Intake popping noise - Polaris RZR Forum - RZR Forums.net
This is a discussion on Intake popping noise within the Engine and Drivetrain forums, part of the Technical category; I have done several searches, so if this has been discussed point me in the right direction. The only thing I could find is that ...
Old April 25th, 2010, 08:06 PM   #1
Rustynuts's Avatar
First Name: Brian
My RZR: 2009 RZR-S
Member #8095
View Rustynuts's Photo Gallery(2)
I have done several searches, so if this has been discussed point me in the right direction. The only thing I could find is that popping in the intake is from a lean condition.
When I bought my RZR-S last year I put a UMP filter on it and have no other engine mods at all and was told this was fine. Later I installed a clutch kit and started to get a little popping in the intake at around 6300 rpm and was told it was from the rev limiter. The last 2 times out in the dunes I have noticed I am getting more popping and at lower RPMs, today it was popping at 5400 rpm. Could it be that the filter is getting dirty enough to be leaning it out? I pulled it and it still looks pretty clean (except from the dog hair) I have a new filter and thought I would put it in and try that.
TIA
Brian
Rustynuts is offline   Reply With Quote
Old April 25th, 2010, 08:41 PM   #2
Stumpduster's Avatar
First Name: Mike #688
My RZR: 16 1000 XP
Member #1676
Re: Intake popping noise
6300 would be the soft limiter. If the clean filter don't fix it you might want to pull the bed and make sure something isn't loose under there pulling unfiltered air in.
Stumpduster is offline   Reply With Quote
Old April 25th, 2010, 08:49 PM   #3
aka: Bad Influence
loboboy's Avatar
First Name: BAD INFLUENCE
My RZR: 2012 RZR900XP
Member #12630
View loboboy's Photo Gallery(3)
a dirty filter will make it go rich not lean. Is the popping noise on decel? If so mine does the same thing when i chop the throttle on decel and it is caused bu excess fuel in the pipe that ignites.
loboboy is offline   Reply With Quote
Old April 25th, 2010, 08:52 PM   #4
Screw dunes..show me mud!
MaineRzr's Avatar
First Name: Darren
My RZR: Red 2009
Member #8716
View MaineRzr's Photo Gallery(28)
Just wanted to throw in that a dirty filter will actually cause a RICH condition because you'll be getting less air and the same amount of fuel.
2009 Rzr w/3" Roktek Lift, High Lifter Springs, Snorkeled, Innovate AFR gauge, Thunderhawk Performance Gas Tank Protector, 4000lb. Viper Max Winch, Burke Moto Pros HIDs, Custom Parking Brake, Vent Racing 4 seat conversion
Sport Roof, Dragonfire Harnesses, iRate Customs Grille Insert, Two Brothers Juice Box
27" Zillas on 12" MSA Nuke Wheels w/ -47mm offset, Dalton Industries Clutch Kit,
F & R Brushguards, Rzr S Fender Flares, K&N Air Filter, Muzzy Dual Exhaust, UHMW Skid Plate
MaineRzr is offline   Reply With Quote
Old April 25th, 2010, 08:53 PM   #5
MaineRzr's Avatar
First Name: Darren
My RZR: Red 2009
Member #8716
I guess I take too long thinking and typing
Old April 25th, 2010, 09:13 PM   #6
Rustynuts's Avatar
First Name: Brian
My RZR: 2009 RZR-S
Member #8095
Yea, you guys are right in a dirty filter making it rich.....long day and brain fart. The popping is happening on hard acceleration like approching a dune and then getting on the throttle all the way, the popping stops if I let up on the throttle a little.
Old April 25th, 2010, 09:24 PM   #7
MaineRzr's Avatar
First Name: Darren
My RZR: Red 2009
Member #8716
I'd consider pulling the plugs and seeing what's going on color wise. Change them out and see if it makes a difference. (I always start with the cheap and simple)
Old April 25th, 2010, 10:04 PM   #8
dkiewicz's Avatar
First Name: Dan
My RZR: 2010 Orange Madness LE S
Member #11780
View dkiewicz's Photo Gallery(2)
How many hours on it? This could be a valve adjustment. If the intake is staying open too long, especially at higher rpm under load, you will hear this type of pop because the vale is still open a tiny bit at ignition. It is also possible your ignition timing has changed and this will do a similar thing. Any signs of over heating?
Yes pull the plugs and see if it's running hot, very white carbon not tan. Tan is the color you want. Black is too much fuel, and flaky black and wet is oil. If too hot, white plug, check the timing and valve lash.
dkiewicz is offline   Reply With Quote
Old April 25th, 2010, 10:14 PM   #9
glamisdunes*****
dev's rzr's Avatar
First Name: devin
My RZR: 08 rzr
Member #5605
View dev's rzr's Photo Gallery(2) Send a message via AIM to dev's rzr
i was told it needs a programable e i. unit ... i'm going to glamis next weekend to check it out
[/SIGPIC]
dev's rzr is offline   Reply With Quote
Old April 25th, 2010, 10:21 PM   #10
dkiewicz's Avatar
First Name: Dan
Member #11780
Well that makes sense. It could definitely be timing. Good luck I hope it runs like a beast!!!
Old April 26th, 2010, 12:09 AM   #11
Rustynuts's Avatar
First Name: Brian
My RZR: 2009 RZR-S
Member #8095
I pulled the plug (what a chore!) and here they are, they look pretty good to me. The rear was a little darker than the front and when I went to pull the plug wire it didnt feel like it was locked on the plug all the way....maybe that has something to do with it. Everything was tight on the intake boots so it doesnt look like any air leaks. I got a new filter in it and will pick up new plugs tomorrow. I will also ask the dealer about it and see what they say.
FRONT
REAR
Old April 26th, 2010, 08:38 AM   #12
dkiewicz's Avatar
First Name: Dan
Member #11780
Yeah they look good. You could be onto something with the boot not connected correctly, although I would expect to see a little more fouling because of unburnt gas, but you say it was darker and that would be consistent. The loose wire might explain why it only happens at higher rpm though once you get enough vibration.
It would be interesting to hear what the dealer says.
Old April 26th, 2010, 11:53 AM   #13
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
does it sound similar to this....?
This video was when I installed the turbo kit and the clutch was not adjusted right. It was all over the rev limiter....
Old April 26th, 2010, 08:54 PM   #14
Rustynuts's Avatar
First Name: Brian
My RZR: 2009 RZR-S
Member #8095
Yes, it sounds just like that. I suspect I need to do some changes on the weights of the clutch. I have an email into DDP for advice.
Old April 27th, 2010, 08:20 AM   #15
Feedback Score: 5 reviews
polyol's Avatar
My RZR: 09 RZR
Member #6951
View polyol's Photo Gallery(0)
Does it pop or does it make a ba ba ba sound? Probably hitting the rev limiter like someone else said. Did it do this before? Have you inspected the primary for wear?
polyol is offline   Reply With Quote
4 wheeler makes a popping noise when i let go of throttle
4 wheeler makes a popping noise when i let of the throttle
intake noise
intake popping
intake popping noise
motorcycle intake noise
popping noise on razor 170 under hard acceleration
rzr 800 intake popping sounds
rzr popping through intake
rzr s make popping noise
rzrs top end noise
valve noise
whats lean or rich aem gauge
why is the air filter making popping sounds
yamaha rhino popping in intake
Popping noise in the rear end heathb2003 Engine and Drivetrain 31 June 20th, 2014 04:27 PM
Binding popping noise ryan85 Engine and Drivetrain 11 March 14th, 2010 12:23 PM
Popping noise Help lomac17 RZR 170 Specific Disccusion 2 March 1st, 2010 08:30 PM
loud popping noise when i hit ground 08 redrzr General RZR Discussion 6 February 14th, 2010 04:55 PM
is popping noise normal from my exhaust? mikeylutzy Engine and Drivetrain 6 February 8th, 2010 05:36 PM
