What differential oil do you use???
This is a discussion on What differential oil do you use??? within the Engine and Drivetrain forums, part of the Technical category; What kinda of oil do all of you use in your front and rear differential. i have water in mine and need to change them. ...
Old August 2nd, 2011, 11:42 AM
insaneclowns04's Avatar
First Name: Eric
My RZR: 2009 Camo RZR
Member #25854
View insaneclowns04's Photo Gallery(0)
What kinda of oil do all of you use in your front and rear differential. i have water in mine and need to change them. but dont have a polaris dealer that close to me to get the polaris oil. i heard of people use royal pruple in them but dont know if that good on them or not. so if you guys would post and and tell me what you are using would help me out.
thanks eric
Old August 2nd, 2011, 12:16 PM
highboost11's Avatar
First Name: steven
My RZR: 08 rzr mcx turbo
Member #28520
View highboost11's Photo Gallery(10)
Re: What differential oil do you use???
I use lucas full synthetic gearcase oil 75-90wt in my rear diff and transfer and gearcase .... the front i use john deere low viscosity hyguard transmission and hydrolic oil yep the front diff need that special oil i dont use any polaris oil products as amatter a fact i use honda gn4 10w40 in my engine i swear by it too....
Old August 2nd, 2011, 12:35 PM
rzrwrecker's Avatar
ride guide extrodanire
First Name: Skeeter
My RZR: XP WE 900 2013
Member #614
View rzrwrecker's Photo Gallery(0)
i swear by Polaris oil ....... i used mobil1 in the motor before the rebuild and it will mix with the polaris oil also if your oils DIRTY there is still like a 1/3 quart still in there , i use the mobile 1 to flush out the motor ! I take 2 quarts, dump them in with the drain pulg out making sure it is going in to a clean pan so u can reuse it run it thru a couple a times and your dirty oil will simply go away ! then refill with good oil and your oil will stay cleaner longer ! also i use the fram filter i dont re 7313 i think ..change oil often , and your motor will love you . also do the front end a lot more too there is only a little oil in there
Old August 2nd, 2011, 06:25 PM
sunset rzr's Avatar
First Name: Sam
My RZR: 2010 SUNSET RED, LE, EPS, SSV Overhead w Add on, Brushgards, Hid Lights. Bimini top.TQS 30" lightbar
Member #14690
View sunset rzr's Photo Gallery(0)
used amsoil atf in front diff, 75/90 sever gear in rear diff. 5/50 in engine, hot down here, 2000 chain case for trans case and transmission all synthetic, oh yeah, there is a sticky for this
Old August 2nd, 2011, 06:29 PM
swingarm1's Avatar
Feedback Score: 137 reviews
First Name: Tim
My RZR: XP 4/2 APEX UTVINC IRONMAN EDITION
Member #7690
I use the Polaris Fluids in my XP...
timaz@cableone.net
928-273-4249
Old August 3rd, 2011, 08:03 AM
brendog84cj8's Avatar
Member #9106
View brendog84cj8's Photo Gallery(0)
In the rear diff I was using the Polaris gear lube but now I have Redline 75-90 in it. The front diff I only use the polaris stuff, hub fluid or whatever it is called. Transfer case and Tranny I use the Polaris AGL (the purple stuff).
In the motor I have been running Amsoil 4Stroke 0-40.
2009 50inch RZR, MakinTrax Springs, Viper 4500 winch.
Old August 3rd, 2011, 10:15 AM
MikeT's Avatar
My RZR: 2009 50" RZR
Member #14202
View MikeT's Photo Gallery(0)
Polaris fluids for all lube needs.
Mike
  #8
Old August 3rd, 2011, 01:26 PM
whiteeye42's Avatar
First Name: Robert
My RZR: 2011 rzr LE
Member #18881
View whiteeye42's Photo Gallery(0)
polaris oil all the way also i use oem filters to
11 polaris rzr 800 le
87 suzuki 230 quadsport
87 suzuki 230 quadrunner
Be Good Play Nice and Share Your Toys
  #9
Old August 4th, 2011, 07:16 PM
First Name: Eric
Member #25854
so it looks like just about everyone use polaris oil. so it there a place where you buy it online. because i cant find anywhere at does.
  #10
Old August 4th, 2011, 08:21 PM
srw's Avatar
First Name: Steve
My RZR: 2009 S
Member #9857
View srw's Photo Gallery(0)
Genuine Polaris Parts | Polaris Accessories | Polaris ATVs| Polaris Ranger | Polaris RZR | Ohio Polaris Dealer
This is the 1st site that google listed, I buy mine from Parker yamaha in AZ.
Much cheaper than my local popo dealer.
  #11
Old August 4th, 2011, 08:45 PM
cwspfx's Avatar
First Name: Chris W.
My RZR: 09 RZR S
Member #3687
View cwspfx's Photo Gallery(13)
front diff .... full synthetic ATF
rear diff .... Redline shock prof full synthetic gear oil
trans/transfer ... Redline shock prof full synthetic gear oil
2010 Class 2 Champion -World Off Road Champion Series - UTV #515
  #12
Old August 5th, 2011, 06:24 AM
TeamMudd's Avatar
Member #24674
View TeamMudd's Photo Gallery(0)
i have searched my eyes screwy on this as well.......well today i'm getting my 5gal bucket of Mobil 424 hydraulic fluid.
i'll be using mobile 424 in the front diff and trans/transfer
the bucket is free so how can i turn it down....
Jason
2010 Rzr 50"---The Bush Buggy, full rhino lined plastic, custom front bumper & rear cage/bumper, true dual exhaust, 2" lift, 4K winch, custom shifter, no sway bars, 30" zillas!
  #13
Old August 5th, 2011, 08:16 AM
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
Chris, what weight of the Redline oil do you use? I used HW in my Hewland sequential transaxle gearboxes in formula cars. The boxes ran at a much higher temp than I would expect in a RZR. The techs at Taylor (who would blueprint our boxes) saw much improved pressure angle wear and less pitting on the gear face when used over other products. I would like to use it in my RZR but was hoping for a guinea pig first!
Robin
  #14
Old August 5th, 2011, 01:35 PM
cwspfx's Avatar
My RZR: 09 RZR S
Member #3687
Robin
The shock prof heavy gear oil isnt really rated ... they say it like having 75w250 ... works well both cold ...and really good hot. It pours like thick strawberry milk .... not like you would think with that rating!
  #15
Old August 7th, 2011, 02:45 PM
Milkman's Avatar
First Name: Milkman
My RZR: 11 RZR 800
Member #25230
View Milkman's Photo Gallery(0)
Amsoil ATF in the front diff and Amsoil 75w90 Marine gear oil in the rear
2011 Orange Madness RZR - Further from stock eveyday
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather skid in sideways, cigar in one hand, beer in the other, body used up, totally worn out and screaming "WOO HOO, what a ride!!!!!!
08 polaris rzrdiff oil
2009 polaris razor 800 differential oil
polaris differential fluid
polaris ranger 800xp rear differential oil
polaris ranger axle fluid
polaris ranger differential fluid
polaris ranger differential oil
polaris ranger rear diff fluid
polaris ranger rear diff oil
polaris ranger rear differential fluid
polaris ranger rear differential oil
polaris rear end oil
polaris rzr differential fluid
polaris rzr rear differential fluid
rear differential oil 2009800efi rzr
RZR Differential Powermaxx Engine and Drivetrain 11 January 23rd, 2010 06:48 PM
RZR differential parts JPeterson889 Engine and Drivetrain 0 October 26th, 2009 04:34 PM
RZR Differential Powermaxx General RZR Discussion 2 September 16th, 2009 07:28 AM
Differential Powermaxx High Performance Designs 28 August 19th, 2009 09:18 AM
Differential Powermaxx Engine and Drivetrain 15 May 9th, 2009 08:52 AM
