Blown head gasket????? - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old October 13th, 2011, 07:01 AM Thread Starter
mudxxed's Avatar
My RZR: 08 RZR
Member #27900
View mudxxed's Photo Gallery(0)
Sooo here is my head gasket. Now its NOT leaking any oil or coolant where the gasket is missing/blown out etc. Which is weird. Oil is NOT milky and coolant is still coolant. I did run low on coolant at CB and had to refill BUT Im not sure if that was due to a hose clamp that was a little loose and you could see where coolant was dripping. I have since fixed that. Do you think honda bond or Bar's Leak (stuff that you pour into the coolant system and supposively seals well from the reviews) will be a temporary "bandaid?"
Im not running low on oil either. The mark is the same where it was when I did an oil change right before the ride. I used some stop leak powder stuff just incase I had a leak in the radiator which I thought I did but it was coming from my front brush guard retaining water and then slowly leaking out and making a puddle in the garage. If the engine is bathed with a mud film on it you can tell where the leak is on the motor but theres never more than half a dime size of residue. Guess just ride it a few more times and see if I have some missing coolant? Could be right where my water jacket to cylinder is and burning it off.
2008 RZR 800
6in SATV LIFT, HL Springs
31 Laws
HIDS
LTE DUALS
Bazooka TUBBIES Speakers
mudxxed is offline
post #2 of 11 Old October 13th, 2011, 07:11 AM
FFmatty's Avatar
First Name: Matt
My RZR: 2011 S LE K&T Style
Member #19406
View FFmatty's Photo Gallery(0)
Re: Blown head gasket?????
If you really think it is a head gasket then I would refrain from adding any additive that will "bandaid" the problem. I think swingarm sells all the gaskets and it would prob not be a hard fix. Drain coolant and remove head and put in new gasket. I be hesitant that adding those temp fixes would over time do somthing to the water pump, jam up thermostats or somthing... Also you could do a leak down test and see if for sure that's where your problem is.
FFmatty is offline
post #3 of 11 Old October 13th, 2011, 11:31 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Feedback Score: 26 reviews
Stop leak will do just what it is intended to do .....plug chit up, and in your case you don't need it so refrain from using it or you'll be sorry later on!
Sent from my Motorola Atrix 4G using tapatalk
MotoXXX is offline
post #4 of 11 Old October 13th, 2011, 12:17 PM
mark5193's Avatar
First Name: mark
Member #1018
Feedback Score: 11 reviews
View mark5193's Photo Gallery(5)
your head gasket is not blown, you are just missing a little piece. there must still be gasket where it is needed if no oil in coolant, or coolant in oil.
2016 yamaha yxz
2009 yfz 450r
2006 raptor 700
2008 bounder 34g
mark5193 is offline
post #5 of 11 Old October 13th, 2011, 12:26 PM
Askin's Avatar
Member #16474
View Askin's Photo Gallery(0)
If your head gasket is blown it will push coolant out the fill bottle once you start getting the motor hot. I would only use stop leak to get you home then fix the problem ASAP.
Askin is offline
post #6 of 11 Old October 13th, 2011, 12:28 PM Thread Starter
mudxxed's Avatar
My RZR: 08 RZR
Member #27900
But why am I getting a little oil/coolant leak from that hole? I mean its nothing bad but look how it discolored the motor and when the motors been under watery mud you can tell where that gasket is missing?
I put hi temp silicone on the little gap to stop the weeping of oil/coolant and rode the ride with no problems. My biggest thing was I had to fill the radiator up once quite a bit, but it could have been from the upper inlet on the radiator didnt clamp the hose tight enough allowing some coolant to leak out. Ive since got it tight and it no longer leaks. Just sucks cause I had a few variables of what it could have been so I cant figure it out!
2008 RZR 800
31 Laws
HIDS
LTE DUALS
mudxxed is offline
post #7 of 11 Old October 13th, 2011, 12:44 PM
mark5193's Avatar
First Name: mark
Member #1018
your first sentence said you were NOT leaking from that hole?
2016 yamaha yxz
2009 yfz 450r
2006 raptor 700
2008 bounder 34g
mark5193 is offline
post #8 of 11 Old October 13th, 2011, 12:50 PM Thread Starter
mudxxed's Avatar
My RZR: 08 RZR
Member #27900
true I did say that, sometimes it will sometimes it wont. Its has never been more than a very SMALL residue not even the size of the tip of your index finger, that why I said it doesnt leak.
2008 RZR 800
31 Laws
HIDS
LTE DUALS
mudxxed is offline
post #9 of 11 Old October 13th, 2011, 12:53 PM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
Cometic gasket kit is cheap and the 800 motor is probably about the easiest to pull the head on as it is pushrod. I would get a gasket set and plan on spending a few hours changing it before you do additional damage.
Nate
Alba Racing
NATE@TEAMALBARACING.COM
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #10 of 11 Old October 13th, 2011, 12:55 PM
Askin's Avatar
Member #16474
If there is no coolant in the oil and you are not pushing coolant out the fill bottle you don't have a blown head gasket. Most likely if you go through a lot mud you have over heated the ride. If you spend a lot of time in mud you will need to clean the fins on the radiator constantly.
That image you posted is a common look on the 800.
Askin is offline
post #11 of 11 Old October 13th, 2011, 01:01 PM Thread Starter
mudxxed's Avatar
My RZR: 08 RZR
Member #27900
It said hot once, I drove it back to camp and popped the cap off and it was low on coolant (which of course coulda been from that upper radiator inlet and hose going from the neck to rad) I got to many variables for us to figure it out. Im just gonna pressure check it and Ill know for sure.
2008 RZR 800
31 Laws
HIDS
LTE DUALS
mudxxed is offline
Head gasket Uppie89 Engine and Drivetrain 2 July 14th, 2011 07:22 PM
ReUse head gasket? futuredenied Engine and Drivetrain 6 September 6th, 2010 06:51 PM
Head Gasket Leak on New RZR FEDERAL General RZR Discussion 15 February 1st, 2010 10:23 AM
head gasket super s puppy Engine and Drivetrain 8 September 22nd, 2009 07:13 AM
Head Gasket? pioneer6869 Engine and Drivetrain 1 August 1st, 2008 09:03 PM
