Transmission noise - Polaris RZR Forum - RZR Forums.net
post #1 of 14 Old September 4th, 2011, 10:34 AM Thread Starter
Red Dragons
LoneStarRZR's Avatar
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
View LoneStarRZR's Photo Gallery(7) Send a message via AIM to LoneStarRZR Send a message via Yahoo to LoneStarRZR Send a message via Skype™ to LoneStarRZR
Pissed Transmission noise
Ive done searches and i cant seem to come up with anything
last time i took the rzr out everything worked great, no sounds no problems. Well it sat for about a week and i decided to take it for a spin around the block. As i was slowing down i heard some rattleing from the back, when i was almost at the stop at sounded like it was falling out of gear. I jacked the rear end up and put it in the neutral spun the tires and it sounds like bolts in a dryer. Its full of oil and only a few hours since the last service, why now? after its been sitting also?
2008 800 -SOLD SOLD SOLD
2014 Titanium XP1000
LoneStarRZR is offline
post #2 of 14 Old September 4th, 2011, 11:40 AM Thread Starter
Red Dragons
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
Re: Transmission noise
this is with it in neutral and spinning the tire by hand
post #3 of 14 Old September 4th, 2011, 12:05 PM
Sand Blaster!!
ohmartm's Avatar
First Name: Merle
My RZR: 14' XP1K4
Member #1732
Feedback Score: 5 reviews
View ohmartm's Photo Gallery(17)
I know that sound all to well. Not good.
Check out this thread I posted a while back....
http://www.rzrforums.net/members-rid...all-apart.html
Can you still drive it? Shift it?
ohmartm is offline
post #4 of 14 Old September 4th, 2011, 12:09 PM
Sand Blaster!!
ohmartm's Avatar
First Name: Merle
My RZR: 14' XP1K4
Member #1732
Sound dry. are you sure you put fluid in both fill spots? There are two.
ohmartm is offline
post #5 of 14 Old September 4th, 2011, 12:22 PM Thread Starter
Red Dragons
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
yeah, when i did the oil change i didnt drain the transfer case, just the trans, it still drives and shifts fine, but when i start to get over 25 there is a weird grinding noise
post #6 of 14 Old September 5th, 2011, 07:22 AM
HIGHOCTANE's Avatar
Member #16360
Whatever it is I don't think continuing to drive is going to help...probably just making things worse. Is there metal in the oil?
HIGHOCTANE is offline
post #7 of 14 Old September 6th, 2011, 08:16 PM
Sand Blaster!!
ohmartm's Avatar
First Name: Merle
My RZR: 14' XP1K4
Member #1732
Pull all the. Plugs and look at the magnets to see if there is any metal on them and look in there with a flashlight.
ohmartm is offline
post #8 of 14 Old September 6th, 2011, 08:17 PM
Sand Blaster!!
ohmartm's Avatar
First Name: Merle
My RZR: 14' XP1K4
Member #1732
The magnets are part of the plug. ( only fyi) lol
ohmartm is offline
post #9 of 14 Old September 6th, 2011, 08:55 PM
wolfpack783's Avatar
My RZR: Can am X3 RS Max, 2013 XP 4 900 LE Sold
Member #15068
View wolfpack783's Photo Gallery(0)
You need to do a "transmission problem" search on this site and in google. It seems lunched transmissions in rzrs is a way too common problem. I wish you luck.
wolfpack783 is offline
post #10 of 14 Old September 8th, 2011, 04:26 PM Thread Starter
Red Dragons
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
no metal in the oil, i dont have magnets on my plugs, could it possibly be the output shaft connecting the rear end?
post #11 of 14 Old September 11th, 2011, 10:30 AM Thread Starter
Red Dragons
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
Bump
post #12 of 14 Old November 8th, 2011, 11:46 PM Thread Starter
Red Dragons
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
well i figured it out, the lashing on the new front plate on the front diff was too tight causing everything to drag, made me feel like a massive dumbass for not checking it before, anyway, future reference, cheers mates
post #13 of 14 Old November 11th, 2011, 05:46 AM
<<< My personal RZR jack
gjem1's Avatar
My RZR: 2010 Walker Evans
Member #18085
View gjem1's Photo Gallery(16) Send a message via MSN to gjem1
Are you refering at the backlash adj. on the front diff. ? If so. How did you readjusted it? I tried to adjust it on mine and the allen key is stuck... and how can this adj. make the rear transmission noisy?
Thanks for taking the time to explain.
gjem1 is offline
post #14 of 14 Old November 11th, 2011, 04:42 PM Thread Starter
Red Dragons
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
Yeah the little allen key adjustment, i just backed it out untill i wasnt feeling it grab on the diff anymore, you are just gonna have to try break it loose. I cant really explain why it fixed it just out of speculation i figured it was too tight causing drag on the driveshaft back to the transfercase and ultimatly the transmission.
Deceleration transmission noise on rzr4 jamie.s.72 Engine and Drivetrain 3 September 15th, 2011 04:14 PM
transmission noise rzr 2011 revenger1 General RZR Discussion 3 June 19th, 2011 10:42 AM
Transmission noise zebradog Engine and Drivetrain 2 September 21st, 2010 12:12 PM
Ticking noise on cold start. (Similar to lifter noise on a car.) rwillden Engine and Drivetrain 1 September 14th, 2010 07:57 AM
Help! Transmission noise Alfa Baz Engine and Drivetrain 3 September 2nd, 2010 05:47 AM
