02 PM
razorkiller50's Avatar
Member #5025
View razorkiller50's Photo Gallery(0)
Re: rzr-s ecu
I do know for sure they have different part numbers.
Old December 16th, 2008, 05:01 PM
BlackBart's Avatar
Feedback Score: 4 reviews
First Name: Bart
My RZR: Regular RZR 08
Member #797
View BlackBart's Photo Gallery(0)
Re: rzr-s ecu
FYI, I ask tech at Polaris dealership outside Nashville,TN. He told me the part # for the RZR,RZRs & Sportman 800 WERE the SAME, B U T
the dealership flashes the ECU for the respective unit, if you ordered one. Post any replys.
Old January 17th, 2009, 10:40 AM
jasmoore3's Avatar
Member #4004
Re: rzr-s ecu
ttt----still wondering
Old January 17th, 2009, 12:31 PM
Member #5025
Re: rzr-s ecu
FYI Mine came straight from polaris as a hook me up for our race team and the s box has a little different mapping and 25% more fuel added throughout the whole rpm range and mine is programmed with a 9000 rpm rev limit. ( which i will never hit )
PART NUMBERS:
PLAIN - F00HM0086
POLARIS# - 4012227
S - F00KM00043
POLARIS# - 4011599
Old January 18th, 2009, 08:29 PM
Shelby-Gt-500's Avatar
Member #3370
View Shelby-Gt-500's Photo Gallery(0)
Re: rzr-s ecu
PART NUMBERS:
PLAIN - F00HM0086
POLARIS# - 4012227
S - F00KM00043
POLARIS# - 4011599
9000 rev limit?
Old January 19th, 2009, 08:31 AM
Member #5025
Re: rzr-s ecu
Yep you have to pin the crank for it to hold but on the nitrous in the mud pit it will turn about 8600 with 28" tires and a Hotseat clutch kit.
4011599 ecu
4011599 polaris
4012227 polaris
95-163260-01
anyone tried a rzr ecu on a sportsman
does a 4012227 ecu fit in 2008 ranger
ecu box rzr s
ecu gunman
ecu: 4011599 polaris rzr
polaris 4011599
polaris 4012227
polaris part 4012227
polaris part# 4012227
polaris rzr ecu
programmed polaris 4011599
rzr ecu pin
rzr s ecu box
rzr s ecu in a rzr
where is rzr ecu
will a polaris rzr s ecu fit a standard rzr
