Revised/Improved K&N Apollo Air Intake
Old April 27th, 2008, 08:05 PM
LTZ470 LTZ470 is offline
My RZR: Gen 1
Had everything just took the time to modify/improve...
Intake side of Filter...
Throttle Body Side of Filter...
Sand/Dirt knocked out of Filter...
Clean inside of Filter...
Clean inside of filter intake...
Donaldson Dust Extractor installed ($1.71 each) drilled 7/8" hole and stuck it in...
Prefilter installed over Filter...
Filter mounted with Dust Extractor in the down position...
New 3" Polished Aluminum Air Inlets with Silicone Boots...
Re: Revised/Improved K&N Apollo Air Intake
Old May 15th, 2008, 03:48 PM
kimmer's Avatar
kimmer kimmer is offline
Crash Test Dummy
My RZR: 2008
Looks good man! This is my next purchase before I snorkle mine. The stock box is junk and these aftermarket rzr specific ones are a fricken rip off! I found a place online to get the black apollo for $100. Hard to beat that price! Thanks for the info on the apollo!!
2008 RZR-Glacier II plow, Venom 4000x Winch, Amsteel Cable, Rear Brush Bumper, Rear Accessory Rack, 3" Xtreme Lift, 2" Datin Wheel Spacers, HD Springs, EPI Clutch Kit, KIMMER Custom Snorkle, K&N Apollo Airbox, 30" Gorilla Silverbacks On ITP SS106's, Ram Mount With Lowrance H2O GPS-owner of www.s197forum.com
Old May 28th, 2008, 12:26 PM
RedMan RedMan is offline
How does the Donaldson Dust Extractor work?
Old May 28th, 2008, 01:45 PM
My RZR: Gen 1
It drops the sand/dust out the bottom of the filter and won't allow anything to come in...
VACUATOR VALVE, 1", 60 DUROMOTER (P149099)
Old May 28th, 2008, 07:31 PM
guy48065's Avatar
guy48065 guy48065 is offline
If I understand it right the swirling dust settles in the little rubber snout. It gets expelled anytime the engine backfires (common on deceleration).
Old May 29th, 2008, 01:47 PM
kimmer's Avatar
Crash Test Dummy
My RZR: 2008
Anyone had one of these fail on something used in deep mud or water?
Old May 29th, 2008, 03:00 PM
kimmer's Avatar
Crash Test Dummy
My RZR: 2008
Another quick question, did you use anything to seal up the layers of the apollo? Or is there a rubber o-ring gasket between the filter housing layers?
Old July 8th, 2008, 07:50 AM
gdog gdog is offline
Can you post a pic of where the intake tube is mounted to the RZR and how you have that end setup?
Thanks!
Old July 8th, 2008, 09:31 AM
My RZR: Gen 1
Picasa Web Albums - Ailan Cole - RZR Air Intake
  #10 (permalink)
Old July 8th, 2008, 09:46 AM
My RZR: Gen 1
I posted more pictures in these and you can all the components better...this is a better system guys...it does not pull dirt and crap from the CVT notice how I did manage to scoop up a lot of sand so the next cleaning I'll get to see how the Dust Extractor worked...even with the K&N packed with sand the air filter and throttle body were clean...my RZR does not use a drop of oil...and it is bad fast with no internal engine mods...
PRC Ranger Club, LLC :: View topic - Intake Changed out to K&N Apollo
PRC Ranger Club, LLC :: View topic - Revised K&N Apollo System with Dust Extractor & Pref
  #11 (permalink)
Thank you!
So...so far so good? Where did you get that intake piping?
  #12 (permalink)
Old July 8th, 2008, 09:52 AM
My RZR: Gen 1
Originally Posted by gdog View Post
Thank you!
Spectre Performance - Official Site
All 3" lightweight stuff and they have the silicone boots and clamps also...they are cheap and can be purchased from Autozone, Pep Boys, Checker, Etc I am sure...
  #13 (permalink)
Old July 8th, 2008, 11:06 AM
My RZR: Gen 1
Cold Air Intake Product Applications - PRM Racing
  #14 (permalink)
Old July 8th, 2008, 11:00 PM
boatnaz's Avatar
boatnaz boatnaz is offline
What do you have for mods other than the obvious Apollo and Looney Tune pipe?
  #15 (permalink)
Old July 9th, 2008, 12:30 AM
My RZR: Gen 1
MPI ECU with Hot Programming...EPI/HPD Clutch Kit...LTE Fuel Controller...just these few items will put a smile on your face...I tried the EPI Clutch Kit alone and the 70 weights (For a Turbo Snowmobile) were too much dropped to 66 weights standard polaris type and voila she rips...going to try 64's also I used the primary spring from EPI the secondary spring and helix from HPD...still going to try different config's with clutch in future I want all my power used up at 50mph and I want all the horsepower from 0-50 most usable for me and the way i ride...if I want to cruise at 55-60mph I'll use my truck ...
| Home | FAQ | Members List | Calendar | Today's Posts | Search | New Posts |
