This is a discussion on Funny belt wear within the Engine and Drivetrain forums, part of the Technical category; All right, I need help from the experts. My brothers drive belt keeps exploding in less than 10 hours of riding. The belt is wearing ...
Funny belt wear
All right, I need help from the experts. My brothers drive belt keeps exploding in less than 10 hours of riding. The belt is wearing on one side and not the other until it just finally goes to shreds. He has tried expensive belts and cheap belts and no change. We have taken the clutch apart to make sure everything is smooth. Could this be an alignment problem? Please help as we are out of ideas and gettin realy tired of changing belts.
| Sponsored Links | ||
Re: Funny belt wear
Yes I would check the alignment. Polaris has a special tool...
But on both of mine the belt barely touches the rear sheave of the primary when the engine is off. If it is in the center of the bearing, touching the front sheave, or rubbing up against the rear sheave excessively, I would say it is out of alignment. There are shim washers under the secondary to align the clutch. add or subtract washers to line it up. While you are in there, check the bearing in the primary to make sure it is turning smoothly. they can get plugged with belt dust and/or burn up. Another thing to check is the washers on each side of the bearing. Sometimes when you blow a belt the high heat will destroy the washers.
______________________________________ My Links: Polaris Parts Microfiche , FREE DOWNLOADS , How to change a RZR clutch belt VIDEO |
Re: Funny belt wear
not sure if this will help you but my first one would shread a belt every hunderd miles or so couldnt figure out what it was so i took one of the shims out from behind the secondary and problem solved for me it has two
Re: Funny belt wear
It sounds like an alignment issue as Cliff has covered well but I would add that these belts do need to be broken in if new, the owners manual does cover this,
John |
Re: Funny belt wear
If it's wearing on one side, and shredding on you quickly, I'd say its an alignment issue.
2009 RZR S MCX Big Bore and Turbo 2010 RZR 4 (stock because I promised the wife not mod it...... I'm teaching my son how to turn wrenches ) 2006 Raptor 700 2000 Honda Foreman (old trusty) |
| Thread Tools | |
| Display Modes | |
| Do you wear a helmet? | Sonnie | General RZR Discussion | 15 | October 10th, 2009 06:09 PM |
| Belt wear and radiator placement? | polarisrzrs | Engine and Drivetrain | 1 | July 6th, 2009 01:42 PM |
| extra wear in awd | jo baldwin | General RZR Discussion | 2 | October 15th, 2008 11:53 AM |
| Wear your seatbelts | LvDirtJunky | RZR and UTV Video's | 3 | October 10th, 2008 08:41 AM |
| belt wear with tracks | weekend warrior | General RZR Discussion | 0 | July 14th, 2008 03:51 PM |
