Oil in Stator Cover???? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Oil in Stator Cover???? within the Engine and Drivetrain forums, part of the Technical category; Ok I dont know if this is a stupid question or not but is the Stator/Flywheel cover suposed to be full of oil??? I have ...
Old October 19th, 2010, 09:16 PM   #1
theanimal's Avatar
Member #776
View theanimal's Photo Gallery(0)
Ok I dont know if this is a stupid question or not but is the Stator/Flywheel cover suposed to be full of oil??? I have never worked on one of these motors before but I know that on all of my quads and dirtbikes over the years the flywheel was dry.
Anyway if it isnt suposed to have oil in it I guess its time for some serious work.
theanimal is offline   Reply With Quote
Old October 19th, 2010, 09:20 PM   #2
odtodd1az's Avatar
First Name: Todd
My RZR: 2008 gen II, Whiplash and /SCORE car crew chief
Member #337
View odtodd1az's Photo Gallery(2)
Re: Oil in Stator Cover????
No that housing should be dry. sounds like a bad crank seal. Most of the time its the other end that starts to leak, right after a drive belt blows apart. Time to yard the motor out.
2008 RZR bought wrecked
2006 red Ferg-Fab Ranger
2006 Outlaw, 06 TB for her, Roketta for daughter
Iron City Polaris RZR 3rd place Whiplash champion
Afraidium RZR 2008 SCORE Champion
2006 WW FSCV2800
2003 GMC 2500 to haul it all around
odtodd1az is offline   Reply With Quote
Old October 19th, 2010, 09:26 PM   #3
theanimal's Avatar
Member #776
Yard it out?? Because of a seal...
The motor only has about 80 hrs on it.
Does anyone know if I can replace the seal without splitting the cases??
I know it can be done on the pto side but is this side different?
This sucks
Old October 19th, 2010, 09:28 PM   #4
King of crash!
Member #787
ask milos or bart they have both had theirs apart
Old October 19th, 2010, 10:32 PM   #5
Feedback Score: 8 reviews
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
View milosusa's Photo Gallery(27)
This sucks
No, you don;t need to split engine, front crank seal is actually in front cover of the engine. But you need to pull engine out to do that, if you will buying parts don't forget to buy front cover gasket too. Plus you will need puller for magneto, I used chevy balance puller, but MCX is selling very nice one now.
Number one is the front crank seal.
milos
2015 Sandstorm F350 GSLR
09 Raptor 700
14 RZR XP Z1100
http://czechracingteam.com/
milosusa is offline   Reply With Quote
Old October 20th, 2010, 04:13 AM   #6
theanimal's Avatar
Member #776
Thanks for the replies.
The motor is already out so I guess im half way there already.
Old October 20th, 2010, 08:20 PM   #7
theanimal's Avatar
Member #776
Ok I pulled off the cover behind the stator and guess what I found. The crank seal wasnt even pressed in the hole. It was just kinda cocked sideways sitting on the crank.
Anyways it doesnt look like I will have a lot of trouble getting it back up and running. Thanks for the info guys.
03 500 predator stator cover
03 polaris predator 500 crank seal
05 polaris predator 500 forum
2003 polaris sportsman 700 magneto crank seal
atv oil in the flywhe cover
how to install a crank seal on 03 500 predator
oil in stator cover
polaris 500 oil on the stator
polaris predator 500 oil in stator cover
polaris rzr inmer stator cover change
polaris sportsman 335 oil in magneto
polaris sportsman 500 oily water leaking from pull start cover
predator 500 damaged stator cover
predator 500 oil in flywheel
why is oil in the flywheel case
Stator shalamara RZR 170 Specific Disccusion 3 October 12th, 2010 07:00 PM
Do you have to pull the motor to get the stator cover off? TheRealBuzz Engine and Drivetrain 14 May 29th, 2010 08:17 PM
stator capacity.....? rg25911 General RZR Discussion 4 April 27th, 2010 09:11 PM
?rewound stator? strracerx Lighting, Stereo and Electrical 1 January 24th, 2010 11:22 AM
09 RZR Stator wheelman20012002 Polaris RZR Parts For Sale 0 September 20th, 2009 07:18 PM
