Secondary clutch question and rebuild kit for primary? - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old October 21st, 2011, 09:52 AM Thread Starter
rzrback fan
aquacure's Avatar
First Name: Aqua
My RZR: 2008 Green
Member #4250
View aquacure's Photo Gallery(0)
I couldnt figure out how to delete my other post and i had the title screwed up so i'm starting over.
When i pulled my belt off something happened that usually doesnt, the secondary clutch snapped shut, maybe i pulled up too hard? How do i get it to relax when i reinstall the belt? Its basically in the position like it would be if i had it the gas peddle to the floor.
One of my buttons on the spider has lost a piece and it is shorter that the others. Also my cover and sheave bushings are showing more brass than teflon and the service manual says replace. Where is a good place to get a simple rebuild kit that includes buttons and bushings?
2008 Black Herculinered
2" rubberdown lift
4000 lb Viper winch (green amsteel cable) Motosport Alloy Black Tork rims : 27" outlaw MST : "S" flares
Trail Armor boot guards : MudATV snorkel
Ipod>Amp>overhead speaker box
Benz silencer (like it quiet) : Gorilla axle
aquacure is offline
post #2 of 4 Old October 21st, 2011, 11:06 AM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
Re: Secondary clutch question and rebuild kit for primary?
Place the belt around the secondary and tap it into the secondary, slowly turning helps. EPI offers a primary rebuild kit part # WE210185 it is about $195 and comes with everything you need. Be prepared to be pressing bearings though...
Nate
Alba Racing
NATE@TEAMALBARACING.COM
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #3 of 4 Old October 25th, 2011, 09:23 AM Thread Starter
rzrback fan
aquacure's Avatar
First Name: Aqua
My RZR: 2008 Green
Member #4250
Well i ended up ordering my parts from Cheap cycle parts cuz i only needed the cover bearing, sheave bearing, buttons and I went ahead and got new washers to go around my new primary bearing and spring I had. Cost is $77 but i guess i didnt realize they just get the stuff from polaris. Doesnt look like its gonna ship till the end of the week and I will be missing a ride this weekend.
We got the old bushings pressed out at work, the cover was easy a small socket was used. The sheave was a little trickier, hard to find something that fits perfect...ended up grinding down some big washers to fit perfectly inside then a large socket to distrute the pressure. Now I just have to let it sit in the shop while i wait on the ups man. I could have ordered from my dealer and had in 3 days supposidly.
2" rubberdown lift
aquacure is offline
post #4 of 4 Old October 25th, 2011, 12:33 PM
pawngod's Avatar
My RZR: 2016 XPT BLUE
Member #12452
Feedback Score: -1 reviews
View pawngod's Photo Gallery(4)
your secondary should be closed, you have to force it open, i use a 6in 1/2drive extention as a prybar, put it inside the hole at the front of the clutch and push back this will open the sheaves and let the belt slip down far enough to roll over the front clutch or primary, you probably had the belt in a bind and when you pulled it loose the secondary will snap shut, youtube on rzr belt replacement, and i will show you just how i described,,,hope that helps
09 RZR S k&t turbo (SOLD)
2012 ARCTIC CAT WILDCAT 1000 (SOLD)
2015 RZR XP 1000 (SOLD)
2016 XPT BLUE
pawngod is offline
Primary clutch question Thebob Engine and Drivetrain 13 March 18th, 2012 09:19 PM
Primary & Secondary torque specs dsimp13 General RZR Discussion 7 June 2nd, 2011 05:46 AM
Primary and secondary clutch, +6in Gorilla axles, voltage regulator, Power Commander twvette Polaris RZR Parts For Sale 10 June 30th, 2010 11:40 AM
Primary & Secondary clutch!!! cheek Polaris RZR Parts For Sale 9 October 27th, 2009 07:37 AM
Stock 09 S primary and secondary clutchs gunrunner Want to Buy 1 October 2nd, 2009 04:45 PM
