One Wheel Drive - Polaris RZR Forum - RZR Forums.net
One Wheel Drive
This is a discussion on One Wheel Drive within the Engine and Drivetrain forums, part of the Technical category; When in AWD, climbing a nasty hill, I broke my right rear axle. Right away the front wheels stopped engaging. In AWD when I hit ...
Old January 5th, 2012, 03:04 PM   #1
crazycooter's Avatar
First Name: Joe
My RZR: 2008 50"
Member #29227
View crazycooter's Photo Gallery(0)
Rzr Icon One Wheel Drive
In AWD when I hit the gas only the left rear would spin. I had to get out of the woods in one wheel drive.
I assumed I also broke Sprague in front axle but now I wonder if maybe If I replace the broken rear axle the front end will start working again?
I read the AWD system will not allow the front wheels the spin faster that the rear.
Maybe with no load on the broken axle side it, the AWD was not allowing power to the front end?
Any thoughts?
crazycooter is offline   Reply With Quote
Old January 5th, 2012, 03:08 PM   #2
Feedback Score: 14 reviews
Devious Powersports's Avatar
My RZR: XP 900 4
Member #33656
View Devious Powersports's Photo Gallery(0)
I think your correct.
Devious Powersports is online now   Reply With Quote
Old January 5th, 2012, 04:49 PM   #3
First Name: Joe
My RZR: 2008 50"
Member #29227
Re: One Wheel Drive
bump
Old January 5th, 2012, 09:53 PM   #4
First Name: Joe
My RZR: 2008 50"
Member #29227
Re: One Wheel Drive
Thanks for the reply Leach.
Can anybody else chime in before I tear the front diff apart??
Old January 5th, 2012, 09:58 PM   #5
darterdad's Avatar
First Name: Claud RZR forum Rocks
My RZR: 2012 900XP LE The White One
Member #33002
View darterdad's Photo Gallery(0)
Re: One Wheel Drive
I would fix the rear & try it
darterdad is offline   Reply With Quote
Old January 5th, 2012, 10:02 PM   #6
First Name: Joe
My RZR: 2008 50"
Member #29227
Re: One Wheel Drive
I am going to try it as soon as my axle shows up. Just not sure if it would be a waste of time to tear apart the front diff in the mean time.
Old January 6th, 2012, 10:25 AM   #7
6skinner
Orangemadness12's Avatar
First Name: Dave
My RZR: 2012 rzr s orange madness
Member #30843
View Orangemadness12's Photo Gallery(0)
Re: One Wheel Drive
Thought pattern makes sense. If you take it apart there will be nothing wrong, if you don't take it apart there will be something wrong in there. Kind of a long shot but you don't have a friend with an axle you can borrow do you?
14 scrambler 1000, 28 mega mayhems on 14" sixr wheels, qsc clutched on hardest setting
14 Ace, 26" pro comp extremes on 14" msa m17 elixer wheels, total blast!
And a 600rwhp 03 powerstroke on 37" mud grapplers to haul it all
13 fx4 a/p on 35"grapplers, 6.2l
Orangemadness12 is offline   Reply With Quote
Old January 6th, 2012, 10:42 AM   #8
First Name: Joe
My RZR: 2008 50"
Member #29227
Re: One Wheel Drive
Well, I decided to take my "heavy duty" 4340 chromoly axle to the local race car shop for welding. That way I will have it back later today and have an answer on the front end. I will order some better axels in the mean time and carry a spare when I am heading way out in the bush.
I will post the outcome.
Old January 6th, 2012, 11:09 AM   #9
Feedback Score: 5 reviews
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Re: One Wheel Drive
My guess, and it's just is a guess, is that with the broken axle you've always got something moving on that side and therefore the AWD can't determine that you're actually "slipping". It's this slip that causes the front diff to engage.
Hope this helps...
Chris Dierkens
teamhog is offline   Reply With Quote
Old January 6th, 2012, 11:43 AM   #10
First Name: Joe
My RZR: 2008 50"
Member #29227
Re: One Wheel Drive
Thanks, thats what i thought too. I know AWD has its advantages but a disadvantage if this is true, would be if you break an axle you go from four possible driven wheels to one!
I was in quite a nasty spot on a hill and had a few hundred yards after the hill to get back on flat ground. If I did not have a winch and another quad there, it would have been a long walk.
Old January 6th, 2012, 11:55 AM   #11
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Re: One Wheel Drive
There's a post on here somewhere that has a link to the company that makes the front diff. I've looked through their site, but have yet to find the info I'm looking for.
So, I may end up calling them to find out if there's another way to get what a lot of us are looking for. I'm pretty certain they can either adapt the stock item or make a replacement that will do what we want.
Chris Dierkens
Old January 6th, 2012, 12:59 PM   #12
rusty richard's Avatar
My RZR: 09 RZR
Member #13596
View rusty richard's Photo Gallery(0)
Re: One Wheel Drive
Joe couple things to look at...first does the awd light come on in the speedo if not could have something electrical going on, next is the front drive shaft turning when the machine is moving if it is moving odds are your cage is destroyed. My guess is when the rear axle broke the jolt to the drive train busted your cage. You can read exactly how the awd works in the "ultimate front diff" thread but in a nut shell the awd feature is mechanical(with the exception of a electic magnet) not sensory(in other words there is not a sensor that engages the system). Good luck on the repairs.
rusty richard is offline   Reply With Quote
2012 polaris ranger drives on one wheel only
does polaris ranger have 1 weel drive
does polaris ranger have 1 wheel drive
is there a 1 wheel drive polaris ranger
one wheel drive
one wheel drive went out on 2011 polaris ranger?
polaris one wheel drive
polaris ranger 1 wheel or two wheel drive
polaris ranger one wheel drive
polaris rzr 1 wheel drive conversion
polaris rzr one wheel drive
polaris scrambler only spinning one rear tire
polaris single wheel drive
rzr only one rear tire working
utv with one wheel drive
4 wheel drive engages in 2 wheel drive rzrhall General RZR Discussion 6 February 5th, 2011 08:21 PM
3 Wheel Drive tjmotors Engine and Drivetrain 37 October 24th, 2010 06:59 AM
four wheel drive Herbie Engine and Drivetrain 0 November 10th, 2009 01:55 AM
Four Wheel Drive Off & On RZRnewguy Lighting, Stereo and Electrical 0 October 19th, 2009 06:10 PM
three wheel drive??? drtguy13 Forum Help, Questions and Info 4 September 6th, 2009 02:37 PM
