How to change a RZR clutch belt VIDEO - Polaris RZR Forum - RZR Forums.net
This is a discussion on How to change a RZR clutch belt VIDEO within the Engine and Drivetrain forums, part of the Technical category; The CVT running: YouTube Changing the belt: YouTube I added a second video (short version) that shows how to change the belt with and without ...
Old December 19th, 2009, 04:48 PM   #1
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
The CVT running:
Changing the belt:
I added a second video (short version) that shows how to change the belt with and without the "extension trick":
2011 RZR-900-XP version:
2014 RZR-1000-XP:
More info on how the CVT works from Team Industries:
Old December 19th, 2009, 05:05 PM   #2
shooters's Avatar
First Name: Robert
My RZR: 2012 XP900
Member #11783
View shooters's Photo Gallery(0)
re: How to change a RZR clutch belt VIDEO
Thank you thank you!
shooters is offline   Reply With Quote
Old December 19th, 2009, 05:10 PM   #3
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
Nice vid.Its about time there is a vid on changing the belt.
http://www.sharetrails.org
crazywatson is offline   Reply With Quote
Old December 19th, 2009, 05:21 PM   #4
AKA: blinginvic
Feedback Score: 6 reviews
bilinvic's Avatar
First Name: Bil
My RZR: 2009 Stealth Black LE
Member #6600
View bilinvic's Photo Gallery(27)
Yes...Thanks for taking the time to do this for us.
2009 RZR 800 LE (Stealth Black)
2009 RZR 170 - For Sale
My RZR Website: http://members.shaw.ca/bilinvicRZR/R...invic_Home.htm
bilinvic is offline   Reply With Quote
Old December 19th, 2009, 05:34 PM   #5
Gunny's Avatar
First Name: Randy
My RZR: 2009 RZR S
Member #9486
View Gunny's Photo Gallery(0)
Outstanding!!!!! Thank you. If you don't put the bolts back on the bottom of the clutch cover, won't it allow a bunch of dirt (sand) etc into your clutch housing ??
Gunny is offline   Reply With Quote
Old December 19th, 2009, 05:38 PM   #6
kedi's Avatar
First Name: Ken
My RZR: Gen II 2008
Member #1014
View kedi's Photo Gallery(1)
Thanks for the instruction vid Cliff.
Ken
kedi is offline   Reply With Quote
Old December 19th, 2009, 05:44 PM   #7
Tuf-Skin's Avatar
Member #2228
Well the cover has a ridge that sits in a groove on the back half, where the gasket seals the two halves.
I only leave two bolts out. The one above the coolant lines (that get really hot) and the one above the drive shaft. They aren't too hard to reach, but I don't need them.
I also use a modifed cover that is vented in an effort to keep the clutch as cool as possible. I have put my hand over the holes with the clutch running and felt air coming out, not going in. I have also never found any sand or dirt inside the clutch, even with all these holes...
Old December 19th, 2009, 07:07 PM   #8
c-huck's Avatar
First Name: chuck
My RZR: 2009rzr , progressive springs,DFR doors,dfr 3'' harnesses , DFR air canister
Member #6089
View c-huck's Photo Gallery(0)
thanx tuff-skin!
c-huck is offline   Reply With Quote
Old December 19th, 2009, 07:19 PM   #9
Grandpa
flyrccg's Avatar
My RZR: 2009 RZR-red
Member #7849
View flyrccg's Photo Gallery(0)
Very nice. Thank you. I didn't realize that it was so easy to change the belt.
Grandpa Chris
2009 RZR, 12" ITP ss108's, 26" Bighorns,Roktek lift,
EMP bumper,
Warn XT30 winch,
1/2" uhmw skids,
PIAA 510 SMR HID lights,
Rancho +6 long travel,
Twisted Stitch seats
flyrccg is offline   Reply With Quote
Old December 19th, 2009, 07:48 PM   #10
Tuf-Skin's Avatar
Member #2228
A question has come up as to how to pry open the secondary using the socket wrench extension. You push the extension towards the back of the RZR against the roller to pry open the sheaves of the secondary.
Here is a picture that BigMike58 took showing us how it works:
Old December 19th, 2009, 08:08 PM   #11
Tuf-Skin's Avatar
Member #2228
If you are putting together a tool kit for your RZR you might want to also include some needle nose pliers and a good knife. Sometimes if you break a belt they shred and the cords in the belt get tangled up in the clutch. If you are lucky you will hear some chunks come off the outside and hit the cover and be able to turn the engine off before they shred. Also remember to take a flashlight with you on night rides so you can work on it in the dark... Belts can last thousands of miles, but I have had them break in less than 500 too.
Old December 19th, 2009, 08:09 PM   #12
ohnuty's Avatar
First Name: Roy
My RZR: 09 Camo
Member #6946
View ohnuty's Photo Gallery(0)
I am not sure if that hole is only on the S, but it's not on mine. I have an 09 RZR (not S)and ended up using a strap oil filter wrench.
ohnuty is offline   Reply With Quote
Old December 19th, 2009, 08:14 PM   #13
Tuf-Skin's Avatar
Member #2228
What hole are you talking about? The hole where you stick the socket extension? If so you might have the Rapid Reaction secondary instead of the Team Roller...
Old December 19th, 2009, 08:16 PM   #14
ohnuty's Avatar
First Name: Roy
My RZR: 09 Camo
Member #6946
Yes, I was talking about the secondary. Do you know the difference of the two, performance wise?
Old December 19th, 2009, 08:20 PM   #15
Tuf-Skin's Avatar
Member #2228
The Rapid Reaction cost less to manufacture, there are less parts. But it is not as easy to change/tune. You can buy the Team Roller from Polaris or several clutch vendors. If you have a stock machine then leave it the way it is.
If you have the Rapid Reaction secondary you can get slack in the belt by pulling up on the belt hard. This will force open the sheaves of the secondary (like using the extension trick), it is just harder to do.
Tags
clutch
2011 rzr 170 cvt clutching
2013 rzr 170 drive belt replacement
2014 razor 1000 belt replacement youtube
change belt on 2011 rzr
changing belt on 2016 rzr 1000xp
how do you change a belt on a polaris
how often to replace drive belt for 2012 polaris rzr 800
how to change 2011 rzr belt
how to install a drivebelt on a 2008 polaris 800rzr
how to replace belt on rzr 1000
how to replace belt on rzr 800
polaris razor belt
polaris rzr 800 belt change
rzr 800 belt change
sostituzione cinta polaris rzr s
Belt change dwin RZR XP 900 7 February 16th, 2012 09:47 AM
How often do you change your belt? MossLager Engine and Drivetrain 4 October 31st, 2011 12:17 AM
When to change the belt WoodsRider General RZR Discussion 14 September 3rd, 2011 04:55 AM
