Overheating 800 - Page 3 - Polaris RZR Forum - RZR Forums.net
Overheating 800
This is a discussion on Overheating 800 within the Engine and Drivetrain forums, part of the Technical category; Ok guys I changed the thermostat and the impeller. Filled the system and vented according to the service manual. Ran it in my shop for ...
Old October 3rd, 2012, 06:42 AM   #31
boatms's Avatar
Member #24436
View boatms's Photo Gallery(0)
Re: Overheating 800
Ok guys I changed the thermostat and the impeller. Filled the system and vented according to the service manual. Ran it in my shop for about an hour and it cycles just as it is supposed to I guess the thermostat was bad the old impeller looked as good as the new one.
boatms is offline   Reply With Quote
Old October 29th, 2012, 02:55 PM   #32
all4down
all4down's Avatar
First Name: keith
My RZR: rzr-s
Member #27147
View all4down's Photo Gallery(0)
Re: Overheating 800
I also had a overheating problem in my '11 razor this past weekend.I have 1100 miles on it and it started cutting out on me,looked over, engine overheat light was on,toggled to the display and temp read 245 deg. Fan was running intermitten at this time,wired it direct and used the foglights toggle so I could turn off and on.Worked for about 3 hours then overheated with fan on.Noticed coolant leaking out of the weep hole on the bottom of the pump.Took out thermostat,threw it in boiling water,opened fine.Rad perfectly clean but water isn't circulating.Impeller doesn't explain why the fan run but shut off before engine was able to cool.Has anyone seen a impeller go bad? Leaks like a cars pump when it goes bad but not built the same way.Totally lost here on this one,hopefully someone can shed some light.
all4down is offline   Reply With Quote
Old January 7th, 2013, 10:29 AM   #33
RZRTOURS's Avatar
First Name: TROY
My RZR: RZRS RZR4 RZR
Member #25042
View RZRTOURS's Photo Gallery(0)
Re: Overheating 800
Yes, Impellers do go bad. We have had to replace a few. You probably got air in your system when you over heated. Also, if you have coolent leaking out of the weep hole down by the water pump, that means your water pump seal is bad. That will have to be changed to correct that problem. Impeller can be changed at the same time.
RZRTOURS is offline   Reply With Quote
Old October 14th, 2013, 03:59 PM   #34
catman1120's Avatar
My RZR: 2011 RZR S carbon fiber
Member #28020
View catman1120's Photo Gallery(0)
Re: Overheating 800
hey i just got back from trailfest in wv and my rzr give me some trouble overheating. this was the first time in 4000 miles. i ride hard and have minor mods done to engine. here is the kicker it only runs hot under steady throttle, i can gag the sh#$ out of it for hours in the mountains but as long as i get in and out of the throttle but if you demand a steady rpm it starts cooking, removed t-stat but no change im thinking impellor is worn but have not tore it down yet, anyone seen this issue? also rad. is clean and no air in system thanks in advance
DONE 4 FUN!!!!!!!
catman1120 is offline   Reply With Quote
2014 polaris rzr 800s overheating issues
800 rzr over heating
800 rzr overheating
over heating polaris rzr 800
polaris 800 overheating
polaris 800 ranger overheating issues
polaris ranger 800 overheating
polaris ranger overheating
polaris rzr 800 overheating
polaris rzr overheating
rzr 800 overheating
rzr overheating
what would cause a polaris razor to over heat
what would polaris razor over heat
why is my polaris ranger overheating
Overheating?? RZRBound Engine and Drivetrain 18 February 20th, 2017 03:04 AM
anyone having overheating problems????? bs250r Engine and Drivetrain 14 August 27th, 2012 06:46 PM
Need help with overheating! Halloween_Nut Engine and Drivetrain 19 July 19th, 2012 07:32 AM
overheating rzr103 Engine and Drivetrain 2 February 20th, 2011 04:56 PM
rzr overheating rickmaley Engine and Drivetrain 8 April 14th, 2009 06:58 PM
