Weep hole oil leak - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old February 14th, 2010, 12:28 PM Thread Starter
Don
DonPro's Avatar
First Name: Don
My RZR: red gen2 +5 LT
Member #648
View DonPro's Photo Gallery(8)
Weep hole oil leak
Two questions.
1. The schematic on Don Woods Polaris site does not show the seal. It shows the bearing on the pump side and the water pump seal but not the rubber seal that goes in the stator cover. Where do I get that part #?
2. The service manual says the stator cover must come off which means the engine must come out. It looks like it could be done with just the water pump removed. Wishful thinking?
Thanks,
Don
Walker Evans Racing Shocks
+5 LT
27" Dirt Tamers
Skat Trac 8s
DonPro is offline
post #2 of 4 Old February 14th, 2010, 02:34 PM
stitch89's Avatar
Member #11363
View stitch89's Photo Gallery(0)
Re: Weep hole oil leak
No i think the seal has to be put in from the inside of the stator cover. If it was leaking water instead of oil it would be the seal behind the water pump cover and could be put in with the engine in. Mine was leaking water from the weep hole had to take it to the shop they said if it was leaking oil instead of water it would be an hour job. So I would bet money the engine has to come out. Do you have a warranty? I hate that for you man.
stitch89 is offline
post #3 of 4 Old February 14th, 2010, 02:36 PM
stitch89's Avatar
Member #11363
Sorry not an hour job but an 8 hour job forgot to add that.
stitch89 is offline
post #4 of 4 Old February 14th, 2010, 04:47 PM Thread Starter
Don
DonPro's Avatar
First Name: Don
Member #648
Ya. I was wondering. Don't think those guys are that fast. It does look like it goes in from the water pump side in the service manual but they say it will damage the shaft if you try to remove or install it with the cover in place.
+5 LT
27" Dirt Tamers
Skat Trac 8s
DonPro is offline
Weep hole weeping Gunny General RZR Discussion 5 December 26th, 2009 08:30 PM
oil leak rzrgriff Engine and Drivetrain 3 August 30th, 2009 01:53 PM
Water Pump Weep Hole BEWARE HivoltageRZR General RZR Discussion 2 April 14th, 2009 09:22 PM
Oil leak ? AZboy Engine and Drivetrain 0 March 10th, 2009 08:15 AM
Oil Leak cisco kid Engine and Drivetrain 3 April 3rd, 2008 09:33 AM
