Cross Ref for Oil Filter? - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 22 Old January 3rd, 2012, 08:37 PM Thread Starter
Nailhead's Avatar
My RZR: RZR 800
Member #30404
View Nailhead's Photo Gallery(0)
Re: Cross Ref for Oil Filter?
Originally Posted by Roky View Post
Somthing I would like to know is there any that meet the Polaris 10 micron rating that they specify in there parts break down? I know for a fact that NAPA, Wix and K & N are only 20 to 21 micron. Is it worth the risk to use a cheaper filter? I know from experience that a cheaper filter is generaly cheaper made and all you have to do is cut one open to see.
A family friend by the name of Bob sold his old Alfa sedan to someone who was going to use the engine in a vintage racer, and when the new owner pulled the head at 100K miles, the original factory hone marks could still be seen on the cylinder walls. Bob attributed this amazing lack of wear in part to his use of Baldwin filters.
That sold me on them.
Some aftermarket filters I would hesitate to use, but the ones I've seen (& some cases installed) on industrial equipment, equipment that has to be reliable & durable I have no problem buying in preference to the manufacturers own filter. These include Baldwin & Donaldson.
Nailhead is offline
post #17 of 22 Old January 3rd, 2012, 08:43 PM Thread Starter
Nailhead's Avatar
My RZR: RZR 800
Member #30404
Originally Posted by turkeyhunter View Post
Here you go
NAPA 1356
Purolator pl14610
Mobile M1-110
Bosch 3323
Walmart Supertech ST7317
Fram XG 7317 or tg7317
Wix 51356
K&N hp1010....Expensive!
Hope you have time to read them.
Thanks for the additions.
Time enough to research, time enough to read.
Nailhead is offline
post #18 of 22 Old January 3rd, 2012, 09:15 PM Thread Starter
Nailhead's Avatar
My RZR: RZR 800
Member #30404
[quote=guy48065;829986]
Thanks, but I did a search of the type I prefer.
I put this question out there primarily for the information sought, secondarily for a little interaction with those who share an interest of mine.
If all I wanted to do was find information, I'd have Googled it, harvested what I needed, & been on my way.
Kind of like I did with the filter numbers I posted above.
Nailhead is offline
post #19 of 22 Old January 3rd, 2012, 09:26 PM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Feedback Score: 26 reviews
Why not just use my sticky thread for finding aftermarket lubricants?.....
http://www.rzrforums.net/engine-driv...lt-part-s.html
FYI.....Different filter manufacturers use different particle size ratings to figure their filtering capabilites so unless you understand it all it means NOTHING to the average joe.
Below is from perfromanceoiltechnology.com.....
Beta Ratings
The Beta rating of an oil filter is a measure of the particle capture percentage in a special test designed and specified by the Society of Automotive Engineers (SAE) and is referred to as test SAE J1858. The test measures the volume of particles that pass through a filter in a single pass vs. the total volume of particles introduced into the filtration system prior to entering the oil filter.
The percent efficiency of a filter with a specific beta rating is determined by subtracting one from the Beta rating, then divide the result by the actual Beta rating and multiplying the result of the division by 100. The final value determines exactly what percentage efficient a certain oil filter is at removing a specific size of contaminant.
Beta rating tests are the best way to accurately compare oil filter performance due to the fact that the test measures the specific oil filter efficiencies at specific particle sizes. Comparing filter micron ratings without knowing the efficiency at a specific micron particle size is meaningless.
MotoXXX is offline
post #20 of 22 Old January 3rd, 2012, 10:46 PM Thread Starter
Nailhead's Avatar
My RZR: RZR 800
Member #30404
Originally Posted by MotoXXX View Post
Why not just use my sticky thread for finding aftermarket lubricants?......
To be honest, I didn't see it before I posted up.
Thanks, though.
Nailhead is offline
post #21 of 22 Old January 8th, 2012, 12:23 PM
RZR Fast's Avatar
Member #21341
View RZR Fast's Photo Gallery(0)
Nailhead had mentioned using a Baldwin filter. They are one of the cheapest filters out there and that is because they are made cheap. I work for a company that is in the construction rental business. We sell Baldwin only because it is cheap and people like cheap. I will not use Baldwin. I have see Baldwin air filters that do not seal correctly and the rep was clueless as to why they were being made that way of if they would even correct the problem. I have see hydraulic filters burst open. If you cut a Baldwin oil filter open you will fined about a third less pleats and the paper is not of the same quality as an higher dollar filter. I would accredit Bobs lack of wear due to good maintenance and better metals used today than in older cars. Filters that I consider good or OEM , Wix, (NAPA. Carquest, Both made by Wix ) Donaldson air filters And Fleetgaurd which is my choice pick. Just my opinion my background is a diesel mechanic for over 30 years. Not saying that makes me right. I am drawing my opinion from my experience. I would not try and save $6 on a filter I did not know was going to keep my $2000 engine safe
RZR Fast is offline
post #22 of 22 Old January 8th, 2012, 02:31 PM Thread Starter
Nailhead's Avatar
My RZR: RZR 800
Member #30404
This I did not know.
I don't think I'll be using them any time soon.
I think Bob probably did change the oil in that car more frequently than required, but it was an early '70's engine, so it wasn't nearly modern. It was, however, a wet-sleeve engine & I've heard the sleeves are harder than regular cast iron.
Thanks for the info.
Nailhead is offline
baja cross keith0715 Wheels and Tires 17 July 24th, 2013 12:23 PM
baja cross ya all psindust Wheels and Tires 2 June 14th, 2011 07:26 AM
Hi, names Cross Cross Fire Member Introductions 14 December 3rd, 2010 06:12 PM
who has the baja cross mack90 Wheels and Tires 29 March 17th, 2010 07:17 PM
L-Cross ohnuty Local Rides and Events 0 February 4th, 2010 01:13 PM
