What is Polaris AGL? - Polaris RZR Forum - RZR Forums.net
This is a discussion on What is Polaris AGL? within the Engine and Drivetrain forums, part of the Technical category; I have a Ranger but it probobly uses the same fluids as your RZRs so I figured I'de ask here as well. I got no ...
Old July 17th, 2011, 09:07 PM   #1
B_Krukow's Avatar
Member #7862
View B_Krukow's Photo Gallery(0)
I have a Ranger but it probobly uses the same fluids as your RZRs so I figured I'de ask here as well. I got no where on the Ranger fourums. I want to change the oil in the rear of my 2010 Ranger before I go on vacation this Friday.. It has the one peice transmision/rear end in it. It takes Polaris AGL for oil but what is it? It is rite at 60 miles to teh nearest dealer and I realy dont feel like driving 2 hour round trip for 2 quarts of what is most likely just 75-90 gear oil. That and what is there front hub oil they use in the front end? Someone told me it basicaly just synthetic ATF wich I have on the shelf in the garage along with synthetic 75-90 gear oil. No one on the Ranger fourums seems to have any idea what either of them actualy are.
B_Krukow is offline   Reply With Quote
Old July 17th, 2011, 09:38 PM   #2
sr12345's Avatar
First Name: Sean
Member #1925
View sr12345's Photo Gallery(0)
Re: What is Polaris AGL?
A couple of years ago I read a post which identified Amsoil substitutes for the Polaris fluids. In summary:
- AGL = You can also use Amsoil series 2000 synthetic chaincase lubricant
- Rear Diff: Use any 75W90 gear oil
- Front diff: You can also use Amsoil shock therapy #5 light
Just mail order the Polaris fluids--it will be far cheaper than driving that distance round trip!
2008 Rzr * RimArmor * Factory UTV skids and A-arm guards * Makin Trax progressive springs * 26" Bighorns * 2 inch lift kit (Rubberdown front, Thunderhawk rear) * Thunderhawk front bumper mount reinforcement and exhaust shield * Dirty Dawg clutch kit * Maier wheel flares * 2 inch rear wheel spacers * HPD greased steering bushing * Dragon Fire Racing 4 point belts and air intake
sr12345 is offline   Reply With Quote
agl fluid
agl oil
agl plus transmission fluid
agl plus transmission fluid equivalent
agl transmission fluid
polaris agl
polaris agl equivalent
polaris agl fluid
polaris agl fluid equivalent
polaris agl oil
polaris agl oil equivalent
polaris agl plus equivalent
polaris agl plus substitute
polaris agl substitute
what is polaris agl fluid
Polaris buys Indian Motorcycle, Polaris stock up 23% today Tuf-Skin General RZR Discussion 8 April 21st, 2011 01:42 AM
