idle adjustment, i searched - Polaris RZR Forum - RZR Forums.net
This is a discussion on idle adjustment, i searched within the Engine and Drivetrain forums, part of the Technical category; I searched idle adjustment but didnt find a clear answer. can anyone tell me where to adjust the idle. dont want to mess with the ...
Old May 13th, 2011, 07:46 PM   #1
rzrs24
rzrs24's Avatar
My RZR: 2011 RZR S
Member #7524
View rzrs24's Photo Gallery(5)
I searched idle adjustment but didnt find a clear answer. can anyone tell me where to adjust the idle. dont want to mess with the tps. where is the screw located. owners manual says to take to dealer. cant be that hard can it?
MY RIDES
2011 RZR S,09 Brute Force,YZ250
Son's Ride
Outlaw 50
rzrs24 is offline   Reply With Quote
Old May 14th, 2011, 05:46 AM   #2
Pirate's Avatar
First Name: Stuart
Member #3677
Re: idle adjustment, i searched
It isn't. Remove at least one seat, then remove the engine compartment access cover and the PVT discharge tube ( two push pins and two clamps). Now you can easily see the black plastic throttle body cover. On the left side (as you're looking from the front of the RZR) towards the bottom of the cover you'll see a lock nut, the threaded end of the cable and a black plastic cover over the hex adjuster. To raise the idle, slide the black cover off the hex, hold the hex with an end wrench, loosen the lock nut and then begin backing the cable threaded end out. When you get the idle you want, about 1120 RPM retighten the lock nut, slide the black plastic cover back in place and complete the reassembly.
One note, if you're having idle problems, say it has started idling at 700 RPM or so, and the motor dies when you stop occasionally, and to get the idle to 1120 RPM you have to back the cable out 1/4". Well, like me, you probably "dusted" the motor.
Best of luck!!!
Pirate is offline   Reply With Quote
Old May 14th, 2011, 06:04 AM   #3
Feedback Score: 5 reviews
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
There is no screw like on a carb. Is that what you're like for?
chipper is offline   Reply With Quote
Old May 14th, 2011, 06:22 AM   #4
Feedback Score: 8 reviews
Lo64chvy's Avatar
First Name: Luke
My RZR: 2008 rzr le
Member #10000
View Lo64chvy's Photo Gallery(2)
Here's a thread that's helped a lot of people. That was the 3rd thread when I searched idle adjustment!!!
http://www.rzrforums.net/engine-driv...dle+adjustment
2008 RZR Le,Superatv+5 kit, w/Fox Podiums, makintrax springs, UTVInc billet hubs,Jstrong top w/light bar w/4" Hid's, Burke moto pro hid's Itp steelies w/GBC dirt commanders, D&L airbox, Ricochet skids,DFR harness, Twisted stitch bench seat, Axia alloys mirror,Gopro wide,Factory Utv dipstick relocator,Thunderhawk performance twin Upper shock brace, radiator brace
Lo64chvy is offline   Reply With Quote
Old May 14th, 2011, 06:53 AM   #5
rzrs24
rzrs24's Avatar
My RZR: 2011 RZR S
Member #7524
Best of luck!!!
appreciate it, ive adjusted throttle cable on my first rzr. i know exactly what your talkin about. my 11 is 1300 at a idle, so i need to turn it down. grinds a little when shifting. when i searched i found something about turning a screw so i was a little confused. thanks for clearing it up.
MY RIDES
Son's Ride
Outlaw 50
Old May 14th, 2011, 08:46 AM   #6
Pirate's Avatar
First Name: Stuart
Member #3677
You're more than welcome. Nope to carburetor, no idle jet screw. But if you remove the black throttle body screws, you'll see that the throttle cable is on a bellcrank that turns the throttle butterfly. But I'd suggest not doing that. To disconnect my throttle cable to pull the motor finally gave up and uses needle nose visegrips to get the cover screws out. Ordered new screws at the dealer and he wasn't surprised at all.
Old May 14th, 2011, 12:06 PM   #7
rzrs24
rzrs24's Avatar
My RZR: 2011 RZR S
Member #7524
thanks again, i like to check the forum before i start tweekin on stuff. Yes i know its fuel injected. thanks
MY RIDES
Son's Ride
Outlaw 50
Old May 14th, 2011, 12:16 PM   #8
Sparky's Avatar
First Name: Dave
My RZR: Aerocharged 1110
Member #1007
View Sparky's Photo Gallery(0)
I suggest you don't use the throttle cable adjustment to set your idle. This isn't what that adjustment is ment for. It's to adjust the free play of the throttle cable - only !!
The correct way to adjust the idle is to adjust the throttle plate set screw. In adjusting this screw - One does have to re-set the TPS. Hence Polaris only recommends taking the machine to the dealer.
Now - IF you want to go ahead and adjust your own idle -- Here is what a modified throttle plate screw looks like and where it is located on the throttle body ........
If you don't wish to modify the set screw - I used a dremmel with their cutoff wheel to cut a straight slot in all of mine -- You can order the KMS tool -- Here's a pic .. ..
And for adjusting the TPS -- Again KMS has a kit .........
Good Luck .. .. ..
Sparky is offline   Reply With Quote
2009 polaris rzr 800 idle adjustment
2010 polaris ranger 700xp idle rpm
2015 800 polaris ranger rpm at idle
2015 polaris outlaw throttle screw location
800 rzr how to adjust idle
how to adjust idle on polaris rzr 800
how to adjust idle on rzr 800
how to set idle on rzr 800s
idle screw location polaris 900
polaris 800 s idle setting
polaris outlaw 50 idle adjustment
polaris ranger idle adjustment
what is the screw for on a polaris rzr throttle body
what should a 2011 800 rzr rpm at a stop
TPS Adjustment....or Throttle Cable Adjustment bizness RZR-S Specific Discussion 5 January 19th, 2012 06:15 PM
idle adjustment screw SSVworks RZR 170 Specific Disccusion 8 October 31st, 2010 05:18 PM
tps adjustment drtguy13 Engine and Drivetrain 15 May 23rd, 2010 05:27 PM
Oil Change. (I already searched) chadster1 Engine and Drivetrain 5 May 3rd, 2010 05:50 PM
Help!! Tie rod adjustment on RZR-S mdebone1 Engine and Drivetrain 6 December 10th, 2008 09:49 AM
