Front diff. backlash adj. - Polaris RZR Forum - RZR Forums.net
This is a discussion on Front diff. backlash adj. within the Engine and Drivetrain forums, part of the Technical category; hi. i already posted about 1 month ago a problem with my front diff. making a funny noise. I changed all the bearings and the ...
Old November 14th, 2011, 05:37 AM   #1
<<< My personal RZR jack
gjem1's Avatar
My RZR: 2010 Walker Evans
Member #18085
View gjem1's Photo Gallery(16) Send a message via MSN to gjem1
hi. i already posted about 1 month ago a problem with my front diff. making a funny noise. I changed all the bearings and the roll cage and it still make the noise. i suspect the ring and pignon gears to be worn uneven and i would like to play with the backlash adj, to see if it changes anything but the screw is jammed pretty good. Any idea on how to loose it? is it suppose to be so tight?
thanks
gjem1 is offline   Reply With Quote
Old November 14th, 2011, 06:00 AM   #2
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Re: Front diff. backlash adj.
Turn the allen adjuster in until it makes a slight drag (you can feel the diff from free to having a slight contact)... Make sure you use Blue Lock Tight on set screw...
Old November 14th, 2011, 07:20 AM   #3
gjem1's Avatar
Member #18085
I wish it was that simple... Like i said, it is set in pretty tight, not moving at all. I'm almost breaking the allenkey in it. It says in the service manual to heat it up with a heat gun but how much heat does it take to free it? I'm scared to warp the casing or melt the 12 volt wiring just beside it....
Old November 14th, 2011, 07:36 AM   #4
swingarm1's Avatar
First Name: Tim
Member #7690
Use a propane torch on the set screw, heat it and immediately break it loose... Then put a wet rag on the housing to cool it off right away...
Old November 14th, 2011, 07:08 PM   #5
gjem1's Avatar
Member #18085
propane torch !?! i will try that.
Old November 16th, 2011, 09:46 PM   #6
Stumpduster's Avatar
First Name: Mike #688
My RZR: 16 1000 XP
Member #1676
Keep in mind your only needing enough heat to loosen the LocTite installed at the factory setting. Maybe insert a allen wrench and heat the wrench, should warm it just enough to break loose, then remove and clean..... play with adjustment then reinstall with new Loctite.
Just curious, how loose are your splines of the inner CV inside the output hubs?
Stumpduster is offline   Reply With Quote
adjusting set screw on polaris front diff
backlash screw rzr 800 s
backlash set screw front diff 550xp
backlash set screw on polaris rzr
could backlash adjustment affect my polaris awd
how to adjust set screw polaris rzr front differential
how to set backlash on rzr front diff
polaris rzr backlash thrust adjustment
polaris rzr front differential lash adjustment bolt location
polaris sportsman front differential adjustment
rzr backlash
rzr front diff adjustment
rzr front diff backlash
subaru front diff preload
what is the set screw on rzr diff for
RZR trans/rear diff/front diff for sale dpcustomfab Polaris RZR Parts For Sale 30 September 9th, 2014 02:14 PM
Front Diff. Parts or complete front diff. klewis34 Want to Buy 0 March 23rd, 2011 06:25 PM
Front parts diff-or-front ring gear Craig_c Want to Buy 3 December 3rd, 2010 08:23 PM
Using An Older Aftermarket Front Diff Cage In A Newer Diff HawkEng Hawk Engineering Inc. 1 October 27th, 2010 08:10 PM
clicking in front end might be front diff Crispy01 Engine and Drivetrain 11 March 1st, 2010 08:05 AM
