Grinding noise? - Polaris RZR Forum - RZR Forums.net
post #1 of 36 Old January 18th, 2010, 07:08 AM Thread Starter
MacLeod's Avatar
Member #12699
View MacLeod's Photo Gallery(0)
Grinding noise/ Popping out of gear
I got my new 2010 RZR S stuck in the snow and broke the belt with 8 KMs on it. Was told I probably should of broke in the belt for longer, and I understand that, makes sense. So i towed it back to the house and put a new belt on and left it for the night. I went to load it the next day on a tilt trailer. when i pulled up to the trailer i was already in AWD and it began grinding (front or back wheels would not spin). So friged with the shifter and moved around the yard where it intermitly "jumped out of gear" (would gring and no tires would spin) mostly while in AWD and under load. I checked the shifter cable and there is no stain on it. I detached the cable on the tranny side and the shifter arm "clicks" between gears so it is not like the cable "holds" the tranny in gear. If a chunk of the belt is stuck in the clutch anytwhere, is it possible to get a grinding noise from something not completley activating?
MacLeod is offline
post #2 of 36 Old January 18th, 2010, 08:00 AM
hoser's Avatar
First Name: Hoser
Member #6551
View hoser's Photo Gallery(0)
Re: Grinding noise?
Sounds like something in the trans to me like the gears are not completely meshing ?
Does this in low high and reverse 2wd and awd ?
When you towed it home it was in neutral ?
Could be something caused by it being cold? How cold did it get when you let it set all night?
I remember reading something about letting the belt warm up by letting the engine idle for 5 min in cold weather.
Hope its still under warranty...
hoser is offline
post #3 of 36 Old January 18th, 2010, 08:05 AM Thread Starter
MacLeod's Avatar
Member #12699
Re: Grinding noise?
done it in high and low, not reverse yet (havn't really tried) and just in awd. will try again tonight. Sorry should of said i trailer it. Was not really that cold maybe -5C. I let it warm up for a minute but would think if it is grinding the clutch is spinning the transmission. Warrenty? LOL i hope, i picked it up Friday and this happened Sunday
MacLeod is offline
post #4 of 36 Old January 18th, 2010, 08:40 AM
hoser's Avatar
First Name: Hoser
Member #6551
Re: Grinding noise?
Oh no its that new, I would call the dealer ASAP and just let them deal with it, what you described sounds so far from being anything normal operation you should not have to mess with it, depending on whats wrong I would push for a new belt too.
Let us know how you make out.
hoser is offline
post #5 of 36 Old January 18th, 2010, 09:03 AM
gunrunner's Avatar
First Name: Man
Member #4830
Re: Grinding noise?
If you abused it enough to break that new big belt on a 010, then you could have damaged something else.
gunrunner is offline
post #6 of 36 Old January 18th, 2010, 09:33 AM
hoser's Avatar
First Name: Hoser
Member #6551
Re: Grinding noise?
It kinda makes you wonder if something inside the trans failed then partly or fully locked up the trans putting extra strain on the belt then the belt poofkaboom, never seen someone trying to get unstuck while driving anything including animals that went easy on it usually its WOT forward then WOT backwards.
hoser is offline
post #7 of 36 Old January 18th, 2010, 10:28 AM
polyol's Avatar
My RZR: 09 RZR
Member #6951
Feedback Score: 5 reviews
View polyol's Photo Gallery(0)
Re: Grinding noise?
You probably have a chunk stuck in your primary somewhere. Blow everything out and check for little fibers or rubber chuncks stuck in the works.
polyol is offline
post #8 of 36 Old January 18th, 2010, 10:36 AM Thread Starter
MacLeod's Avatar
Member #12699
Re: Grinding noise?
Could this cause grinding though
MacLeod is offline
post #9 of 36 Old January 18th, 2010, 10:42 AM Thread Starter
MacLeod's Avatar
Member #12699
Re: Grinding noise?
You don't have to be hard on something to get it stuck or unstuck. I wouldn't think spinning or reving a motor would be classified as abuse. And it got stuck in snow in a ditch. inside of belt/clutch housing wasn't even damp, so i don't think it sucked in any snow. Was moving backwards fine (about 10feet from spot it was stuck) , stoped put it in low and nothing.
MacLeod is offline
post #10 of 36 Old January 18th, 2010, 10:45 AM
polyol's Avatar
My RZR: 09 RZR
Member #6951
Re: Grinding noise?
Grinding going into gear or grinding when it already is in gear?
polyol is offline
post #11 of 36 Old January 18th, 2010, 10:53 AM Thread Starter
MacLeod's Avatar
Member #12699
Re: Grinding noise?
in gear moving then pops out of gear when under load. sounds the same as if i reved it up and tried to shift then.
MacLeod is offline
post #12 of 36 Old January 18th, 2010, 11:00 AM
polyol's Avatar
My RZR: 09 RZR
Member #6951
Re: Grinding noise?
Its possible, getting debris jammed into your clutching can cause all sorts of issues...but honestly your problems sounds a bit worse than that. If it is new, take it into the dealership, you shouldnt have these kinds of problems when its this new. I dont think ive ever heard of someone blowing a belt with that low of mileage, broken in or not.
polyol is offline
post #13 of 36 Old January 18th, 2010, 11:16 AM Thread Starter
MacLeod's Avatar
Member #12699
Re: Grinding noise?
yeah i called the sales guy i delt with and he seemed really surprised. I already fixed it so they may reimburse me for the price of the belt. I would be happy with that. Took the bike to the dealer about an hour ago. Tried it again and it only seems to happen in low awd, hopefully just some adjustment on the shifter (crossing my fingers)
MacLeod is offline
post #14 of 36 Old January 18th, 2010, 11:20 AM
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
Feedback Score: 18 reviews
Re: Grinding noise?
As stated earlier take it straight back to the dealer asap
GIFF-TURBO is offline
post #15 of 36 Old January 18th, 2010, 11:26 AM Thread Starter
MacLeod's Avatar
Member #12699
Re: Grinding noise?
Already took it back
MacLeod is offline
Grinding Gears RZR FAN Engine and Drivetrain 32 July 26th, 2011 08:32 AM
Viper Elite 3500 Grinding Noise baddobies Lighting, Stereo and Electrical 2 January 18th, 2010 08:38 PM
clutch grinding? kade RZR-S Specific Discussion 0 February 17th, 2009 09:16 AM
grinding in awd Crispy01 General RZR Discussion 4 October 5th, 2008 07:44 PM
grinding noise utvatv800 General RZR Discussion 3 July 16th, 2008 06:19 PM
