clutch torque - Polaris RZR Forum - RZR Forums.net
clutch torque
This is a discussion on clutch torque within the Engine and Drivetrain forums, part of the Technical category; could someone tell me the torque for the clutch bolt on an 08 rzr...
Old October 15th, 2010, 06:01 AM   #1
delmar71's Avatar
Member #4644
View delmar71's Photo Gallery(0)
clutch torque
delmar71 is offline   Reply With Quote
Old October 15th, 2010, 07:47 AM   #2
sandjunkie's Avatar
First Name: Phil
My RZR: 2014 XP41K
Member #9682
View sandjunkie's Photo Gallery(4)
Re: clutch torque
I have the 09 spec's, Driven clutch 17 ft. lbs.,Drive clutch 40 ft.lbs.Those numbers are straight out of the 09 service manual.
sandjunkie is offline   Reply With Quote
Old October 15th, 2010, 10:07 AM   #3
delmar71's Avatar
Member #4644
Re: clutch torque
the numbers should be the same.thank you.
2009 polaris rzr clutch torque specs
polaris ranger clutch torque
polaris ranger primary clutch torque
polaris rzr clutch torque#gsc.tab
rzr clutch torque
rzr primary clutch bolt torque
rzr primary clutch torque
rzr primary clutch torque specs
torque spec for clutch on polaris ranger
what torque for polaris drive clutch
what torque should polaris drive clutch
torque hommer1 General RZR Discussion 18 June 30th, 2012 11:48 AM
Lug Nut Torque RatPatrol General RZR Discussion 37 February 20th, 2011 12:03 AM
Lug nut torque Kip Wheels and Tires 11 October 25th, 2009 11:02 PM
Clutch Torque Question jaywebguy Engine and Drivetrain 3 September 7th, 2009 12:56 PM
Torque Help FastCarrera Wheels and Tires 1 May 29th, 2009 06:31 AM
