Old November 18th, 2008, 05:58 PM
Adding Coolant ??
I need to add some coolant in my RZR. I cant find my manual so I thought I would ask here. Do you add it through the cap or through the tank? Thanks
Remove advertisements
Sponsored links
Old November 18th, 2008, 06:40 PM
First Name: Ed
My RZR: 09 RZR S and 08 Gen 2 Greenie
Re: Adding Coolant ??
Remove the radiator cap and top off. Then top off the reservoir to the upper line. I have 3 RZRs and they all had some air in the lines from the factory.
Ed 08 RZR, and my 04Rhino racing team.
Old December 17th, 2008, 08:47 AM
airbornjim's Avatar
First Name: Jim
My RZR: '09 LE
Is the Polaris coolant a special product? Crossover?
Old December 17th, 2008, 09:34 AM
NICTAC1's Avatar
First Name: Nick
My RZR: '08 RED
USUALLY IF THE COLOR MATCHES, U R OK.
OMF 5/3 offset, reinforced inner & outer, alba intake, exhaust & fuel controller & map.
gunrunner's Avatar
its a 50-50 mix, any brand will be fine.
Old December 17th, 2008, 10:02 AM
jerrzr's Avatar
Also, dont forget to bleed the air out by unscrewing the bleed screw on top of the thermostat housing.
J & T
Old December 23rd, 2008, 09:13 PM
There probably was some air in the lines from the factory, but just to be on the safe side, check your clear res. line coming out of the top of your radiator. Mine was leaking there when it warmed up. If it is, just get a very small regular style hose clamp.
Old December 24th, 2008, 12:26 AM
str8rzr mine leaked in the same spot....did the same thing put a hose clamp on it
2006 silverado 2500 hd
2006 additude toy hauler
2008 polaris rzr
2006 suzuki ltr450
2005 kawisaki kfx700
2003 suzuki z400
2003 honda ex250
Old December 24th, 2008, 09:42 PM
Yea, I wish everything else on the thing was that easy to fix.
Sponsored links
