December 19th, 2007, 04:12 PM
First Name: Bud
My RZR: Red 2008
Grinding Gears
Anyone else having issues with the gears grinding when trying to shift from park? I am totally stopped and not forcing the shifter but it still grinds most of the time.
December 19th, 2007, 06:13 PM
"RHINO" HUNTER
First Name: Jim
My RZR: green 08
Re: Grinding Gears
I have that problem occasionally. I will have the dealer address the problem when I go in for service soon. I think it is a linkage adjustment problem.
December 19th, 2007, 07:25 PM
First Name: Tom
My RZR: original red
Re: Grinding Gears
Are you at idle or are your RPM's a little high. The clutch's have to be turning, or the tires have to be turning to grind.
December 20th, 2007, 01:03 PM
First Name: Bud
My RZR: Red 2008
Re: Grinding Gears
My idle is between 1100 and 1200. Is that to high?
December 20th, 2007, 02:43 PM
My RZR: 2008 Murdered Out RZR
Re: Grinding Gears
No anything under 1300 RPM is normal. I would take it to the dealer.
2006 Silverado 2500HD Custom Truck
2007 Weekend Warrior FSW3200
2008 Ranger RZR 800 EFI (w/kids rear bench seat!)
2001 ETON 50 ATV (Taylor's Old Ride!)
Coming Soon (Something for KatieBugs!)
December 20th, 2007, 05:06 PM
Re: Grinding Gears
I think he is having the common problem that a lot of people are having. It does not fully engage into gear, and when you hit the gas it grinds bad. I got to where I pull it back, and tap the pedal to see what it does.
Just Muddin!
December 20th, 2007, 06:52 PM
My RZR: 800
Re: Grinding Gears
The clutch moves in neutral. The noise reminds me of a boat where you have to hit it in gear fast.
Has anyone gotten stuck in park? I was going for reverse when I got stuck on a steep incline. I stabbed it all the way in park by accident. When I let off the brakes, all of the weight was on the park gear. I had to pull with both hands to get it out.
'08 Gen1 RZR, ITP's, Maxxis Bighorn 26-9-12's, Fireball 6" over suspension with Bilstien shocks & 14" of travel  , GPS
December 20th, 2007, 07:25 PM
Re: Grinding Gears
Just got mine stuck in park last night actually.Passenger had to get out and rock it .
December 20th, 2007, 09:39 PM
My RZR: 800
Re: Grinding Gears
How do you like the goodyear tires? I'd like to know how long they last. Try to wear them out so you can tell us!
December 24th, 2007, 06:46 PM
My RZR: 2008 RED GEN2
Re: Grinding Gears
A fast rapid shift will prevent the grinding issue.
December 25th, 2007, 12:32 PM
Re: Grinding Gears
So far i rate them as ok.Not as good as the Mud lites in snow and mud but much smoother ride.I noticed they are already cut up pretty good from spinning on rocks
December 26th, 2007, 11:40 AM
Re: Grinding Gears
December 26th, 2007, 11:41 AM
Re: Grinding Gears
100 miles on my 08 and I too "tap" the throttle just to make sure its in.
September 3rd, 2008, 02:37 PM
Re: Grinding Gears
My 09 grinds also. So far i just shut it off and select the gear then restart.
September 4th, 2008, 08:01 PM
Re: Grinding Gears
I notice the same on occasion, shifting from reverse to high. It helps to hold the shift lever back at initial throttle. Possibly a linkage adjustment will correct this.
