Failed connecting rods - Polaris RZR Forum - RZR Forums.net
This is a discussion on Failed connecting rods within the Engine and Drivetrain forums, part of the Technical category; In another post Chris mentioned failed connecting rods. I didn't want to hijack the post too bad, so starting a new thread. Not seeing much ...
Old March 15th, 2011, 10:08 AM   #1
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
In another post Chris mentioned failed connecting rods. I didn't want to hijack the post too bad, so starting a new thread. Not seeing much on the topic....
Quote: Originally Posted by bioaction2 View Post
I twisted mine [crank reference] at 10 psi with the stock limiter. Then I had a connecting rod break on a pinned crank at 11 psi with stock limiter and it destroyed the whole engine. Now I have a billet crank standard bore running 12 psi for now and it rips.
Chris, What are you saying the the relationship between the original pinned crank vs. the billet crank in regards to your connecting rod failure? Is there something about the pinned crank that allowed the rods to fail? Not seeing the relationship.
What is the proposed solution here, aside from a billet crank? Are there any better connecting rods I should be considering while she's split open? -Just want to be able to safely run the RPMs up in the future without rod failure on my mind. Can't even turn up the RPMs on a '11 at this point, but somebody will offer something at some point.
Likely the answer is "don't worry about it", but just checkin'
FunRide is offline   Reply With Quote
Old March 15th, 2011, 02:12 PM   #2
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
Re: Failed connecting rods
Not an attempt to hijack but a point of clarification... I cannot see, in any pics/diagrams in the svc man. or elsewhere, that there are "end caps" on the crank end of the con rods on this engine. Am I just not seeing views where they are visible or are the rods slipped on over the rod bearing surface prior to pressing the crank together on assembly. If that is the case then I assume that a billet crank would use upgraded rods being that they would by necessity be included as part of the crank assembly when purchased. Along that same vein of thought, then, if I would break a con rod on a stocker, then I would have to by a new crank assembly to replace it (short of splitting the crank apart to put on a new one)
Scratching my head here!!!
rardoin is offline   Reply With Quote
Old March 15th, 2011, 03:47 PM   #3
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Not sure Robin. Haven't got that far in my break down, or thought that far ahead yet Somebody who knows will chime in, Moto, Milos, Bart, HighOctane, or Cliff. -Good question though and completely relevant.
Old March 15th, 2011, 04:39 PM   #4
Slacker
Evil Eye's Avatar
First Name: Shawn
My RZR: 2009 RZR-S
Member #17704
View Evil Eye's Photo Gallery(0)
Good question! Pass me some popcorn, I'm gonna learn a thing or three...
Shawn Carlson
Proud Navy Vet
2009 RZR-S
Evil Eye is offline   Reply With Quote
Old March 15th, 2011, 05:14 PM   #5
super s puppy's Avatar
First Name: steven
My RZR: 2008 2gen
Member #3970
View super s puppy's Photo Gallery(0)
you can not get the stock rods off the stock crank or can anyone els the only thing to do if you do not want to have to ever think about the crank again is to buy the crank work one alot bigger rods and roller bearings billet crank
super s puppy is offline   Reply With Quote
Old March 15th, 2011, 09:51 PM   #6
35bansheerider's Avatar
My RZR: Sold!! RZR xp (turbo'ed) and a pink LE for my wife
Member #786
View 35bansheerider's Photo Gallery(5)
Supper puppy is right, you cant service the rods on a stock crank, therefore you wont gain much by pinning the crank. You should just bite the bullet and build it with the billet crank.
Greg
Nuclear Sunset 1k My current ride
Turbo'ed Pink 800 LE for my wife
Aerocharged XP900 LE Sold!
RZR "S" 800 Turbo'ed Sold!
The Original 50" RZR Green Turbo'ed Sold!
35bansheerider is offline   Reply With Quote
Old March 15th, 2011, 10:10 PM   #7
bioaction2's Avatar
My RZR: XP 1000
Member #2604
View bioaction2's Photo Gallery(0)
Chris, What are you saying the the relationship between the origiHxnal pinned crank vs. the billet crank in regards to your connecting rod failure? Is there something about the pinned crank that allowed the rods to fail? Not seeing the relationship.
Just saying the connecting rod is the next weak link. And 200.00 to pin and weld yours looks good compared to 1,800.00-2,000.00 for a billet crank. but in reality it's the down time that's not replacable so if your trying to decide what to do. Just think what it would be like to not have a ride next time all your buddies go out to play.
bioaction2 is offline   Reply With Quote
Old March 16th, 2011, 09:37 AM   #8
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Thanks for the replies.
Driving time is precious, but I think I'm going to run pin/weld under 7K for now with factory gear. If I determine I need more boost and RPM, I will rip it apart again and start over. Could do it in half the time next go around and have the parts pre-staged. If I had the parts, I could completely rebuild this engine in a long weekend. -This is all providing I don't break a rod at 6300-6500 RMP at 11lbs of boost and destroy its guts. Going to roll the dice and hope
Old March 16th, 2011, 10:17 AM   #9
clownracing's Avatar
Member #5449
View clownracing's Photo Gallery(0)
Look on EBAY, you can buy just the replacement connecting rods and yes there are companies out there that can take apart a stock crankshaft from a rzr and replace rods, but for the price I would just buy the hotrods replacement stock stroke crankshaft??? mpo....
I looked on ebay under rzr hot rod... also rzr crank for rebuilt stock crank...
clownracing is offline   Reply With Quote
2008 rzr 800 broken connecting rod
2012 polaris rzr 800 forum/engine connecting rod problems
can i rebuilt stock crank and connting rod 2012 570 rzr
can you just replace a connecting rod on 08 rzr 800
change rod bearing on polaris rzr 800
polaris ranger connecting rod pin scared
polaris rzr 900 xp rings connecting rod and crankshaft
polaris rzr connecting rod
polaris rzr crankshaft bearing failure
replacing the connecting rod on a 800 polaris ranger
rzr 570 rod bearing
rzr 800 bad rod bearings
rzr 900 turbo connecting bearing failure
rzr broken connecting rod
why are rzr rods so common to break
Brakes failed and no emergency brake!!! PC13 RZR 4 Specific Discussion 45 September 17th, 2010 07:04 AM
My connecting rod broke!!!! bioaction2 Forced Induction 15 August 1st, 2010 10:28 AM
Connecting Rods old ranger Engine and Drivetrain 2 March 1st, 2010 06:58 AM
KMS intake failed! emmagator General RZR Discussion 18 May 30th, 2009 05:50 PM
failed crank/connecting rod jlestanguet General RZR Discussion 12 July 31st, 2008 08:01 PM
