Temp sensor for cooling fan - Polaris RZR Forum - RZR Forums.net
This is a discussion on Temp sensor for cooling fan within the Engine and Drivetrain forums, part of the Technical category; Does any no where this sEnsor is located? Fan is intermittent from the min u turn the key on. All connections look good at radiator. ...
Old October 19th, 2010, 06:47 AM   #1
trailblazer's Avatar
First Name: james
My RZR: '08 red
Member #867
View trailblazer's Photo Gallery(0)
Does any no where this sEnsor is located? Fan is intermittent from the min u turn the key on. All connections look good at radiator. I'm sure I got something jacked up at sensor. Need help locating
trailblazer is offline   Reply With Quote
Old October 19th, 2010, 07:27 AM   #2
Feedback Score: 8 reviews
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
View milosusa's Photo Gallery(27)
Re: Temp sensor for cooling fan
On the engine is only one temperature sensor, one next to thermostat housing
I think this sensor send temperature reading to ECU which control the fan on/off operation. IMHO
milos
2015 Sandstorm F350 GSLR
09 Raptor 700
14 RZR XP Z1100
http://czechracingteam.com/
milosusa is offline   Reply With Quote
Old October 19th, 2010, 08:03 AM   #3
TURBO'S RULE
allcool's Avatar
My RZR: 2010 rzrs
Member #11295
View allcool's Photo Gallery(7)
Temp sensor is on the head.
As a fail safe, if the plug gets disconnected the fan will run continuously.
If the the plug comes loose intermitantly making/breaking connection the fan operation will be erratic/intermittent also.
allcool is offline   Reply With Quote
Old October 19th, 2010, 08:28 AM   #4
First Name: james
My RZR: '08 red
Member #867
Allcool, that is exactly what I'm experiencing. Thank u both. Ill check it out tonight
Old October 25th, 2010, 02:57 PM   #5
First Name: james
My RZR: '08 red
Member #867
wanted to let you guys know, i found the issue, wire loom chaffed and grounding out on the frame.
thanks for the help. the info was spot on.
Old April 13th, 2013, 06:21 PM   #6
Kr211v's Avatar
Member #54266
View Kr211v's Photo Gallery(0)
My fan won't come on unless I hard wire it
Kr211v is offline   Reply With Quote
2004 polaris 330 magnum fan won't stop
2009 polaris ranger 700 temperature sensor
4010934 polaris
heat sensor on 800 polaris
how to change heat sensorr polaris 500
how to change temp switch on polaras 700 xp
polaris 700 sportsman fan runs
polaris ranger 800 raditor fan sensor
polaris ranger temp sensor location
polaris rzr 800 thermostat sensor
rzr temp sensor
the oil cooler fan on my 2006 trail boos wont shut off
trouble polaris trail boss message hot check engine
where is the power module and the thermister locater at on my 2006 polaris trail boss
will a bad water temp switch make myrzr not run when hot
Water temp sensor location ccie6872 General RZR Discussion 13 June 13th, 2015 01:34 PM
RZR cooling fan rockstar Polaris RZR Parts For Sale 0 October 14th, 2010 06:24 PM
Used RZR Cooling Fan hav19 Polaris RZR Parts For Sale 1 June 7th, 2010 10:43 AM
Code 42 engine temp sensor circuit? fast eddie Engine and Drivetrain 5 October 24th, 2009 07:33 PM
Inline Water Temp sensor leaking ccie6872 General RZR Discussion 2 January 27th, 2009 05:53 AM
