Old November 18th, 2008, 05:39 PM
performance packages
im buying a 2009 rzr. and i was wondering what are some of the better mods to do to it. im going to be doing alot of trail/snow/woods/light mud bashing.
whats a good clutch, does it affect the top end. (i know it does on our brte force 750)
whats a good exhaust, intake, and fuel controller i could use.
im only putting on 26" tires. is there no point of doing the spacer remover, if i put a clutch in it. wont the clutch slow it down. but doesnt the spacer give around 5 mph more. or does it you different springs and everything.
Remove advertisements
Sponsored links
Old November 19th, 2008, 05:07 PM
HOLZTECH's Avatar
holzracingproducts*****
Re: performance packages
Best bang for your buck is a good clutch kit. Take into consideration the other upgrades you plan on doing and get a clutch that will work with those. The other upgrades wont be able to show their full potential if your clutch isn't set up right.
I'm not sure if I want to get into a debate over the spacer removal....I'll just say I dont believe it's worth doing.
At best, you will only see a top speed increase of 3 - 5 mph...but nothing else.
not a site sponsor- here by choice
Old November 20th, 2008, 03:27 PM
if you buy a clutch kit make sure it has adjustable weights so you can adjust it as you get more performance mods.
Sponsored links
