How to change transmission fluid - Polaris RZR Forum - RZR Forums.net
This is a discussion on How to change transmission fluid within the Engine and Drivetrain forums, part of the Technical category; Well I decided since its been a dry winter with no snow I'd sell my sled and concentrate on getting my RZR in tip top ...
Old January 30th, 2012, 11:06 AM   #1
shanksyamaha's Avatar
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
View shanksyamaha's Photo Gallery(0)
Well I decided since its been a dry winter with no snow I'd sell my sled and concentrate on getting my RZR in tip top shape for spring... The last thing I need to do is change the transmission fluid. I have the correct fluid but I'm not easily finding the drain plugs. From what I understand there are two different compartments in the transmission that need to be changed. One the main gear box and the other the transaxle??? Anyway. I had no issue changing the front and rear diff fluids but I have full aluminum skids on the bottom... Will I have to pull them to get to the tranny drain plugs and am I looking for two plugs??? I looked it up in the manual but its kinda hard to follow.. and dosn't make it easy to find. The Transmission is labled with the fill and level plugs but I didn't find the drain plugs. Im working all day today but tomorrow I plan to get this done..
Thanks in advance for the help guys.... this site rocks...
2009 RZR-s 800: full skids front to back, bumper, 3500lbs winch, tunes, rock sliders, FMF pipe, clutch kit
2006 Yamaha Apex RTX with G-Force supercharger. 180hp trail sled that loves the frozen lakes..
2004 Polaris XC 700 SP with some moderate tweeks, wifes sled that outruns most of my buddies sleds, love it...
shanksyamaha is offline   Reply With Quote
Old January 30th, 2012, 11:16 AM   #2
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: How to change transmission fluid
The drain plugs are on the very bottom. There are holes in the skid plate to access them.
Quote: Originally Posted by Tuf-Skin View Post
Read the service manual for complete instructions...
Old January 30th, 2012, 12:20 PM   #3
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
I looked closely. There arn't any holes in my aluminum skids in that area.. I think I must just have to remove them to access these drain plugs.... Maybe I'll cut a couple holes in the skid so next time I can do it without dropping the skids...
Old January 30th, 2012, 12:33 PM   #4
Tuf-Skin's Avatar
Member #2228
oh, if it isn't the stock skid then yes, you might have to take them off.
Old January 31st, 2012, 08:49 PM   #5
<<< My personal RZR jack
gjem1's Avatar
My RZR: 2010 Walker Evans
Member #18085
View gjem1's Photo Gallery(16) Send a message via MSN to gjem1
you better remove the skid plate, even stock one, I stripped the tranfer case drain plug because the hole in the stock skid plate is very small and could not see or feel that i was going cross threads... I fix it temporary and it is holding but will have to go with heli-coil on the next oil change.
BTW, do not over tight the tranny and transfer case drain plugs! they have a small o-ring and shoud be just tight and torque very lightly. the o-ring do the sealing job
gjem1 is offline   Reply With Quote
Old February 1st, 2012, 02:53 AM   #6
Feedback Score: 4 reviews
milzo's Avatar
First Name: Jason
My RZR: 2011 XP900
Member #30216
View milzo's Photo Gallery(1)
I just changed all my fluids monday. Its the first time i've done it myself. Remove the skid, lay underneath the rzr and compare the picture in the service manual to your tranny & you will find both drain plugs on the tranny & just follow the fluid change directions in the manual. Be very careful to torque the drain plugs and fill window plug to the correct spec they will strip easily.
For refill of the fluids you'll want to have a funnel with flexible hose on the end cause the fill holes are in awkward location.
milzo is offline   Reply With Quote
Old February 1st, 2012, 05:21 AM   #7
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
I got her done last night.. I found it weird that the torq specs on the drain plugs and level plug were so light but now I see why, glad I read the torq specs or Im sure I would have over torqed them, Im good at that... anyway I did break one of the large fill plugs, I had a torq wrench on it and didn't even get it to spec and the top broke right off.. so now I have two pieces, one is the top and the other is the threads so the threads don't bottom out on anything, they will just screw right into the tranny.... I ordered a new one and epoxyed this one back together so I can go for a little ride today, it was weird how it broke like that, looked like it had alot of air bubbles in the casting, maybe casting flaws from the factory.... got her done anyway..... thangs guys....
Old February 5th, 2012, 01:37 PM   #8
Pirate's Avatar
First Name: Stuart
Member #3677
Lemme remember, oh yeah, on Harleys the torque for 1/4 x 20 bolts is 150 ft-lbs...yup, busted more than my share trying to keep them from coming loose....LOL
Pirate
Pirate is offline   Reply With Quote
Old February 5th, 2012, 08:28 PM   #9
rusty richard's Avatar
My RZR: 09 RZR
Member #13596
View rusty richard's Photo Gallery(0)
Ya know not tryin to be a smart a$$ but sum times you have to be smarter than the dang manual and use a little common sense when it comes to torque specs and drain plugs, I have read more than one thread where someone has broken, striped, rounded or otherwise destroyed a drain or fill plug by trying to follow the specs stated in the manual. My advise is use common sense when tightening these fasteners, SNUG goes a long ways...just sayin...
rusty richard is offline   Reply With Quote
Old February 12th, 2012, 06:32 PM   #10
CY6
CY6's Avatar
First Name: Antony
My RZR: 2011 800 SLE
Member #32566
View CY6's Photo Gallery(0)
I just changed my fluids and the transfer case used about double the amount of oil as specs indicated. Is this normal, or am I missing something????
Thanks,
CY6 is offline   Reply With Quote
Old February 12th, 2012, 06:43 PM   #11
Tuf-Skin's Avatar
Member #2228
Thanks,
did you fill it up to the level plug or the fill hole?
Old February 12th, 2012, 06:47 PM   #12
CY6
CY6's Avatar
First Name: Antony
Member #32566
Thanks,
Level plug I thought, but starting to doubt it now. I Need to take a pic and post with this to confirm.
Old February 12th, 2012, 07:41 PM   #13
CY6
CY6's Avatar
First Name: Antony
Member #32566
Thanks,
I was putting oil in the fill plug........ Lesson learned, and it was still less expensive than having a dealer do it!!
Thanks for the input!
Old February 13th, 2012, 03:18 AM   #14
Pirate's Avatar
First Name: Stuart
Member #3677
Well no one ever learned anything without trying and without making mistakes.
Next time it will be a snap!!
Pirate
2012 polaris ranger 800xp transmisdion fluid change
2012 rzr 900 transmission oil
2013 polaris rzr 800 transmission oil change without removing skid plate
2016 polaris 900 rzr tranny fluid change
changing transmission fluid on rzr 1000
checking transmission oil in rzr xp
how do i change rear fluild on 2016 polaris rzr 1000s
how to change transmission fluid on 08 polaris razor
how to replace transmission flyid rzr 800
oil and transmission fluid in 1000 rzr
polaris ranger fluid change
ranger 800xp transmission fluid
rzr 1000 transmission how oil change
rzr 1000 transmission oil change
transmission fill 2013 rzr 900ho
Transmission fluid change Ojmadness Engine and Drivetrain 3 November 21st, 2011 06:56 AM
transmission fluid whaffner Engine and Drivetrain 10 September 5th, 2011 10:11 PM
changing transmission fluid? fltjnky16 General RZR Discussion 5 February 26th, 2011 09:23 PM
transmission fluid Paulson Engine and Drivetrain 6 December 5th, 2010 01:15 PM
Transmission Fluid GIFF-TURBO Engine and Drivetrain 7 November 28th, 2009 05:32 AM
