rzr will not move in any gear. - Page 4 - Polaris RZR Forum - RZR Forums.net
This is a discussion on rzr will not move in any gear. within the Engine and Drivetrain forums, part of the Technical category; Yeah I dropped the transfer down a lil and jacked up motor just a tad. There's one bolt you can't get to unless this happens ...
Old August 29th, 2012, 08:17 AM   #46
birdmanf250's Avatar
My RZR: 08 RZR
Member #2355
View birdmanf250's Photo Gallery(0)
Re: rzr will not move in any gear.
Yeah I dropped the transfer down a lil and jacked up motor just a tad. There's one bolt you can't get to unless this happens or u take out of vehicle and separate.
FTM 6" Arched Lift
Gorilla Axles
Speed Werx/Hot Seat Performance Custom Clutching
UTV Inc. Intake/Donaldson Filtration
Burke Moto Pro HID's
Custom Tunes w/J Strong Top
birdmanf250 is offline   Reply With Quote
Old August 29th, 2012, 08:21 AM   #47
My RZR: 08 RZR
Member #2355
May have to make a 2x4 wedge or a pry bar to give you the room u needto get the bottom left bolt out.
Also once you buy new pinion shaft. You can weld the two gears together, or purchase the turner upgraded piece which also lowers gear ratio but is like 1600.00$
FTM 6" Arched Lift
Gorilla Axles
Old August 30th, 2012, 04:29 AM   #48
rzr_rider's Avatar
My RZR: 2014 RZR xp 1000
Member #1943
View rzr_rider's Photo Gallery(0)
well finally got the transfer case front plate removed. Pinion shaft is sheared off, but that wasn't the only thing....Alot of pieces of metal fell out when I seperated the case, turns out part #3234568 Cap, Bearing Retainer busted in quite a few pieces. looks like I have to order another part(s),
Laid up for another week or two before that comes in. What a headache this is.....oh well could be worse.
thanks for the help, hopefully soon I can get this back together, before I forget how.
rzr_rider is offline   Reply With Quote
Old August 30th, 2012, 05:30 AM   #49
My RZR: 08 RZR
Member #2355
Good idea to replace the bearings. Always forget to mention that.
Better than paying big money for dealer to work on it!
FTM 6" Arched Lift
Gorilla Axles
Old September 3rd, 2012, 12:04 PM   #50
My RZR: 08 RZR
Member #2355
Update?
FTM 6" Arched Lift
Gorilla Axles
Old September 4th, 2012, 04:18 AM   #51
rzr_rider's Avatar
Member #1943
just ordering parts today, long weekend delayed things a bit....probably be a week or so getting parts in.
Old April 3rd, 2014, 11:24 PM   #52
SRD Composites's Avatar
My RZR: 09 RZR S
Member #62724
View SRD Composites's Photo Gallery(0)
Same issue here only problem is my break is in a different location the part that gave out is (#3234564) it sheared perfectly smooth. the confusion I have is why none of my gears work including park. this is what broke not the main gear also I do not have 4x4 either I did hear a pop when I lost Power and my speedo does still work.
SRD Composites is offline   Reply With Quote
2008 polaris rzr will not pull in gear
2009 polaris rzr 800 will not move when in gear
800 rzr busted belt now will only go in reverse
polaris ranger starts but won't move
polaris ranger will not move
polaris razor wont move
polaris rzr 900 2012 engine run but not move
polaris rzr drive shaft will not sin and move
polaris.rzr. heard snap.now.it wont roll.in gear
rzr 170 runs but does not move forward or reverse
rzr 800 stopped pulling in gear
rzr 800 wont move
rzr 800 wont move in any gear
rzr 900 won't move
what will cause a polaris rzr to not move
Fast in Low Gear or Slow in High Gear? WARPARTY36 General RZR Discussion 9 February 28th, 2010 06:25 PM
Razr is "stuck" High gear and won't move beerseason Engine and Drivetrain 29 November 9th, 2009 08:06 PM
Just Washed, now won't move belandbroc Engine and Drivetrain 9 August 16th, 2009 06:00 PM
RZR170 on the move! jsawyer RZR 170 Specific Disccusion 0 May 7th, 2009 02:36 PM
can't move keowee1 Seats and Belts 1 August 26th, 2008 09:01 AM
