clicking in front end when turning, coming from the wheels
Old June 10th, 2008, 01:09 PM
RZR-LTR450's Avatar
RZR-LTR450 RZR-LTR450 is offline
RZR rider 4 life
First Name: Dale
My RZR: gen. 3 08
i have about 16 hrs on my rzr and i clicks in the front end when turning, it is worse on the passenger side. anyone seen this. i was thinking it is the cv joints going out.
Re: clicking in front end when turning, coming from the wheels
Old June 10th, 2008, 01:10 PM
RZR-LTR450's Avatar
RZR rider 4 life
First Name: Dale
My RZR: gen. 3 08
Old June 10th, 2008, 01:43 PM
Johnny's Avatar
Johnny Johnny is offline
UTVCRAP*****
First Name: Johnny
My RZR: the red one
probley not cvs sometimes just click
www.utvcrap.com 623-934-3070
623.934.3070
Old June 10th, 2008, 08:18 PM
trailblazer trailblazer is offline
mine has 50 hrs on it and it just started doing the same exact thing, johnny no disrespect but it is much louder than what ur suggesting is "normal", guess "ltr" and i are the only ones out there with this problem? anyone else had this?
Old June 10th, 2008, 08:25 PM
mines just started doing the exact same thing, much, much to loud to be "normal", we cant be the only 2 with the same problem, any else out there having or had this issue?
Old June 10th, 2008, 08:36 PM
snack747 snack747 is offline
mines got bout 40 hours and around 700 miles and it just started on the front passenger corner is the only one that does it. after looking at it we came to the conclusion that it was the brakes cauise they were rubbing a little, anyhow rzrz are prone to braking hubs which can cause the cvs to go out if its not fixed. it will make that clicking noise and the way to check if the hubs are broke is jack it up and grab the tire by the top and bottom and see if it rocks and if it does you just solved your problem. hope i could be a help
Old June 10th, 2008, 08:53 PM
wildmanMG wildmanMG is offline
First Name: Phil
My RZR: 2008 Green GEN3 RZR
Send a message via AIM to wildmanMG Send a message via MSN to wildmanMG
mine had a clicking on the driver side, sounded just like a cv joint. to it to the shop and it turned out to be dried up in between where the axle goes through the bearing. The mechanic put some anti-seize compound in there and put the hub back on and I have had no problems since.
Old June 10th, 2008, 10:11 PM
Makin' Trax's Avatar
Makin' Trax Makin' Trax is online now
I have been installing a LT kit from Mafia on the UTV Offroad Magazine RZR. What I found is that all the pivot points holes are so oversized that the bolts have almost an 1/8" slop. You can loosen the a-arms and the hub bolts in the rear and change the camber from negative to positive. We installed weld washers to remove to play. Check these points and make sure everything is tight. Also the bolt that holds the ball joint to the front hub was worn and allowed movement.
Old June 11th, 2008, 06:37 AM
RZR-LTR450's Avatar
RZR rider 4 life
First Name: Dale
My RZR: gen. 3 08
Thanks guys i appriciate the info. I checked the wheels and the front end feels tight all the way around, its still under warranty, im going to take it to the dealer, let you guys know what they say.
  #10 (permalink)
Old June 11th, 2008, 07:13 AM
cartersotr cartersotr is offline
My RZR: GEN 1
50 Hours On Mine Took It In For Rattling. They Changed Passenger Cv Said Was Bad. Got It Back Rode Two Hours Rattling Again. Coming From Drivers Side. Its Back At The Shop!
  #11 (permalink)
Old June 11th, 2008, 07:39 AM
firehawk001 firehawk001 is offline
First Name: Darr
thought mine was doing the same thing..got about 60 hours...turns out the winch had some slack and the hook was rattling...luckily i'm not a complete idiot and didnt take it to the shop
  #12 (permalink)
Old June 11th, 2008, 12:04 PM
wgladde's Avatar
wgladde wgladde is offline
Will Gladden
First Name: Will
My RZR: Green 08
I have front clicking coming from my front left guess I'll take her in. I only have 14 hrs of pretty easy riding. I'm afraid these things aren't going to be tough enough for me. Wish Honda would enter the SXS market.
  #13 (permalink)
Old June 11th, 2008, 01:56 PM
My RZR: GEN 1
they are
  #14 (permalink)
Old June 11th, 2008, 07:27 PM
boatnaz's Avatar
boatnaz boatnaz is offline
My front right was clicking, changed the cv and no more clicking. Now my right rear is clicking. I usually ride very hard wot.
  #15 (permalink)
Old June 12th, 2008, 01:17 AM
ldb ldb is online now
First Name: Kevin
My RZR: Red
Mine clicks and a friend of mine has one that also clicks. I will wait until something breaks and we will all know what the real problem is.
| Home | FAQ | Members List | Calendar | Today's Posts | Search | New Posts |
