Old July 22nd, 2008, 12:35 AM
ak_stick's Avatar
AAAMAD
First Name: Stick
My RZR: 08
Send a message via Yahoo to ak_stick
Linkage issue.
Hey guys. I've got a new Rzr, just 100 miles on it, and now its developed an issue, when I shift to low, it reads neutral, but engages low. If I shift to High, it reads low, but engages low.
The kicker, if I engage AWD, in high, it works, but in low range, I don't get AWD at all, even with the switch thrown.
Ideas?
Only angels and aviators have wings.
Remove advertisements
Sponsored links
Old July 22nd, 2008, 04:30 AM
ohiotodd's Avatar
razor abuser
First Name: todd
My RZR: 3rd gen red
Re: Linkage issue.
your not getting awd because it thinks your in neutral your shift linkage is fine cause youve got the gears you want its the sensor thats your problem its on the motor there behind the drivers rear tire follow your shift linkage back and youll see it there with the linkage it has 1 bolt holding it down it tells the brain what gear your in just slightly losen the bolt and rotate the sensor till you display reads right you dont rotate it much at all just nudge it then check your display repeat till its right
itp wheels, maxxis bighorns, custom cage, custom diamond plate roof, suicide doors, front and rear bumpers, winch, lonestar weld in gusset kit, utv crap frame tubes, full skid plate,clutch spacer removed, epi clutch, kms intake, ehs racing airbox, fmf exhaust, dobeck tfi box, bored throttle body, 4 point harnesses , lock n ride storage box , 2 lock n ride gas cans , all 3 polaris storage bags
Sponsored links
