U joints on a 800 rzr - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old March 10th, 2011, 11:11 AM Thread Starter
RBz_OFFROAD's Avatar
I have a 08 Rzr and have slack in my rear ujoint. Called Polaris and they said you have to replace whole shaft. Has anyone had this problem? Is there aftermarket ones you can buy? Please let me know trying to get this thing goin again soon. Thanks alot
RBz_OFFROAD is offline
post #2 of 17 Old March 10th, 2011, 04:21 PM
so-illrzr's Avatar
Re: U joints on a 800 rzr
ok i went to tractor supply and got perfect u joint it even has a grease jerk it is a weasler 0270956 metric & b kit 200-7155 that is there # part #on box is 620.010 series:aw10 reference 10.01.00 the size is 54.8mm by 22.0mm or 2.157" by .866" it was 18.99$
found this in another thread, i had to do it last fall also. it is a pita to pull the drive shaft, but it will definitely save you some coin. i got mine at rural king, it's a pretty standard size.
so-illrzr is offline
post #3 of 17 Old March 10th, 2011, 04:35 PM
mschwe's Avatar
I just replaced the U-joints in my 2010 RZRS. The weasler 0270956 did not fit. I just took the failed U-joint down to my local auto parts store. They measured the old u-joint and came up with a Precision #338 u-joint and has a grease jerk . Cost was about $22.00 for both front and rear.
mschwe is offline
post #4 of 17 Old March 10th, 2011, 05:08 PM
so-illrzr's Avatar
i didn't use the part # either, i used the measurements and mine fit fine
post #5 of 17 Old March 10th, 2011, 07:48 PM
georgehine's Avatar
i just did my Front u-joint about 2 weeks ago I am not sure if the rear is the same but i thought it was! I DONT THINK THE REAR U-JOINT HAS INNER LOCKS LIKE THE PRECISION #338. I had O'Riley auto parts get the u-joint it was a "precision #812" "...autozone was able to cross it as well" I had a hard time getting mine off because we couldn't get the front yoke to come off the diff! we ended up knocking the front u-joint out while still in place then put a puller on the yoke and got it off that way.also the manual I think says to pull the skid plate..... we didnt we just pulled it out between the a-arms on the front passenger side. GOOD LUCK
georgehine is offline
post #6 of 17 Old March 11th, 2011, 04:22 PM
silveradols's Avatar
Just take it off and go to your nearest auto parts store and match one up. that's what most people do, because Polaris wants way to much $$ for theirs
silveradols is offline
post #7 of 17 Old March 11th, 2011, 05:35 PM
HawkEng's Avatar
Also, the S model is about 1/16" bigger than the regular model unit.
I specialize in APEX and Z1 conversion kits for the 800. Z1 kits for the 900xp, XP1000, and 1k Turbo. We have a Z1 waterproof belt cover too.
573-579-8295. Check out our custom coach builds too. www.hawkengineering.com.
HawkEng is offline
post #8 of 17 Old December 17th, 2011, 08:25 AM
dfrulla1's Avatar
Might anyone know the part number for the rear yoke by chance? Mine has some slack and I want to change it and u joints while doing an engine rebuild.
dfrulla1 is offline
post #9 of 17 Old December 20th, 2011, 04:22 PM
3012red's Avatar
Which one fits a reg 50in RZR? a 812 or the 338? I got the 338 per this site, but am now wondering if I got the wrong durn one. Again, I don't have a S model.
3012red is offline
post #10 of 17 Old December 31st, 2011, 10:22 AM
alivenwellntx's Avatar
i have an 08 standered 50" rzr and the 338 will NOT fit the front (of mine anyways).
alivenwellntx is offline
post #11 of 17 Old December 31st, 2011, 10:39 AM
3012red's Avatar
Well, that figures. I either read it wrong, or some one put some bad info on here, which I have passed on. Guess I'll have to take the 338s back and trade them in on a couple of 812s. Oh well, at least I didn't have it all tore apart yet, as I always have to rder stuff, as all of the local auto part stores never seem to have what I need or want. But they sure can have it here in one to seven days!!!! Thanks for the reply.
3012red is offline
post #12 of 17 Old December 31st, 2011, 12:49 PM
jerrzr's Avatar
Go by the dimensions. The weasler 620.010 and precisicion #812 have the same specs and will work on 08 rzr.. Overall length 55mm and bearing diameter of 22mm..
jerrzr is offline
post #13 of 17 Old December 31st, 2011, 01:24 PM
3012red's Avatar
I like to have the part number befor I get to town, as a lot of the counter help arond here couldn't learn to say "Can I super size that for you?" SO they had to go work in a parts store!! And I can't measure it if I ain't got it apart yet!!!! But thanks any way, I am going to trade the 338s in a some 812s. And then all of my dreams will be happy ones.
3012red is offline
post #14 of 17 Old December 31st, 2011, 03:19 PM
jerrzr's Avatar
Just take the old ones out first and take them to town with you to match them up with the new ones....you will sleep real well then because there will be no suprise when you go and install the new ones.
jerrzr is offline
post #15 of 17 Old January 2nd, 2012, 09:45 AM
i had a hard time finding them in stock anywhere but the precision 812 is what ended up fitting my rzr , i found them at oreily auto parts , i went to two different tractor supplys to try and find the weasler 620.010 but they didnt have them in stock .
HELP ! i need U-Joints ! rzrwrecker General RZR Discussion 12 January 31st, 2012 03:08 PM
replacement CV joints? racerxj17 Engine and Drivetrain 4 October 17th, 2009 05:45 PM
Are my CV joints going bad? sr12345 Engine and Drivetrain 2 May 26th, 2009 06:36 AM
CV joints kedi Engine and Drivetrain 1 February 11th, 2009 08:41 AM
CV Joints BigDog_Arizona General RZR Discussion 27 February 29th, 2008 07:38 AM
