Holtz Derlin secondary washer?
This is a discussion on Holtz Derlin secondary washer? within the Engine and Drivetrain forums, part of the Technical category; Anybody using one of these? If so, does it make a difference? Info from Holtz website: RZR / RZR-S Anti-Friction Derlin Secondary Washer Retail Price: ...
Old January 25th, 2010, 11:12 AM
gunrunner's Avatar
Member #4830
Retail Price: $3.50
The Holz Racing Products Anti-Friction Derlin Secondary Washer
This washer is designed to help improve backshift performance in the TAS-03 Rubber Damped Team Secondary clutch on the RZR and RZR-S.
Cheap, Simple, Effective...no brainer.
Why is this part important?
A coil spring will naturally want to turn or twist as it is being compressed. This can cause friction and a sort of binding affect which results in inconsistent performance.
Because the Derlin material is self lubricating, this inexpensive little part will help eliminate that problem by giving the spring a smooth surface to turn/twist on while it is being compressed.
Only 1 washer is required
Old January 25th, 2010, 11:16 AM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Re: Holtz Derlin secondary washer?
It is supposed to make the secondary move smoother due to less drag on the spring. I dont think you will see any change on the RZR, maybe good for racing when you are trying to squeeze out every last drop of HP and performance. You can find these washers for the P90 clutch on all the snowmobile sites for a couple of bucks.
1 Limey in a world of Yanks
Old January 25th, 2010, 11:49 AM
Tuf-Skin's Avatar
First Name: Clifford
My RZR: 2009 RZR-S + MCX Turbo Apex (RZR-X)
Member #2228
View Tuf-Skin's Photo Gallery(6)
I bought one when I was getting other stuff from them but I haven't had the secondary apart to install it...
______________________________________
My Links:
Polaris Parts Microfiche , Free Downloads no longer available , How to change a RZR clutch belt VIDEO
Links to Bart's clutching threads
Old January 25th, 2010, 04:33 PM
HOLZTECH's Avatar
holzracingproducts*****
Member #2084
View HOLZTECH's Photo Gallery(0)
Retail Price: $3.50
You could also expect a little longer lifespan for your secondary spring as it will see less stress because it is not binding as much.
Don’t think you are going to buy a $3.50 "performance" part and all of the sudden win drag races, but there is a purpose for the part and it does the job. This is not the single answer to all clutching problems, but a small part of the big picture. Also, to answer some myths, it's not a spacer, just a thin piece of plastic whose sole purpose is to provide a smooth surface for the spring to twist on.
The purpose/function of having this washer is tried and true. This is snowmobile clutching 101 and has been a staple tuning part for almost as long as there have been CVT clutches. There are several suspension companies who sell a similar part for the coil spring shocks.
Racing or not shouldn't matter.
Old January 25th, 2010, 06:14 PM
Tuf-Skin's Avatar
Member #2228
does it matter what end of the spring you install it on?
My Links:
Old January 26th, 2010, 08:36 AM
HOLZTECH's Avatar
Member #2084
I dont suppose it really would except our part is sized to fit under the spring against the clutch sheave. The OD of the washer is too big to fit against the spider plate
Old May 22nd, 2010, 06:31 PM
MotoXXX's Avatar
Feedback Score: 24 reviews
First Name: Jeff
My RZR: 08 with 2010 "S" MCX turbo motor
Member #4542
I took my Team secondary apart today for inspection (my primary is headed to Dirty Dawg Dale as we speak). My build date is in June of 08. My 08 service manual shows a metal "spacer" under the secondary spring. Mine has no spacer there, so I went online to Babbits to look at their parts fiche for the secondary. It does not show a spacer or anything that goes under the spring. Has anyone ever had a spacer on their pre 10/08 build date Team secondary?
Edit:.....Also will the Holz delrin washer fit in this location on my secondary? I can see a benefit to a slippery washer there. On mine you can tell exactly where the end of the spring has been riding on the magnesium inner sheave, there is a shiny spot there.
  #8
Old May 22nd, 2010, 06:38 PM
rzrwrecker's Avatar
ride guide extrodanire
First Name: Skeeter
My RZR: XP LE 900
Member #614
View rzrwrecker's Photo Gallery(0)
none on mine early 07
JOIN NOW www.redbanktrailriders.com
  #9
Old May 22nd, 2010, 07:12 PM
Anthony Oberti's Avatar
My RZR: 09 RZR
Member #7356
View Anthony Oberti's Photo Gallery(0)
I have run Delrin washers on every sled I have owned for years. It is very important with clutching on the snow as spring binding can really affect the performance of your sled. Holz is 100% correct as to why to use this product.
  #10
Old May 22nd, 2010, 07:22 PM
swingarm1's Avatar
TAGTEAM 928-273-4249
Feedback Score: 93 reviews
First Name: Tim
My RZR: XP LE PROCHARGER 10 PSI SUPERCHARGER UTVINC BUILT IRONMAN EDITION
Member #7690
I installed it in mine... Common sense says it has to help... Cheap & easy to install...
I SELL AND INSTALL THE FOLLOWING PRODUCTS...
HOLZ RACING, RACER TECH, PROCHARGER SUPER CHARGER KITS, STAR ISLAND MOTOR SPORTS (OEM PARTS), I REBUILD & SELL STOCK & MODIFIED 800 & 900 ENGINES, AZ HYDROGRAPHICS, STM CLUTCHES, UTVINC 100% AMERICAN MADE PARTS 1ST DEALER
928-273-4249
  #11
Old May 22nd, 2010, 08:32 PM
pawngod's Avatar
My RZR: 09 RZR-s k&t turbo
Member #12452
View pawngod's Photo Gallery(4)
the springs definitely show wear on the ends..the washers make sense, i think they could prolong the life of the springs as well.
09 RZR S k&t turbo
2012 ARCTIC CAT WILDCAT 1000
  #12
Old May 23rd, 2010, 09:27 AM
rzr(s)hroom's Avatar
First Name: kevin
My RZR: 2010 rzr s
Member #14447
View rzr(s)hroom's Photo Gallery(0)
got it..just havent installed it yet
  #13
Old May 23rd, 2010, 10:04 AM
quadnkev's Avatar
Feedback Score: 18 reviews
First Name: Kev
My RZR: Red
Member #610
x2 not yet installed.
  #14
Old May 23rd, 2010, 10:33 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Except for the shipping....$11.56 to send one washer that is $3.50, weighs nothing and can be sent in a letter sized envelope?
  #15
Old May 23rd, 2010, 10:48 AM
swingarm1's Avatar
First Name: Tim
Member #7690
If you tell Matt USPS he'll make sure they do it that way in the shipping department...
Matt actually took mine to the Post Office on his way home from work...
928-273-4249
anti friction washer
changing secondary spring rzr s
delrin rings rzr clutch
derlin washer install on team secondary
does it matter what plate washer i use on the secondary clutch sheave?
has any one tried a tas-03 secondary clutch
holtz clutch
holtz secondary washer
holz delrin washer install
holz derlin washer
holz racing clutch washer
holz racing delrin washer install
holztech clutch washer
how to install secondary spring on 2010 rzr s
polaris rzr clutch washer install
polaris secondary washer
review on holtz clutch
secondary washer
team secondary binding
what is a derlin washer
RZR Derlin A-Arm Bushing Kit SXSHQ SXSHQ 59 July 16th, 2011 01:30 PM
Derlin bushings noisy? quadnkev Suspension 10 October 20th, 2009 06:43 PM
derlin bushings? Moosehumper UTV Inc 9 October 6th, 2009 12:58 PM
Holtz Bumper RGERBER General RZR Discussion 2 September 7th, 2008 02:29 PM
holtz skid any good tysonhonda General RZR Discussion 0 August 29th, 2008 01:11 PM
