Old June 30th, 2008, 05:17 PM
First Name: Terry
My RZR: 08 Green RZR
engine breather tube
Why is the breather tube coming from the valve cover to the air box split? One tech said it was there to keep it from over pressuring the system, but if it goes to the air box how would it over pressure? From what I understood all RZR's come with this setup. I replaced mine with a solid hose to to keep water and mud from getting in.
www.dirty4man.com
Remove advertisements
Sponsored links
Old June 30th, 2008, 06:30 PM
DA INFERNO's Avatar
Re: engine breather tube
I was told it is so condensation (or water can drain) wont freeze in cold climates.
06 CHEVY 2500 HD
07 LE3305 WEEKEND WARRIOR
05 PREDATOR 500 (4 SALE)
05 LTZ-250
01 SCRAMBLER 50 (4 SALE)
08 RZR (GEN 3)
http://www.dieselplace.com/forum/gar...do=view&g=6876
Old June 30th, 2008, 08:12 PM
First Name: Terry
thanks for the response, but the split faces upward so I assume this isn't a drain of any sort.
www.dirty4man.com
Old July 1st, 2008, 12:25 AM
milosusa's Avatar
My RZR: 2008 Red
[quote=dirty4man;27470]Why is the breather tube coming from the valve cover to the air box split? One tech said it was there to keep it from over pressuring the system, but if it goes to the air box how would it over pressure? From what I understood all RZR's come with this setup. I replaced mine with a solid hose to to keep water and mud from getting in.
I am wondering about same thing, why is a cut in the hose, they even have white mark for it. It is going to air box and don't have any restrictions on the way to have danger of blowing that hose.
milos
2008 Attitude TH
04 raptor 660
06 raptor 700
08 RZR
Old July 1st, 2008, 05:10 AM
fanjules's Avatar
Also doesn't that kind of undo the work of the peeps that have put an air filter at the intake between the seats?
Old July 1st, 2008, 05:16 AM
Cordachine's Avatar
Look'n 4 da deep stuff!
First Name: Don
My RZR: Red 08 Gen III
I replaced my hose with one withOUT a slit. I am all about the no water/mud/dirt getting into the engine.
08 Popo RZR and 02 Sportsman X 500 HO (mudder) (dead)
RZR mods: 30" Mudzillas on 14" SS108, 3000lb Winch, K&N Air Filter, 3" Xtreme Lift Kit, HL springs, Custom snorkle, Deluxe front and rear bumpers, Rock slider nerf bars, Sport roof, FMF pipe, 1 1/2" Wheel spacers!
Old July 1st, 2008, 05:44 AM
The manuel doesn't list anything about this split in the hose
Old July 1st, 2008, 05:57 AM
fanjules's Avatar
Can't you just vent the gases to the atmosphere instead? Do they have to be recirculated??? This is just the breather for emmissions, right? I don't even know why it's there when the RZR isn't emmissions regulated? What do you snorkelling types do?
Old July 1st, 2008, 06:25 AM
Like Cordachine said change the hose if you are snorkeling. This hose leads striaght into the motor if sand, water, or mud was to enter...not good!
08 RZR
26" Bighorns, SS112's, Snorkeled, stereo
  #10 (permalink)
Old July 1st, 2008, 06:44 AM
stroker0836's Avatar
My RZR: the green one
the hose is split in case the condensate, in cold ,winter, riding conditions would freeze and cause the pressure in the case to blow the dipstick out of the tube or worse. a solid tube is fine in warmer areas but in the midwest and northern parts of the country leave the tube alone. now if you don't ride in the winter it makes no diff. wether the tube is split or not.
  #11 (permalink)
fanjules's Avatar
Found this post on the other forum about the slit: PRC Ranger Club, LLC :: View topic - Snorkel kits/ air box
Almost a duplicate of this thread!
  #12 (permalink)
Old July 1st, 2008, 07:19 AM
megadesertdiesel's Avatar
Rhino defector
My RZR: green gen 3 racer
its a crankcase breather air in air out. my UMP airbox came with a new hose without a slit and a better fitler media for the end of the hose.
  #13 (permalink)
Old July 9th, 2008, 07:12 PM
First Name: Terry
thanks to all for the info, I replaced it with a solid hose. I don't have to worry about cold weather here.
www.dirty4man.com
Sponsored links
