  #31 (permalink)
Old October 9th, 2008, 07:10 AM
RZRCRZY's Avatar
My RZR: 2008 Gen 2 or 3
Re: low idle
Sounds like some of you are getting dust past your filter and into your engine. Have a compression / leakdown test perfomed, get a free engine rebuild and throw that crappy airbox away and get a DFR or UMP to fix all your dust and idle issues...just my 2 cents...
Remove advertisements
Sponsored links
  #32 (permalink)
Old October 9th, 2008, 06:15 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
Yep RZRCRAZY I'm sure that was the deal, theyare going to rebuild the engine. But the only other problem is now that there is the air filter fix in the works, if it is a dust ingested related problem using an after market airbox or filter Polaris may not cover it. Thanks for the input tho.
  #33 (permalink)
Old October 10th, 2008, 08:37 AM
RZRCRZY's Avatar
Re: low idle
Good point. It is always best to check with your local dealer before installing aftermarket products. If you buy the parts from the dealer, they typically take care of you. I found DFR parts are cheaper when I go through Polaris...
  #34 (permalink)
Old October 12th, 2008, 10:56 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
Ok, now I'm getting really confused... They did the upper teardown, and found nothing wrong ???? They have had the RzR for 1 month now..
They tell me that when they call polaris they put them on hold for like an hour then ask them to test something then call them back,,, and when they do they are on hold again, and they can only do so much inna day. So some of you are mechanics out there, is it really like this ?
  #35 (permalink)
Old October 13th, 2008, 12:37 PM
ahunt84's Avatar
RZR Rider Ky
First Name: Adam
My RZR: '08 Green RZR
Re: low idle
Did they ever do a leakdown test?
  #36 (permalink)
Old October 13th, 2008, 01:34 PM
RZRCRZY's Avatar
Re: low idle
Or compression?
  #37 (permalink)
Old October 13th, 2008, 09:24 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
Yes to both, they got a 190 befor they replaced the fuel pump, then got a 132 after they replaced the fuel pump, the did the teardown and found nothing really wrong, not even a stuck valve. I need to ask them tomorrow about the compression issue if they didnt find anything, or check into a lemon law lawyer.. its been over 30 days now and made 2 payments...
  #38 (permalink)
Old October 28th, 2008, 09:16 PM
**JM**'s Avatar
Re: low idle
What's the latest news?
  #39 (permalink)
Old October 29th, 2008, 10:09 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
Getting top end re done, Supposedly, carbon build up on the piston and rings caused the problem, I hope to hear from them tomorrow.
  #40 (permalink)
Old November 12th, 2008, 10:39 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
Update: They got the engine back together, but found that they needed to fix the original issue. The TPS(Throttle positioning sensor) was bad, and now I have to wait again for that to come in...
  #41 (permalink)
Old November 13th, 2008, 08:23 PM
BlackBart's Avatar
Black Bart
First Name: Bart
My RZR: Fully Loaded RED RZR
Re: low idle
How did they diagnosis that the TPS was bad?
  #42 (permalink)
Old November 13th, 2008, 09:58 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
I was told that it had poor or no idle and it pulled a code that pointed to the tps.
  #43 (permalink)
Old November 17th, 2008, 10:51 PM
QuadRoPed's Avatar
First Name: Jesse
My RZR: 2008
Re: low idle
Update... Traded it in for a new '09 LE, Didnt want to deal with it anymore.
ended up a few K's upside down but in the long run got way better financing, and I get to ride.
Sponsored links
