Do you need to split cases to replace crank seal (pto side)? - Page 4 - Polaris RZR Forum - RZR Forums.net
post #46 of 56 Old April 25th, 2012, 08:25 PM
2nd two none's Avatar
First Name: Damon
My RZR: turbo built 800/ 2014 xp1
Member #19563
View 2nd two none's Photo Gallery(0)
Just tear it part and be a godfather?
Sent from my C771 using Tapatalk
2nd two none is offline
post #47 of 56 Old June 30th, 2012, 04:14 PM
Sasq40's Avatar
First Name: Kael
My RZR: 900xp
Member #26967
View Sasq40's Photo Gallery(0)
Re: Do you need to split cases to replace crank seal (pto side)?
so hows anyone whos done this holding up still, any leaks or seal doing its job?
Rzr XP 900
28x12.5 Outlaws with Sti slip kote beads/27 s/w bighorns on stocks painted wheels/5" highlifter lift, shocks cranked down to lowest setting/Random Polaris parts/Front viper 5000, rear superatv 5500/Unisteer PowerSteering/Gorilla Axles/Custom Stereo/S3 rear radius bars, high clearance a arms/Pa doors,harness,trailing arm sliders,door bags/thunderhawk rear plate/piaa lights/Epi mud clutch kit
Sasq40 is offline
post #48 of 56 Old July 30th, 2013, 11:51 PM
JDD23's Avatar
Member #45941
View JDD23's Photo Gallery(0)
Originally Posted by hav19 View Post
The OE Seal is 35mm x 72mm x 7mm (lipped)
I found 2 diifernt seals that will work one is 8mm thick instead of 7mm but there is penlty of room as a matter of fact it fits better then the 7mm one
SKF 14096 = 35mm x 72mm x 7mm
SKF 13923 = 35mm x 72mm x 8mm
[IMG][/IMG]
I cleaned the seal sitting surface on the block really good - I used the "Right Stuff" (item #29208 Permatex) on the outside surface just as added insurance and I lube the seal/Crankshaft surface with a little high temp grease
If you got oil on that belt you can clean until the cows come home....
Here's what I have if you want them, I have both of these seals (they were my spares incase I ever ripped the main seal open again) and I have a Brand new Polairs Belt (3211130) you can have it all for $85 bucks shipped to the lower 48
[IMG][/IMG]
I don't need them any more since the WEBER swap and I'm running a DDP Clutch
Disclaimer: Although this worked perfectly for me, perform at your own risk, we were extremely careful to make sure the seal went in straight and without nicking – I also let the “Right Stuff” dry before changing the engine oil and starting – Good Luck were all counting on you!! LOL
Are the seal number you stated for a 800?
JDD23 is offline
post #49 of 56 Old August 1st, 2013, 08:43 AM
Godfather.'s Avatar
First Name: Frank
My RZR: 900 xp White Lightening
Member #39449
View Godfather.'s Photo Gallery(0)
They are for the 900.
Godfather. is offline
post #50 of 56 Old August 1st, 2013, 12:16 PM
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
Feedback Score: 8 reviews
View milosusa's Photo Gallery(27)
They are not, at least not for 2011 XP 900.
Milos
2015 Sandstorm F350 GSLR
09 Raptor 700
14 RZR XP Z1100
http://czechracingteam.com/
milosusa is offline
post #51 of 56 Old August 1st, 2013, 01:44 PM
Godfather.'s Avatar
First Name: Frank
Member #39449
When I get back home I will try to go see which one I actually used and let you know.
post #52 of 56 Old August 17th, 2013, 10:01 AM
Dirtyd03's Avatar
First Name: shayne
My RZR: Xp 900
Member #57059
View Dirtyd03's Photo Gallery(2)
Anyword on which seal for the 900? Is it the same when taking it out as the 800?
"Build it, Break it, Fix it"
2012 rzr xp liquid silver 30 inch backs muzzy duals and digi tune patv snorkels dirty dawg clutch cobra axles alba radius rods homemade roof and radio pro armor doors and harnesses and more to come
Dirtyd03 is offline
post #53 of 56 Old December 4th, 2014, 05:38 AM
Zavala369's Avatar
First Name: Tommy
My RZR: 2010 Robby Gordon RZR4 Turbo
Member #74956
View Zavala369's Photo Gallery(0)
I was wondering if the seal has held up or did it start leaking again? Can you guys give an update im getting ready to do this to my rzr 4 800
Zavala369 is offline
post #54 of 56 Old March 3rd, 2015, 07:25 PM
rabes's Avatar
Member #20836
View rabes's Photo Gallery(0)
Curious, if there is a seal for the 1000 as well? Thanks in advance
rabes is offline
post #55 of 56 Old November 9th, 2015, 12:49 PM
dirt_racer22r's Avatar
Member #83646
View dirt_racer22r's Photo Gallery(0)
Does this apply to the 800 as well?
dirt_racer22r is offline
post #56 of 56 Old October 19th, 2016, 09:42 AM
planethax's Avatar
Member #163633
View planethax's Photo Gallery(0)
THANK YOU
Hard to get seal here in Canada, ended up costing me $50
for others info, this is a 2002 Sportsman 700
planethax is offline
Gear Cases gtmcgeejr Engine and Drivetrain 1 March 10th, 2010 12:38 PM
Need to replace rear seal - need advice ArtVandelay Engine and Drivetrain 8 March 2nd, 2010 08:40 PM
Looking for cases and crank for RZR DAMAGED HawkEng Want to Buy 5 December 22nd, 2009 03:56 PM
About to order Crank from Crank works. Whats the deal with the Spacer? pioneer6869 Forced Induction 2 September 20th, 2009 06:21 AM
Anyone had a gas tank split yet? Realbadlarry General RZR Discussion 0 October 30th, 2008 06:13 PM
