Clutch System Cleaning - Polaris RZR Forum - RZR Forums.net
This is a discussion on Clutch System Cleaning within the Engine and Drivetrain forums, part of the Technical category; I read somewhere that you clean the pulleys with with hot soapy water with a steel wool, do I need to clean the belt also? ...
Old October 15th, 2008, 09:55 AM   #1
cbowtie's Avatar
Member #3427
View cbowtie's Photo Gallery(0)
I read somewhere that you clean the pulleys with with hot soapy water with a steel wool, do I need to clean the belt also? I know on on auto v belts you could put toothpaste on the belt, would that work on the this belt also?
as far as belt replacement(if needed), I know the Dayco's I should stay away from, what about EPI or Goodyear? What is the part numbers associated with them?
cbowtie is offline   Reply With Quote
Old October 15th, 2008, 07:24 PM   #2
snowbanx's Avatar
My RZR: 2009 RZR LE Nuclear Sunset
Member #4203
View snowbanx's Photo Gallery(0)
Re: Clutch System Cleaning
Hot soapy water or a degreaser like Slapshot and clean it up. Then scuff it just a little bit, like hardly at all with scotch brite, not sure about steel wool.
Definatly wash your new belts in hot soapy water. There is lots of oils and release agents on the belt from being made.
snowbanx is offline   Reply With Quote
Old October 15th, 2008, 07:59 PM   #3
Feedback Score: 18 reviews
megadesertdiesel's Avatar
My RZR: None
Member #597
this is the info noone speaks of. i have learnned this from a sled guy and its true. makes the belt not slip as much.
just one of those little tricks.
megadesertdiesel is offline   Reply With Quote
Old October 15th, 2008, 08:03 PM   #4
King of crash!
Member #787
do not use tooth paste or anything but soap and water on a belt....
Old October 16th, 2008, 05:11 AM   #5
Boost_it's Avatar
Member #1380
View Boost_it's Photo Gallery(0)
Also, never use a cleaner other than soapy water on the clutches.
Boost_it is offline   Reply With Quote
Old October 16th, 2008, 08:41 AM   #6
cbowtie's Avatar
Member #3427
Thanks Guys
Old October 16th, 2008, 05:41 PM   #7
Dirty Dawg Dale
Feedback Score: 8 reviews
Dirty Dawg Dale's Avatar
First Name: Dirty Dawg Dale
My RZR: 2015 RZR 900, "09" RZR 170
Member #1845
View Dirty Dawg Dale's Photo Gallery(0)
One of the best ways to clean the clutches is first remove them from the machine. Use air to blow out the belt dust. [I would do this outside] Make sure blow out any belt dust from under the heel of the weight, as build up can cause the clutch to engage at idle. Next scuff the clutch sheaves with a green scotch brite pad and do not forget to do the towers where the buttons ride up and down. Then you will want to spin the shoulder bolt that holds the weight in. If there is any resistance when trying to spin it, you should remove the shoulder bolt and drag your fingernail along it making sure there is no wear if there is they should be replaced, if not clean with scotch brite pad. I use nothing but alcohol to clean the clutch sheaves, towers and all other clutch components. Pour the alcohol on a clean rag wipe and repeat these steps until rag is not black with belt dust. Brake and contact cleaners leave a residue that can cause premature belt, bushing, and roller failure. Water if not used very carefully can cause some premature damage. Like others have said it is best to wash the belt with dish soap removing the silicone release agent from the belt then using a clean scotch brite pad drag it along the belt lightly on both sides then install. [make sure belt is totally dry before installing] After belt is installed put machine in neutral and start machine then let the machine run for 5 minutes then go out and drive it at steady slow speed to build heat in to the belt this will heat cycle the belt and prolong the belts life. Then go mash the gas and hang on!
Dirty Dawg Dale is offline   Reply With Quote
Old October 16th, 2008, 05:57 PM   #8
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
how often should this be done?
crazywatson is offline   Reply With Quote
Old October 16th, 2008, 06:20 PM   #9
Dirty Dawg Dale
Member #1845
If the clutch sheaves are not nice and shinny and if you can see black belt dust on the primary clutch this would be a good time to clean them. I would always clean before installing a new belt. Keep in mind there is a huge performance difference having clean clutches. The primary clutch is the one that will need most of the attention.
best way to clean a rzr clutch
clean rzr clutch
cleaning clutch on polaris ranger
cleaning polaris clutch
cleaning polaris clutch sheaves
cleaning rzr clutch
cleaning sheaves rzr forum
clutch cleaning
how to clean a polaris clutch
how to clean a polaris quad clutch
how to clean polaris clutch
how to clean rzr clutch
polaris rzr clutch cleaning
rzr clutch clean
rzr clutch cleaning
MCX Turbo System compared to Aerocharger System jaywebguy Forced Induction 74 May 12th, 2011 05:01 PM
cleaning the ump bajarzr Forum Help, Questions and Info 9 February 19th, 2009 07:54 PM
Cleaning After Riding Bruce General RZR Discussion 30 December 15th, 2008 10:11 PM
cleaning my rzr N2DARZR General RZR Discussion 3 December 2nd, 2008 11:08 AM
cleaning tysonhonda General RZR Discussion 14 September 3rd, 2008 12:47 AM
