Codes 51/52. Acceleration problem..... - Polaris RZR Forum - RZR Forums.net
This is a discussion on Codes 51/52. Acceleration problem..... within the Engine and Drivetrain forums, part of the Technical category; My 08 Gen 2 started sputtering under hard acceleration, so I checked the codes and found 51/52/25. I serched and found lots of info on ...
Old August 5th, 2010, 08:17 AM   #1
MDEVO's Avatar
My RZR: 08 RZR with some goodies
Member #9586
View MDEVO's Photo Gallery(0)
My 08 Gen 2 started sputtering under hard acceleration, so I checked the codes and found 51/52/25. I serched and found lots of info on fuel pump issues so I think that may be the issue, just trying to find a gauge to measure fuel pressure. It starts fine and does not fall on its face untill I hit the throttle to the floor. I looked at the wiring harness and checked around for grounding issues but found nothing. Gona order a fuel pump just incase......
Any other suggestions?
Thanks....
THE ONE WITH THE MOST TOYS WHEN HE DIES
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>WINS
MDEVO is offline   Reply With Quote
Old August 5th, 2010, 09:18 AM   #2
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
Re: Codes 51/52. Acceleration problem.....
You need a gage with a connector to attach to the schrader valve on the fuel rail.
I bought the master kit from Harbor Freight that has all kinds of attachments. Used it several times now for mine and other RZR's.
Good chance it is your pump. You want 39psi on the rail.
Just saw your from Canada. What do you have, Northern tool up there??? Harbor Freight of the North.
bagman is offline   Reply With Quote
Old August 19th, 2010, 08:54 PM   #3
MDEVO's Avatar
Member #9586
Finally had time to put the new fuel pump in, and test her out. NO CHANGE! It is still hesitating/popping upon hard accelleration around 4500rpm. I added more fuel with the controller and it did not seem to help much. Back to the drawing board I guess.
What other issues arise from the code 51/52. Do the injectors go bad?
Id hate to have to bring it to the dealer............. help please!
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>WINS
Old August 19th, 2010, 09:19 PM   #4
Banshee84's Avatar
First Name: Andy
My RZR: RZR S
Member #7051
View Banshee84's Photo Gallery(7)
I'm not at the shop but i believe 51 and 52 is injector 1 & 2 short to ground or short to hot. Code 25 is temp. sensor short to ground or short to hot. Had a rzr give me these codes after a motor rebuild. Found it was a bad conection at the the solenoid. Be sure to check all major power conections hot and grounds. Hope this helps.
Banshee84 is offline   Reply With Quote
Old August 19th, 2010, 10:15 PM   #5
rzrnaz's Avatar
My RZR: 2014 XP4k
Member #1446
View rzrnaz's Photo Gallery(0)
Had the same codes and it was a loose ground at the battery.
2010 S
DynoJet PC-V with autotune module
HIDs from Endi at Sidexside Customs
Makin Trax progressive springs
Opti-Air 600 filter with in-bed mount
25" Haulers
Axia Alloys Mounts
LE33 Weekend Warrior
rzrnaz is offline   Reply With Quote
Old August 22nd, 2010, 02:11 PM   #6
MDEVO's Avatar
Member #9586
Thanks for the replys.
I found the problem, the G3 DFR fuel controler! Figures...last thing I looked at.
Not sure why it is causing the problem, guess I'll call DFR and see if it can be fixed.
Cheers
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>WINS
2007 polaris ranger not aacelerating properly
2008 polaris ranger code 51
2008 polaris rzr sputtering during acceleration
2010 polaris ranger sputtering under acceleration
code 51
code 51 on polaris ranger
codes 51,52 ,54 on rzr polaris
polaris ranger acceleration problems
polaris ranger error code 51
polaris ranger error code 51 4
polaris rzr acceleration problems
polaris rzr code 51
polaris rzr sputtering on acceleration
rzr s sputtering under hard acceleration only after its hot
slippage on very low acceleration RZR 4 ROCKSTAR Engine and Drivetrain 4 April 21st, 2010 01:27 PM
New RZR and acceleration hancop General RZR Discussion 11 April 16th, 2010 05:50 PM
codes rzrwrecker General RZR Discussion 10 March 19th, 2009 07:38 AM
Acceleration for my 09 RZR mister General RZR Discussion 17 March 2nd, 2009 06:43 AM
codes pateneaude_34 Engine and Drivetrain 3 September 15th, 2008 02:39 PM
