In 2009 did Polaris put clear fluid in the Transmission (Main Gearcase) and the Transmission (Transfer Case) at the factory?
The manual says use AGL Synthetic (PN 2873602) this oil is Purple.
Gary, I think what you might find is the factory put a break-in oil in.Thats why they want you to change it out after 25 hrs of running. I ran across the same thing in my 2009 also. Your right the new oil is purple. I don't know this for a fact but it was what I was told by a dealer, for what thats worth.
At 25 hrs they only change engine oil they dont change your gear oil until 1 yr. They probly just put in cheap oil then when you come back they sell you the expensive stuff.LOL
The clear stuff at the factory has a uv reflective dye in it to check for leaks in the final build stages.
I refuse to let break in oil stay in a machine for more than the first 25 hours.
Oil is cheap, parts ain't. Change them all on the first service.
Related Threads
3.1M posts
141.5K members
Since 2007
