CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle
This is a discussion on CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle within the Engine and Drivetrain forums, part of the Technical category; ......
Old November 18th, 2008, 07:46 PM
LvDirtJunky's Avatar
LV RzR Rider's Mechanic
First Name: Chase
My RZR: 2009
Member #4118
View LvDirtJunky's Photo Gallery(6) Send a message via AIM to LvDirtJunky Send a message via Yahoo to LvDirtJunky
2009 poolaris RZR Bikeman pipe , ump , powercammander , Throttle play adjusted , lonestar grill's .she rips
www.utvcrap.com , These guy's ROCK
I.U.O.E. Local 12 . Work Union Live Better
Old November 18th, 2008, 07:52 PM
FlyHigh rzr's's Avatar
First Name: Nick
My RZR: 09 rzr s
Member #4775
View FlyHigh rzr's's Photo Gallery(0)
Re: CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle
nice... so u would recomend the powercammander?
Old November 18th, 2008, 07:59 PM
First Name: Chase
My RZR: 2009
Member #4118
Old November 18th, 2008, 08:05 PM
First Name: Nick
My RZR: 09 rzr s
Member #4775
ill put it on my list
Old November 19th, 2008, 05:20 AM
jdhoggg's Avatar
Member #285
View jdhoggg's Photo Gallery(0)
Will do when I get home tonight...thanks for the heads up!
Things may come to those who wait, but only the things left by those who hustle.
Old November 19th, 2008, 05:59 AM
stroker0836's Avatar
First Name: tom
My RZR: the green one
Member #2742
View stroker0836's Photo Gallery(0)
poop, the secrets out. just kiddin, adj. mine at about 50 miles and again at 250 and it had excess play both times, and it does make a difference in performance.
Old November 19th, 2008, 11:50 AM
WFO's Avatar
WFO WFO is offline
Freedom ain't free
First Name: Greg
My RZR: S'sssss
Member #4968
View WFO's Photo Gallery(6)
05 Rhino......GONE
09 rzr-S x2 and LOVIN EM
07 GT500 Shelby
05 H2 SUT
ssg, 1stSFG- LIVE FREE OR DIE
  #8
Old November 19th, 2008, 01:09 PM
tightline's Avatar
Member #3399
View tightline's Photo Gallery(0)
So where do you adjust it. Is it by the pedal or down on near the throttle body somewhere.
  #9
Old November 19th, 2008, 01:39 PM
socalrs4's Avatar
Member #3063
View socalrs4's Photo Gallery(0)
Page 96 manual
  #10
Old November 19th, 2008, 03:44 PM
razrface's Avatar
My RZR: rzr s
Member #3663
View razrface's Photo Gallery(0)
great tip!!
  #11
Old November 19th, 2008, 04:50 PM
Trey's Avatar
Member #3584
View Trey's Photo Gallery(5)
thanks
Dothan, Alabama
2008 rzr racer tech engine mount, 28" zillas, 14" rims, 2" lift, warn 30, epi trail and mud clutch, s fender flares, Maier Vented Hood and optima battery, home made stereo
  #12
Old November 19th, 2008, 09:46 PM
socalrs4's Avatar
Member #3063
got to say my throttle is off, not by a huge margin but off for sure, and I must say that getting to that adjustment is not easy. its in such a tight area. Anyone remove anything to get it? or just got there hand in there?
  #13
Old November 20th, 2008, 05:23 AM
ditch pickel's Avatar
My RZR: 08
Member #1871
View ditch pickel's Photo Gallery(0)
START Hope this helps. Page 25 Freethrottle play Adj.
  #14
Old November 20th, 2008, 01:44 PM
WFO's Avatar
WFO WFO is offline
Freedom ain't free
First Name: Greg
My RZR: S'sssss
Member #4968
Wrench Re: CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle
Dilly of a post pickel. sorry couldn't help myself. Nice job.
05 Rhino......GONE
07 GT500 Shelby
05 H2 SUT
  #15
Old November 23rd, 2008, 04:35 AM
stocking_eater's Avatar
First Name: jerry
My RZR: 09
Member #4811
View stocking_eater's Photo Gallery(0)
I found mine was off also. but don't get it to tight, when i hit hard bump the idle went way high. grab your cable after your adjustment and shake it. if your idle gos up then to tight. you can reach it by your left tire very easily.
Bookmarks
Throttle Body noodles Engine and Drivetrain 3 November 17th, 2008 07:40 PM
Throttle Too Sensitive drcdac General RZR Discussion 9 October 8th, 2008 04:51 PM
Oil In Throttle Body??? r6realtor General RZR Discussion 10 September 9th, 2008 10:35 AM
Throttle free play BlackRaptor General RZR Discussion 1 July 30th, 2008 11:07 AM
Throttle Bodies Pgreg Engine and Drivetrain 14 March 17th, 2008 05:54 PM
