Yes, it is a PCV, keep confusing the letters with plastic pipe. It won't hook up because the electrical connections are different. They must have changed with 2011's with the new firing/injector configuration.
My original question does not matter anyway. Also had to take the Muzzy back off ,after a mear twenty minutes run time I almost cooked the injector wiring, the fuel lines, and the case vent. There is not enough clearance between the exhaust and all the injector components. I compared my 2011 to a 2010 and all the components stand higher on the 11's. Or at least they do on an 11 RZR4.
Obviously vendors are assuming the everything is the same on 11's.
